Extended disk incorrect free space
Carl039
#1 Post by Carl039 »
I was adding a extra disk to an already extended volume in Windows 2008 R2 server and I opted to the extend which Windows reported reported a upgrade the disk to Dynamic was required first, I usually do this step manually but on this occassion I thought what could possibily go wrong. Big mistake!
The original disk was 1 x 256GB and 1 x 100GB extended to give a total of 356GB space.  At this point I had 72GB free space.  I then added a 3rd 256GB and exended the volume expecting free space would be 328GB, but windows only managed to set the disk to dynamic, add the disk as a extended volume and then error with a command failed message.  My free space is still 72GB free.
Running a chkdsk /f hasn\'t helped, would using testdisk repair the issue?
Re: Extended disk incorrect free space
Dynamic volumes don't use a partition table.
That's why it's not possible to write a partition table.
As long as you see your volume in your disk management console, you can have a try to repair the boot sector.
In some cases I used the windows disk management console to create volumes exactly like before.
Using Rebuild BS or Backup BS in TestDisk restored the data.
Would it be possible to upload a screenshot from your disk management console?
I assume that your volume appears as RAW?
Information will follow.
Carl039
#3 Post by Carl039 »
Hi
The disk is not appearing as RAW.
Screenshots have been attached.
Thanks
Carl
