Want to search for .sxw and .svg only
tamccullough
#1 Post by tamccullough »
Hi there,
At the moment I am looking to recover only .svg and .sxw file formats with photorec.
After clearing all file formats, which ones should I re-select to do that?
Thanks!
Kaineda77
Re: Want to search for .sxw and .svg only
#2 Post by Kaineda77 »
Hi Tamccullough,
did you find a solution? I have the same problem. I know that svg files are part of a file format, I just dont know which one it is.
Bests
Kai
#3 Post by cgrenier »
This information can be found at http://www.cgsecurity.org/wiki/File_For ... y_PhotoRec
svg are part of the tx? file family, sxw of the zip family.
Kaineda77
#4 Post by Kaineda77 »
Thanks a lot CGrenier!
