Recovery NTFS partition after HFS+ format
Sergio
#1 Post by Sergio »
USB HDD 500Gb.
I need to recovery NTFS partition after HFS+ format on iMac.
Step-by-Step and Data_Recovery_Examples give no results.
Pls help who know us. :(
Its log testdisk
Wed Mar 19 23:43:30 2014
OS: Darwin, kernel 13.1.0 (Darwin Kernel Version 13.1.0: Thu Jan 16 19:40:37 PST 2014; root:xnu-2422.9
Compiler: GCC 4.0
Compilation date: Jul 30 201314:08:37
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
Disk /dev/disk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/disk2 - 500 GB / 465 GiB - 976769024 sectors, sector size=512
Disk /dev/disk3 - 157 MB / 150 MiB - 307200 sectors (RO), sector size=512
Disk /dev/rdisk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/rdisk2 - 500 GB / 465 GiB - 976769024 sectors, sector size=512
Disk /dev/rdisk3 - 157 MB / 150 MiB - 307200 sectors (RO), sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/disk2 - 500 GB / 465 GiB - 976769024 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976769023 (expected 976769023)
hdr_lba_start=34
hdr_lba_end=976768990
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 40 409639 409600 [EFI System Partition]
2 P Mac HFS 409640 976506839 976097200 [perenoska]
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
EFI System 40 409639 409600 [EFI]
part_size 976097200
HFS+ blocksize=4096, 499 GB / 465 GiB
P EFI System 40 409639 409600 [EFI]
1 P EFI System 40 409639 409600 [EFI]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
gpt_change_part_type
Change partition type:
2 P MBR 409640 976506839 976097200 [perenoska]
2 P NTFS 409640 976506839 976097200 [perenoska]
ntfs_boot_sector
filesystem size 1
sectors_per_cluster 0
mft_lcn 0
mftmirr_lcn 0
clusters_per_mft_record 0
clusters_per_index_record 0
Status: Bad
Status: Bad
Sectors are identical.
rebuild_NTFS_BS
mft at 488179664, seq=1, main=0 res=1
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn 3
ntfs_find_mft: mftmirr_lcn 61022207
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
Re: Recovery NTFS partition after HFS+ format
Run TestDisk, Analyse, Quick Search and Deeper Search.
Your NTFS partition should be found using the NTFS backup boot sector.
Set this partition as *(bootable), the others as D(eleted). On next screen, choose Write, confirm, Quit
