Analysis of Drive
Drive F: - 500 GB / 465 GiB - CHS 60800 255 63
Partition Start End Size in secto
1 * Sys=72 13577 238 11 119521 238 60 1701990410
Bad relative sector.
2 * Sys=74 45381 70 3 79242 34 29 543974724
3 * NetWare 3.11+ 10498 56 41 10498 56 40 0
I created a dd of both partitions (72 and 74) and both returned "Image created successfully but read errors have occurred."
I tried to mount the image.dd files (but they're RAW) in Ubuntu and continually receive:
mount: you must specify the filesystem typeCode: Select all
sudo fdisk -l ~/share/image.dd
Disk /home/hakarune/share/image.dd: 388.4 GB, 388422383104 bytes
255 heads, 63 sectors/track, 47222 cylinders, total 758637467 sectors
Disk identifier: 0x249061c1
Disk /home/hakarune/share/image.dd doesn't contain a valid partition table
I have tried every method I could think of and the internet's knowledge database, but nothing.
