New User Who's Stuck
Miller62808
#1 Post by Miller62808 »
Background. My old laptop crashed; hp pavilion dv4 running Windows 7. Blinking light indicated CPU failure, so removed my HD to make external and recover data. Using husband's Toshiba satellite now, and external won't boot (should be bootable). Get the BSOD that indicates bad boot sector, ran testdisk which gives back that boot information is good - or at least identical. Not sure where to go next. all of my daughter's pictures are on this HDD! Please help!
Thu Nov 21 21:59:23 2013
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=238736637952
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=14195621888
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=108191744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=235544772608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=208666624
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - TOSHIBA MK2565GSXV, S/N:8 F0SGN4SP, FW:GH01
Disk /dev/sdb - 250 GB / 232 GiB - CHS 103936 127 37, sector size=512 - ATA TOSHIBA MK2555GS, FW:2C
Disk /dev/sdb - 250 GB / 232 GiB - ATA TOSHIBA MK2555GS
New geometry
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30402 255 63 sector_size=512
NTFS at 0/32/33
NTFS at 25/126/38
NTFS at 28662/46/57
FAT32 at 30388/9/22
Info: size boot_sector 211312, partition 211312
FAT1 : 6604-7397
FAT2 : 7398-8191
Data : 8192-211311
sectors : 211312
cluster_size : 2
no_of_cluster : 101560 (2 - 101561)
fat_length 794 calculated 794
1 * HPFS - NTFS 0 32 33 25 126 37 407552 [SYSTEM]
NTFS, blocksize=4096, 208 MB / 199 MiB
2 P HPFS - NTFS 25 126 38 28662 46 56 460048384
NTFS, blocksize=4096, 235 GB / 219 GiB
3 P HPFS - NTFS 28662 46 57 30388 9 21 27725824 [RECOVERY]
NTFS, blocksize=4096, 14 GB / 13 GiB
4 P FAT32 LBA 30388 9 22 30401 48 31 211312 [HP_TOOLS]
FAT32, blocksize=1024, 108 MB / 103 MiB
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size 407552
mft_lcn 16981
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
Failed to open inode: Input/output error.
repair_MFT
NTFS at 0/32/33
ntfs_readdir failed for cluster 5
NTFS listing using MFT:
5 dr-xr-xr-x 0 0 0 17-Nov-2013 04:12 .
5 dr-xr-xr-x 0 0 0 17-Nov-2013 04:12 ..
ntfs_dir: ntfs_inode_open failed
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 16981
mftmirr_lcn 2
Status: OK
Status: OK
rebuild_NTFS_BS
mft at 16, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 16981
ntfs_find_mft: mftmirr_lcn 2
mft_lcn 16981
mftmirr_lcn 2
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 16981
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 25/126/38
NTFS at 25/126/38
filesystem size 460048384
mftmirr_lcn 7602175
Status: OK
Status: OK
Re: New User Who's Stuck
TestDisk has failed to access your data. You can still use PhotoRec to recover them, but the files won't have their original filenames.
Miller62808
#3 Post by Miller62808 »
I have tried photorec and a lot of my files are missing.
After selecting the NTFS partition, choose [Whole] instead of [Free]. Do you get better results ?
