can't launch get command not found
bth73
#1 Post by bth73 »
Using mint 9 on 1 comp and mint 16 on another. sudo ~/testdisk_static /dev/yourdisk only returns "command not found
some help needed. thanks, BT
Lito
Re: can't launch get command not found
#2 Post by Lito »
You can try:
sudo testdisk
If this does not work you could try becoming the Superuser (root). Better disconnect from the Internet and then type:
su -
After that just type:
testdisk
Best of luck
