after Photorec is finished
dimis46
#1 Post by dimis46 »
Hello i have a problem.
When photo rec is finished i have on my desktop a folder named recup_dir.1 and in that folder a have a zip file that i can not open it and see my files that i have recovered. what do i do???????
Re: after Photorec is finished
It may be a problem of file ownership:
http://www.cgsecurity.org/wiki/PhotoRec ... _files_.21
dimis46
#3 Post by dimis46 »
i am so sorry but i dont understand
As written in the FAQ I link to
- If you are using Windows, you may need to take ownership of the folders: http://support.microsoft.com/kb/308421
- Under MacOS X or Linux, change the owner of the files, example sudo chown -R username recup_dir.* or sudo chown -R username /home/username/testdisk-6.14/recup_dir.*. (When asked for the password, use the password from your user session to validate the sudo command)
