Is there a max file size that can be copied in list option?
sjoshi60
#1 Post by sjoshi60 »
I am trying to recover files using the List option and then Copy and select a destination. Whenever I try to copy a file greater than around 4 GB, it keeps copying the file to the destination over and over. Has anyone seen this problem?
BTW The Files seem to be intact after I select the List option.
Additionally, I am using the List option only because I cannot recover the partition using Rbuild_BS. The Serach mft did not find anything and returns with no error. I had to select "None" as partition type table in the initial menu. If I select "Intel/PC" it returns the Bad relative sector error.
Below is the log.
Compiler: GCC 4.7, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500000882688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000388063744
Disk \\.\PhysicalDrive0 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Drive C: - 500 GB / 465 GiB - CHS 60788 255 63, sector size=512
Drive D: - 2000 GB / 1863 GiB - CHS 243199 255 63, sector size=512
Partition table type: None
Analyse Disk \\.\PhysicalDrive2 - 250 GB / 232 GiB - CHS 30401 255 63
P Unknown 0 0 1 30401 80 63 488397168
NTFS at 20/176/23
filesystem size 488064366
mftmirr_lcn 30504022
NTFS part_offset=170193920, part_size=249888955392, sector_size=512
NTFS at 20/176/23
NTFS 20 176 23 30401 74 49 488064366 [HD PART]
NTFS, blocksize=4096, 249 GB / 232 GiB
file_win32_pread(96,11,buffer,488397163(30401/80/59)) read err: read after end of file
file_win32_pread(96,8,buffer,488397162(30401/80/58)) read err: read after end of file
file_win32_pread(96,8,buffer,488397166(30401/80/62)) read err: read after end of file
file_win32_pread(96,14,buffer,488397155(30401/80/51)) read err: read after end of file
file_win32_pread(96,14,buffer,488397156(30401/80/52)) read err: read after end of file
file_win32_pread(96,14,buffer,488397157(30401/80/53)) read err: read after end of file
file_win32_pread(96,14,buffer,488397158(30401/80/54)) read err: read after end of file
file_win32_pread(96,14,buffer,488397159(30401/80/55)) read err: read after end of file
file_win32_pread(96,14,buffer,488397160(30401/80/56)) read err: read after end of file
file_win32_pread(96,14,buffer,488397162(30401/80/58)) read err: read after end of file
file_win32_pread(96,14,buffer,488397164(30401/80/60)) read err: read after end of file
file_win32_pread(96,14,buffer,488397166(30401/80/62)) read err: read after end of file
P NTFS 20 176 23 30401 74 49 488064366 [HD PART]
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 5-Jun-2012 21:45 .
5 dr-xr-xr-x 0 0 0 5-Jun-2012 21:45 ..
19149 dr-xr-xr-x 0 0 0 29-Dec-2010 14:17 $RECYCLE.BIN
7906 dr-xr-xr-x 0 0 0 27-Aug-2007 12:14 Aai Tahoe Trip
29 dr-xr-xr-x 0 0 0 8-Nov-2008 19:45 Canon Videos
19095 dr-xr-xr-x 0 0 0 27-Nov-2009 22:49 From pqi
7899 dr-xr-xr-x 0 0 0 21-Oct-2010 21:52 HPLaptop
178 dr-xr-xr-x 0 0 0 29-Jan-2011 18:28 Movies
424 dr-xr-xr-x 0 0 0 1-Jun-2009 23:28 Music
15319 dr-xr-xr-x 0 0 0 24-Dec-2008 17:04 My Pictures
1228 dr-xr-xr-x 0 0 0 9-Aug-2009 16:17 NOMADAPP
7904 dr-xr-xr-x 0 0 0 11-Sep-2009 15:57 Nikhil
25770 dr-xr-xr-x 0 0 0 15-Jun-2010 07:31 Nikhil Graduation 2010
25965 dr-xr-xr-x 0 0 0 28-Aug-2010 14:13 Nikhil's Camera India 2010
19148 dr-xr-xr-x 0 0 0 5-Sep-2009 13:31 PSCS4
388 dr-xr-xr-x 0 0 0 12-May-2012 12:46 Pictures
18416 dr-xr-xr-x 0 0 0 7-Jul-2009 23:45 Pinnacle Studio
36 dr-xr-xr-x 0 0 0 28-Oct-2008 18:08 RECYCLER
27 dr-xr-xr-x 0 0 0 11-Sep-2011 17:16 System Volume Information
7990 dr-xr-xr-x 0 0 0 27-Aug-2007 15:02 Temp
17363 dr-xr-xr-x 0 0 0 28-May-2009 16:44 VIDEO_TS
7813 dr-xr-xr-x 0 0 0 20-Feb-2008 19:25 starcraft
26662 -r--r--r-- 0 0 27 9-Oct-2010 21:18 DONTSHOW.INI
18995 -r--r--r-- 0 0 1463903997 11-Sep-2009 09:33 StudioTrialExtractor.exe
18995 -r--r--r-- 0 0 0 11-Sep-2009 09:33 StudioTrialExtractor.exe
18995 -r--r--r-- 0 0 26 11-Sep-2009 09:33 StudioTrialExtractor.exe:Zone.Identifier
ERROR: Couldn't set
