Recover files from RAW ext 1.5 tb WD hdd Topic is solved
RJL24
#1 Post by RJL24 »
WIN7 Professional, External WD 1.5TB hdd, containing backup files of all types.
HDD connected via USB on a HP SJ9 desktop 64 bit system, 2 Quad CPU 2.83 ghz 8gb ram.
I think there were about 200GB of active back-up type files, thus about 1.3GB of the drive is empty.
Can not access drive even to format via WINDOWS.
Showing as RAW and inaccessible
I did use Wondershare DATA Recovery to extract files but no file names came associated with the files. So I am deciding to try another way to extract the files and then hopefully reformat the drive.
AM having difficulty understanding TESTDISK.
QUOTE
Drive P: - 1500 GB / 1397 GiB - CHS 182400 255 63
Keys A: add partition, L: load backup, Enter: to continue
UNQUOTE
My options are only A and L, this I do not get option to P that I am reading about.
Pressing L gets a message don't use backup and try to locate partition. How do I do this?
Thank you in advance.
Consider my a newby.
Robert
RJL24
Re: Recover files from RAW ext 1.5 tb WD hdd
#2 Post by RJL24 »
Was fortunate to sort things out, and this software is powerful and useful. All necessary files retrieved.
And found at WD.com a software to format the RAW drive back to usefulness.
Thank you TestDisk. Thank you.
