Hello all,
I really need help. I was using my husband's WD 500 GB external hard drive and it was working fine, next morning it just went RAW and windows wouldn't recognize it and asks to format it. Funny enough though it works perfectly fine on my TV, I can access all files and media perfectly! I stumbled upon Test Disk and decided to give it a try, I got the error :The harddisk (500 GB / 465 GiB) seems too small! (< 2736 GB / 2548 GiB). I don't really understand what's wrong , I spent the past 6 hours searching forums but then again I've been awake for the past 48 hours and my brain is mushy..I would appreciate any help greatly.
Here's the log:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500096991744
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 24 GB / 22 GiB - CHS 2919 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 974 GB / 907 GiB - CHS 118510 255 63, sector size=512
Drive E: - 500 GB / 465 GiB - CHS 60799 255 63, sector size=512
Analyse Drive E: - 500 GB / 465 GiB - CHS 60799 255 63
Geometry from i386 MBR: head=117 sector=57
BAD_RS LBA=1919950958 5725296
check_part_i386 1 type 20: no test
BAD_RS LBA=1330184202 4633706
check_part_i386 2 type 6B: no test
BAD_RS LBA=538989391 5544459
check_part_i386 3 type 53: no test
BAD_RS LBA=1394627663 1397717
check_part_i386 4 type 49: no test
1 * Willowsoft OFS1 119511 107 3 153401 15 41 544437093
Bad relative sector.
2 * Sys=6B 82800 34 61 116349 219 8 538976288
3 * OnTrack DM WO ??? 33550 137 11 120594 153 54 1398362912
4 * Sys=49 86811 142 3 86812 225 45 21337
file_win32_pread(120,16,buffer,26640(1/167/55)) read err: read after end of file
file_win32_pread(120,16,buffer,53311(3/81/14)) read err: read after end of file
file_win32_pread(120,16,buffer,71806(4/119/50)) read err: read after end of file
file_win32_pread(120,1,buffer,71811(4/119/55)) read err: read after end of file
BAD_RS LBA=2319100427 1036634
HPFS - NTFS 144357 82 57 332638 127 24 3024737068
This partition ends after the disk limits. (start=2319100427, size=3024737068, end=1048870198, disk end=976751937)
Bad relative sector?
