I have not made sense of very well
testdisk is started (for the reason that doesn't find the partition so)
server-root: testdisk / dev/cciss/c1d1
and when she is started the file of the logs testdisk.log it doesn't create me in the directory root, instead when she is normally started with the command
the screens of creation of the logs it doesn't exist in the first case.
thanks
Partition Raid1
Re: Partition Raid1
Your disk description indicates wrong chs-values.
You can use the menu "Geometry" to change the value 32 to 63 and have another try to search for your partitions.
Please edit only the value sector from 32 to 63 ant test it again!
Leave all the other values alone!
As long as you don't use write, you'll not going to change anything to your disk.
It's only a try to find your partitions.
The value 32 might be wrong and should be 63.Disk / dev/cciss/c1d0 - 999 GBs / 931 GiBs - chs 239337 255 32
Re: Partition Raid1
I have tried with a new quick search alone cambianto the sectors to 63, then I make you know.
if you have time and you want my id of teamwiev sending you a message, if it is not too much
Re: Partition Raid1
This is the result the partition it called Raid1.
What I have to do now.
I ask you I help!
I ask you I help!
Re: Partition Raid1
Nobody can kindly help me for the solution above
Re: Partition Raid1
this is the result a help.
Thanks
Thanks
Re: Partition Raid1
she has not ended but this message has appeared
