Hello everyone,
OK, so here is the story. I was editing the partitions on an extra internal drive on my Mac Pro running Lion 10.7.5. I accidentally selected the entire drive and not the partition that I needed to erase and now all my data and the partitions are just one single formatted drive called Untitled.
So I booted up to a spare install of Lion and used TestDisk to hopefully recover my partitions. It finds the correct partitions right away, but after I tell it to write the partition structure and reboot, the drive still shows up as just one partition named Untitled.
I must mention that I have read all the instructions before hand and read through the forums already. I unmounted the disk before launching TestDisk and I did launch it with sudo. I have tried dev/disk0 and dev/rdisk0. I have also used TestDisk in the past, but for some strange reason its not working for me this time.
What could be the issue?
I have uploaded all the screenshots of my progress for you to double check my work.
https://drive.google.com/file/d/0B-zaWl ... sp=sharing
Thanks
TestDisk found my formatted partition, but I cant write them
Re: TestDisk found my lost partition, but I can't write them
Same issue.
mine is Win 7 32, drive is 2TB on USB interface (tried more than one interface)
shows proper info to retrieve, select write, reboot, restart drive, but not fixed
thanx
e
thanx
e
Your partition is listed in the current partition table, so no need to use TestDisk to search for the partition. Your partition isn't lost, you have reformated it! Use PhotoRec instead. Good luck for renaming all the recovered files...
The thing is, I have made the mistake before of formatting the wrong disk from Disk Utility and TestDisk has been able to recover the partitions every time, except this time.cgrenier wrote:Your partition is listed in the current partition table, so no need to use TestDisk to search for the partition. Your partition isn't lost, you have reformated it! Use PhotoRec instead. Good luck for renaming all the recovered files...
Why is it that the old partition scheme is found, but can't be written back on this drive?
I have attached the log file for anyone able to look it over.
Thanks
Re: TestDisk found my formatted partition, but I cant write
I don't find any logfile?
As you reported your topic, you're not able to upload your logfile, did you get any message?
Did you use a supported file format to upload?
Also, you can copy and paste the content of your testdisk.log into your next post.
I just noticed the error now, because its a little hidden. "The extension txt is not allowed"
Here is the log just pasted in. Thank you
________________________________________________________________________
Mon Dec 9 01:27:03 2013
OS: Darwin, kernel 11.4.2 (Darwin Kernel Version 11.4.2: Thu Aug 23 16:26:45 PDT 2012; root:xnu-1699.3
Compiler: GCC 4.0
Compilation date: 2013-07-30T14:08:37
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
Disk /dev/disk0 - 2000 GB / 1863 GiB - 3907029168 sectors, sector size=512
Disk /dev/disk1 - 3000 GB / 2794 GiB - 1565565872 sectors (RO), sector size=512
Disk /dev/disk2 - 250 GB / 232 GiB - 488397168 sectors (RO), sector size=512
Disk /dev/rdisk0 - 2000 GB / 1863 GiB - 3907029168 sectors, sector size=512
Disk /dev/rdisk1 - 3000 GB / 2794 GiB - 1565565872 sectors (RO), sector size=512
Disk /dev/rdisk2 - 250 GB / 232 GiB - 488397168 sectors (RO), sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/rdisk0 - 2000 GB / 1863 GiB - 3907029168 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 3907029167)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 40 409639 409600
2 P Mac HFS 409640 3906766983 3906357344
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
EFI System 40 409639 409600 [EFI]
part_size 3906357344
HFS+ blocksize=4096, 2000 GB / 1862 GiB
P EFI System 40 409639 409600 [EFI]
1 P EFI System 40 409639 409600 [EFI]
write!
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
write!
