Hey, folks-
My apologies in advance if I'm breaking any protocols here; I've tried in vain to figure out how to use testdisk to save six years of home video from a 3-TB external hard drive (WD MyBook). I let testdisk run all night and it seemed to confirm what I already suspected; my files are all safe; I just can't get to them because the drive is now RAW. I wanted to load screenshots, but in my sleep-deprived state, I somehow deleted them. (Yeah, I know... I'm not giving you much cause to want to invest any time or energy in me...)
Anyway, I've used a program called Directory Snoop to recover deleted files in the past, so instead of running the testdisk program for another eight hours, I just let Directory Snoop show the list it generated (which takes literally less than a minute). To me this confirms that my files are all there, safe and sound, but that I simply need to find a way of fixing the lone item that shows up in red (screenshot attached). Can any expert out there corroborate this? And if so, if I run testdisk again and show you all the screenshots, could I beg one of you to walk me through the steps to fix that lone problem? I would be deeply indebted to you (and I'd definitely make it worth your time. I promise!)
Thanks!
Kevin
Newbie with question Topic is solved
- Directory Snoop screenshot of M Drive (10-13-2013).JPG (225.62 KiB) Viewed 17542 times
Re: Newbie with question
Hi. Not everyone is familiar with "directory snoop" so perhaps it would be better to ask the question in a directory snoop forum. In directory snoop what does an item in red indicate? Just my opinion but I would let testdisk run its course and attempt to rebuild the partition table if it is possible. The wait is a small price to pay because if you have to recover a lot of data on a 3TB drive in raw mode it will take a long time.
Thanks for the reply, Bartleby, and it's a fair point. Not sure Directory Snoop even has a forum, but my hope was that somebody here who is more familiar with reading the technical information than I am would know at a glance if recovery is likely (or even possible.) As for your question, the red letters in Directory Snoop indicate deleted items; the program allows you to just hit UNDELETE and the file is recovered. I suspect the file noted in red is corrupted rather than deleted, and that makes it trickier. Even so, as soon as I can let testdisk run all night again, I'll grab the screen shots over again and hope for the best. Another question, if I may: Where does testdisk save the logs it asks to create? Both times I've run it, I've told it to create a log but I don't know where they are. If anybody can help me and has a followup question, I'll know what to offer them. Thanks again for taking the time!
Hi. On my system testdisk.log is created in my /home directory. You can search for it if necessary with: find / -name testdisk.log
If you only want to undelete a file, run TestDisk, go in the Advanced menu, select the FAT or NTFS partition and choose Undelete.
Hi again, guys, and thanks for the advice. I'd almost like to try that, cgrenier, but I don't see how it could be that simple. I know for certain that the file with the videos wasn't deleted, but I don't remember exactly what suggestions were coming up when I did the full testdisk run. I just remember that I got to a certain point and came across a screen that didn't match any of the examples I'd seen around this forum. I'm going to have to wait until I have a couple days off and I can let the thing run all night and grab the screenshots, then hope I can bother you folks again and get it figured out. Still hoping it's a minor fix that I simply don't know how to do yet. Thanks again!
Hi again, folks-
Finally had a chance to hook the drive up and run through all the steps. This is where things end up. Could somebody tell me where I go from here, or is the drive irrecoverable? Thanks-
Kevin
Kevin
- M Drive 06.JPG (42.24 KiB) Viewed 17371 times
- M Drive 07.JPG (54.83 KiB) Viewed 17371 times
- M Drive 08.JPG (56.81 KiB) Viewed 17371 times
The item listed in red is a deleted directory, so try the undelete function of TestDisk
http://www.cgsecurity.org/wiki/Undelete ... h_TestDisk
Hi, cjrenier! Thanks so much for the quick reply! As it happens, though, the files the undelete option turns up seem to be files I deleted myself and that I don't really need back. In the original Directory Snoop listing, all the files I that I DO want back are still in black (which means they're there, but they're not accessible because the disk is RAW).
This actually happened to me once before, and I vaguely remember running CHECKDISK through Windows and the entire drive came back. I can't swear to that, though, and everything I've read here says NOT to run CHECKDISK. Is there something else I should try?
Again, thanks for helping!
Kevin
Kevin
- M Drive 09.JPG (107.81 KiB) Viewed 17366 times
Hi again, cgrenier! Just letting you know that the information you shared with me was enough for me to figure out how to locate the files that I believed were NOT deleted. The COPY feature inside the advanced settings allowed me to start saving the lost videos, one at a time. It's been working for the past two hours and has recovered 166 of them (two years' worth!) with NO failed attempts. Four years' worth to go, but I have cause to believe I'll get them all, so THANK YOU! I said in an earlier post I'd make it worth your trouble, so I'll be contacting you by e-mail to do exactly that. You've made my day!
Kevin
P.S. And for the record, if anybody's wondering how I could be stupid enough to not have backups of these, I actually did. Three different drives went three different kinds of screwy over two days of power outages, and that's how I ended up in this mess. I am literally thanking God as well as the creator(s) of TestDisk for this program...
Kevin
- M Drive 10.JPG (80.94 KiB) Viewed 17360 times
