Unable to format File system shows GW RAW
Crimsoncobra
#1 Post by Crimsoncobra »
I have an SSD drive which seems damaged. File system in windows shows GW RAW. Tried to format but it will not. Tried to rebuild but that failed.
Question: is it possible to manually rebuild this drive so it is bootable as NTFS?
Any help will be appreciated.
Thanks.
Testdisk analysis log:
Sat Feb 22 09:03:34 2014
TestDisk 7.0-WIP, Data Recovery Utility, January 2014
Compilation date: 2014-02-02T16:29:31
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=128035675648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=128035675648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=312090950144
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD32 00BEKT-60V5T, S/N:W -DXW1H3AX07657, FW:12.0
Disk /dev/sdb - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - EDGE SSD
Disk /dev/sdb - 128 GB / 119 GiB - EDGE SSD
Partition table type: None
P Unknown 0 0 1 15566 29 62 250069679
Change partition type:
Analyse Disk /dev/sdb - 128 GB / 119 GiB - CHS 15566 255 63
test_FAT()
1 P FAT16 >32M 0 32 33 15565 241 36 250064896
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
