Help Recover or Repair Partition Segate GoFlex 500GB
Hakarune
#1 Post by Hakarune »
So I'm trying to repair my external drive or at least recover the partition and I can't seem to get anything to work right, I even tried to to dd the partition and mount in Linux, but no avail. The original file system was the default Segate NTFS setup, never changed.
When I start the app for my drive I get this message off the bat.
Hint: None partition table type has been detected.
Note: Do NOT select 'None' for media with only a single partition. It's very
rare for a drive to be 'Non-partitioned'.
Analysis of Drive:
Drive F: - 500 GB / 465 GiB - CHS 60800 255 63
     Partition                  Start        End    Size in secto
 1 * Sys=72               13577 238 11 119521 238 60 1701990410
Bad relative sector.
 2 * Sys=74               45381  70  3 79242  34 29  543974724
 3 * NetWare 3.11+        10498  56 41 10498  56 40          0
I've done "quick scan" and "deeper scan" but nothing seems to give me the option to write. The original system was an NTFS external drive (plugged into Linux it is read as NTFS, but won't mount and Windows wants to Format it. In TestDisk it says "Hint: choose none" when I go to examine the drive. I also tried running the drive as an Intel setting. Nothing bares fruit, can someone help me please :( ?
I created a dd of both partitions (72 and 74) and both returned "Image created successfully but read errors have occurred."
I tried to mount the image.dd files (but they're RAW) in Ubuntu and continually receive:
mount: you must specify the filesystem type
sudo fdisk -l ~/share/image.dd
Disk /home/hakarune/share/image.dd: 388.4 GB, 388422383104 bytes
255 heads, 63 sectors/track, 47222 cylinders, total 758637467 sectors
Disk identifier: 0x249061c1
Disk /home/hakarune/share/image.dd doesn't contain a valid partition table
I also tried to use OSFMount to mount them, but again it says no file system structure and I can't access the image files.
I have tried every method I could think of and the internet's knowledge database, but nothing.
QUICK SCAN (Intel/PC partition):
 [  Quit  ] >[Deeper Search]
                          Try to find more partitions
DEEPER SEARCH (Intel/PC partition):
>L Linux                 9725  15 11  9802 144 62    1245184 [preinstall]
     Enter: to continue
ext3 blocksize=1024 Backup superblock, 637 MB / 608 MiB
 1 E extended LBA          9725   0  1  9802 254 63    1253070
 5 L Linux                 9725  15 11  9802 144 62    1245184 [preinstall]
I can re-scan using "none" if that needs to be posted too, it did give more partitions found, but said cannot write because there wasn't a file system type.
