Can't open filesystem. Filesytem seems damaged.
Induna123
#1 Post by Induna123 »
I've had two IDE PATA hard drives go like this on me in the past couple of weeks. Not sure why. Basically, the drive is still visible in Windows XP. It shows up in My Computer with the drive letter but with no volume showing. It won't let me do chkdsk on the drive either.
I've ran TestDisk on it and the partition shows up but when I try to list files I get the following message "Can't open filesystem. Filesystem seems damaged." I went to the boot option and it says boot sector is OK.
Any ideas on how to at least to view the files and copy them?
Another thing, in Partition Magic 8 the drive shows up as ?m?
Induna123
Re: Can't open filesystem. Filesytem seems damaged.
#2 Post by Induna123 »
I forgot to attach the log. Very strange message shows up. Something about "MFT has invalid magic"?
Wed Oct 30 10:19:11 2013
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=122941242880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=203927027200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=122941242880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=203927027200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=10618804224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=112316166144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=203912884224
Disk /dev/sda - 122 GB / 114 GiB - CHS 14946 255 63, sector size=512 - Maxtor 6Y120P0, S/N:335958325a504533202020202020202020202020, FW:YAR41BW0
Disk /dev/sdb - 203 GB / 189 GiB - CHS 24792 255 63, sector size=512 - Maxtor 6L200P0, S/N:344c52304c424845202020202020202020202020, FW:BAH41G10
Disk /dev/sdb - 203 GB / 189 GiB - Maxtor 6L200P0
Analyse Disk /dev/sdb - 203 GB / 189 GiB - CHS 24792 255 63
NTFS at 1/1/1
 1 E extended LBA             1   0  1 24791 254 63  398267415
 5 L HPFS - NTFS              1   1  1 24791 254 63  398267352
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 1/1/1
filesystem size           398267352
sectors_per_cluster       8
mftmirr_lcn               24891709
clusters_per_mft_record   -10
     NTFS, blocksize=4096, 203 GB / 189 GiB
file_pread(5,2,buffer,398295040(24792/183/32)) lseek err Invalid argument
file_pread(5,1,buffer,398295040(24792/183/32)) lseek err Invalid argument
file_pread(5,1,buffer,398295039(24792/183/31)) lseek err Invalid argument
file_pread(5,14,buffer,398295041(24792/183/33)) lseek err Invalid argument
file_pread(5,3,buffer,398295055(24792/183/47)) lseek err Invalid argument
file_pread(5,3,buffer,398295102(24792/184/31)) lseek err Invalid argument
file_pread(5,8,buffer,398295118(24792/184/47)) lseek err Invalid argument
file_pread(5,11,buffer,398295165(24792/185/31)) lseek err Invalid argument
file_pread(5,2,buffer,398297087(24792/215/63)) lseek err Invalid argument
Not an exFAT boot sector.
add_ext_part_i386: max
add_ext_part_i386: min
write_all_log_i386: CHS: 1/0/1,lba=16065
NTFS at 1/1/1
ntfs_boot_sector
NTFS at 1/1/1
NTFS at 1/1/1
Status: OK
Status: OK
Sectors are identical.
ntfs_boot_sector
NTFS at 1/1/1
NTFS at 1/1/1
Status: OK
Status: OK
#3 Post by cgrenier »
What is the results if you try Repair MFT ?
Induna123
#4 Post by Induna123 »
Not sure why this happened. It was working perfectly normal. The two drives that have done this were connected to the USB port via USB-to-IDE cable like this one;
http://www.amazon.co.uk/Neewer-SATA-Dri ... 43-9554601
Would this be causing them to go bad like this?
Induna123
#5 Post by Induna123 »
Seems my screenshots have disappeared.
The message was MFT and MFT mirror are bad. Failed to repair them.
Not good news by the looks of it. I've googled the term and it seems TeskDisk has limited options from here. If both the $MFT and $MFT Mirror are bad then is there no way to reapir the MFT? Some suggestions were use GetDataBack to recover the data and then format the drive, is this the only option left?
#6 Post by cgrenier »
Yes, you can try this utility. If it doesn't work, use PhotoRec to recover your files (files will have generic filenames instead of the original ones).
yvann
#7 Post by yvann »
Hi everyone.
I also got to the point where I encountered the very same messages (file system damaged) finally performed the "Write" using TestDisk and it reallocated a partition letter "D:" to my external USB disk (SAMSUNG Momentus ST320LM001 320GB);
I could not anymore open the disk using windows but another thing: CHKDSK D: /F /R and seems to find again the files; But this is the very first time I seek CHKDSK taking that much time (hours).
However, it seems to recover most files.
#8 Post by Fiona »
You should never use Partition Magic.
It's an old obsolete program and doesn´t support most new features.
It often caused loss of data.
Daterecovery software would be a good solution.
To have another try to run chkdsk would be:
You can run testdisk / Advanced / RebuildBS.
If the boot sector (extrapolated) is different to the current one, you can have a try to list your data and write it.
Then you can have another try to run chkdsk.
You should open your terminal with administrator privileges.
You should run chkdsk from system root like C: or C:\Windows\System32.
Please try the parameter chkdsk Driveletter: /r.
If it doesn´t work for you, after datarecovery using datarecoverty software, you can create a new partition and reformat it and copy your data back.
