K so heres the deal...
I have an external usb hard drive that I stored most of my data on. One day I was loading files on it, and after I was done I got a bit excited and unplugged it before the computer was done shutting down.
Wed Nov 6 07:56:23 2013
OS: Linux, kernel 3.8.0-29-generic (#42~precise1-Ubuntu SMP Wed Aug 14 15:31:16 UTC 2013) i686
Compiler: GCC 4.6
Compilation date: 2012-02-05T07:16:54
ext2fs lib: 1.42, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: size 312500000 sectors
/dev/sda: user_max 312500000 sectors
/dev/sda: native_max 312500000 sectors
/dev/sda: dco 312500000 sectors
/dev/sdb: LBA, LBA48, DCO support
/dev/sdb: size 781422768 sectors
/dev/sdb: user_max 781422768 sectors
/dev/sdb: dco 781422768 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size 976773168 sectors
/dev/sdc: user_max 976773168 sectors
/dev/sdc: native_max 976773168 sectors
/dev/sdc: dco 976773168 sectors
Disk /dev/sda - 160 GB / 149 GiB - CHS 19452 255 63, sector size=512 - WDC WD1600JS-75MHB0, S/N:WD-WMANM1016040, FW:03.01C03
Disk /dev/sdb - 400 GB / 372 GiB - CHS 48641 255 63, sector size=512 - ST3400820AS, S/N:9QG5XVNF, FW:3.CHL
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500418AS, S/N:5VM0N9K6, FW:CC34
Disk /dev/sdc - 500 GB / 465 GiB - ST3500418AS
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
Geometry from i386 MBR: head=1 sector=63
NTFS at 0/1/1
1 * HPFS - NTFS 0 1 1 60801 0 63 976768065 [Expansion Drive]
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sdc - 500 GB / 465 GiB - CHS 60802 255 63
search_vista_part: 1
NTFS at 0/1/1
filesystem size 976768065
mftmirr_lcn 2
NTFS, 500 GB / 465 GiB
Warning: the current number of heads per cylinder is 255 but the correct value may be 128.
* HPFS - NTFS 0 1 1 60801 254 63 976784067 [Expansion Drive]
1 * HPFS - NTFS 0 1 1 60801 254 63 976784067 [Expansion Drive]
NTFS at 0/1/1
mftmirr_lcn 2
BAD_RS LBA=3998587624 10892290
HPFS - NTFS 248900 144 53 298025 115 50 789191296
This partition ends after the disk limits. (start=3998587624, size=789191296, end=492811623, disk end=976784130)
The harddisk (500 GB / 465 GiB) seems too small! (< 2451 GB / 2282 GiB)
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 18-Oct-2013 02:36 .
5 dr-xr-xr-x 0 0 0 18-Oct-2013 02:36 ..
36 dr-xr-xr-x 0 0 0 17-Oct-2013 18:25 $RECYCLE.BIN
39 dr-xr-xr-x 0 0 0 18-Oct-2013 02:36 System Volume Information
