WD USB HDD "You need to format disk...."
aagnie
#1 Post by aagnie »
Hi ,
I have been working with testdisk and my brothers external WD HDD. He has been using it for backup and needs the content but windows is unable to use the disk and keeps saying "You need to format disk..:". I have tried Mac and Linux as well.
So I have been able to copy pictures and movies clips using TestDisk (thanks!) - but before formating the disk I am wondering what is wrong with the disk
When I look at the disk (see below) the backup boot sector is bad - but when I try to copy it from the boot sector - I get write error !
TestDisk 6.14-WIP, Data Recovery Utility, March 2012
 1 * FAT32 LBA                0   1  1 121600 254 63 1953520002 [Elements]
OK
fat32_boot_sector: Can't read backup boot sector.
Bad
First sectors (Boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
Third sectors (Second part of boot code) are not identical.
 [  Quit  ]  [  List  ] >[Org. BS ]  [Rebuild BS]  [  Dump  ]
                      Copy boot sector over backup sector
Result of copy:
"Write error: Can't overwrite FAT32 backup boot sector"
Any clue ?
Best regards
Aage
Re: WD USB HDD "You need to format disk...."
In few cases I've seen this message, it was not possible to copy the boot sector over the backup of the boot sector.
Also, some users tried to repair their backup from the boot sector.
After copying the boot sector over its backup, partition appeared as RAW.
In some cases chkdsk /r helped to solve that issue!
In this case, I only suggest to sync a backup of a boot sector if there is any reason for.
Before someone uses chkdsk, I suggest to have a backup first.
Should be a normal maintenance, like backup, chkdsk and defrag.
aagnie
#3 Post by aagnie »
Hmm strange - tried the chkdsk way
C:\Windows\system32>fsutil fsinfo drives
Drives: C:\ D:\ E:\
C:\Windows\system32>chkdsk e: /r
The type of the file system is RAW.
CHKDSK is not available for RAW drives.
No luck.
I have checked/tried the recovery example on the wiki - but the "write error...:" appears again.
/aage
#4 Post by Fiona »
I'd need infos from TestDisk Analyse and Quick Search.
Under Quick Search, press p to list your data.
I'll compare your partition table to the results under Quick Search.
I'ts strange, normally TestDisk displays data if at least the boot sector or it's backup is ok.
In your case your boot sector is OK, but your backup of the boot sector not.
In this case, your data should be avilable and chkdsk should be possible.
aagnie
#5 Post by aagnie »
I have done the analyse and quick search part.
The output:
Keys A: add partition, L: load backup, Enter: to continue
When hitting enter:
 [  Quit  ] >[Deeper Search]
                          Try to find more partitions
I have tried the "Load backup" with no luck - so I need to add a partion or ?
Regards
Aage
#6 Post by Fiona »
Using the menu Advanced found your boot sector.
But it looks like that Quick and Deeper Search didn't find it.
Your partition should be in your partition table, otherwise Advanced wouldn't list it.
Got to the menu Advanced and Boot.
Check how your boot sector is listed.
Please upload a screen.
Might be possible to use Rebuild BS.
Information will follow.
aagnie
#7 Post by aagnie »
Hi ,
The boot sector is aparently ok as listed below.
OK
Bad
Really weird ;-)
Regards
Aage
#8 Post by Fiona »
Would it be possible to use Rebuild BS?
When it was successful, you'll see the menu List.
Do you see your data or an error message?
Please let me know.
If your data are listed, I'd suggest to copy them to another intact partition or disk.
Don't use Write at the moment.
aagnie
#9 Post by aagnie »
The output from "Rebuild bs"
OK
Bad
>[  Quit  ]  [  List  ]  [Org. BS ]  [Rebuild BS]  [  Dump  ]
                            Return to Advanced menu
As far as I can see - all the files are present when choosing "List" - as I mentioned earlier - copying files is not a problem - I have copied all the pictures and some video to another drive.
Regards
/Aage
#10 Post by Fiona »
Looks like Rebuild BS easily goes back to the previous screen.
It was intended to get a different result, so that chkdsk might work.
But it didn't work either.
In your case if you copied/backup your data, the format your harddisk and copy data back.
