GUI:
Disk Management
The operation failed to complete because the Disk Management console view is not up-to-date. Refresh the view by using the refresh task. If the problem persists close the Disk Management console, then restart Disk Management or restart the computer.
OK
DISKPART> select disk 2
Disk 2 is now the selected disk.
DISKPART> list partition
Partition ### Type Size Offset
* Partition 1 Primary 931 GB 0 B
DISKPART> select partition 1
There is no partition selected.
DISKPART> assign letter=F:
There is no volume specified.
Please select a volume and try again.
DISKPART>
Disk /dev/sdf - 1000 GB / 931 GiB - CHS 121601 255 63
Invalid NTFS or EXFAT boot
1 P HPFS - NTFS 119528 74 3 232582 38 44 1816210284
Bad relative sector.
2 * Sys=6C 120512 46 15 242121 118 1 1953653108
>[Quick Search] [ Backup ]
Try to locate partition
