I have RAID 10 with 3 logical partitions and 100 MB Windows partition. Recently I replaced my old faulty disks so that now there are 2 ~500 GB disks and 2 ~1000 GB disks. It all worked fine for last three weeks. though system decided not to use one of 1000 GB disks (offline member), possibly for extended partition.
However, yesterday it all collapsed and RAID started to show as "failed". Following this guide, I dissasembled RAID, then rebuild it, hopefully with same settings.
Now, after deep search, TestDisk shows the following:
My system partition and (I assume) boot partition is gone. Deep search recognized 8 partitions in total (possibly 4 x 2), though I couldn't select complete partition set without getting"BAD". This is what I ended up with.
Filesystem for all partitions seems damaged.
Now, I probably would like to reinstall system and try to recover missing files with PhotoRec, though first of all partition structure should be rebuild. Any structure on how to proceed?
