Recovering partition from 1TB external disc
Eruanno
#1 Post by Eruanno »
Hello again,
Now i have a problem with disc i'm mentioned here: http://forum.cgsecurity.org/phpBB3/post9837.html#p9837
However now i have problem with second disc 1TB. It was damaged when my friend try to copy files from previously mentioned Samsung disc to this one. He was using Ontrack Easy Recovery and choose "Copy Disc" option... lucky(?) he stopped progress after 2%. After scannig quick search with typ None option there was no partition that i could listed for files. Now I try with Intel option and i post result here.
Here is a log file:
Fri Oct 25 20:59:19 2013
Compiler: GCC 4.7, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=100030242816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000204883968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=41586983424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=58440614400
filewin32_getfilesize(\\.\E:) GetFileSize err Niepoprawna funkcja.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Niepoprawna funkcja.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=1000204124160
Disk \\.\PhysicalDrive0 - 100 GB / 93 GiB - CHS 12161 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Drive C: - 41 GB / 38 GiB - CHS 5055 255 63, sector size=512
Drive D: - 58 GB / 54 GiB - CHS 7105 255 63, sector size=512
Drive I: - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Geometry from i386 MBR: head=123 sector=57
BAD_RS LBA=1632504333 6031666
BAD_RS LBA=729050177 1083064
check_part_i386 2 type 74: no test
BAD_RS LBA=1918989427 6062649
check_part_i386 3 type 20: no test
 2 * Sys=74               45381  70  3 91774  34 41  745301316
 1 * HPFS - NTFS          101618 177 13 217117  30 49 1855482211
 3 * Willowsoft OFS1      119451 144 41 221239  34 18 1635217268
Not an exFAT boot sector.
Analyse Drive I: - 1000 GB / 931 GiB - CHS 121601 255 63
Invalid NTFS or EXFAT boot
Bad relative sector.
It's usb disc so i can't check it with MHDD :( here is smart summary from HDTune Pro:
HD Tune Pro: IntensoExternal USB 3.0 Health
ID                              Current  Worst    ThresholdData          Status
(01) Raw Read Error Rate        100      100      50       0             ok
(02) Throughput Performance     100      100      50       0             ok
(03) Spin Up Time               100      100      1        2640          ok
(04) Start/Stop Count           100      100      0        633           ok
(05) Reallocated Sector Count   100      100      50       0             ok
(07) Seek Error Rate            100      100      50       0             ok
(08) Seek Time Performance      100      100      50       0             ok
(09) Power On Hours Count       99       99       0        605           ok
(0A) Spin Retry Count           112      100      30       0             ok
(0C) Power Cycle Count          100      100      0        73            ok
(BF) G-sense Error Rate         100      100      0        0             ok
(C0) Unsafe Shutdown Count      100      100      0        7             ok
(C1) Load Cycle Count           100      100      0        1287          ok
(C2) Temperature                100      100      0        201864642594  ok
(C4) Reallocated Event Count    100      100      0        0             ok
(C5) Current Pending Sector     100      100      0        0             ok
(C6) Offline Uncorrectable      100      100      0        0             ok
(C7) Interface CRC Error Count  200      200      0        0             ok
(DC) Disk Shift                 100      100      0        0             ok
(DE) Loaded Hours               100      100      0        86            ok
(DF) Load/Unload Retry Count    100      100      0        0             ok
(E0) Load Friction              100      100      0        0             ok
(E2) Load-in time               100      100      0        266           ok
(F0) Head Flying Hours          100      100      1        0             ok
Health Status         : ok
What else can i do to rescue partition?
Re: Revovering partition from 1TB external disc
Don't scan I: but the physical disk. TestDisk may be able to detect the original partition after Analyse, Quick Search and Deeper Search.
Eruanno
#3 Post by Eruanno »
Thank you for reply. I've connected TOSHIBA through SATA interface and then TestDisc found partition table from the SAMSUNG disc, not TOSHIBA.
