Lost mdadm raid 10 array...
ris8
#1 Post by ris8 »
I used to have a 4 x 3T mdadm RAID 10 array
When moving to a new PC... something went wrong
Now back on the old PC I only see one disk with a partition:
sudo parted -l
Model: ATA WDC WD30EFRX-68A (scsi)
Disk /dev/sda: 3001GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Number  Start   End     Size    File system  Name        Flags
 1      1049kB  3001GB  3001GB               Linux RAID  raid
Disk /dev/sdc: 3001GB
Disk /dev/sdd: 3001GB
Disk /dev/sde: 3001GB
Supposedly the partition info should be identical across the disks... is there a way to copy it? Any better course of action?
For the disk that has the partition, both mdadm and testdisk report a bad superblock, what can I do?
Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63
Invalid RAID superblock
 1 P Linux Raid                  2048 5860533134 5860531087 [Linux RAID]
                P=Primary  D=Deleted
>[Quick Search]  [ Backup ]
                            Try to locate partition
Thanks
ris8
Re: Lost mdadm raid 10 array...
#2 Post by ris8 »
ran testdisk quick search on one of the other disks, log extract is below (whole log attached)
It does appear to find the 6T partition of the md disk. Isn't it odd, since the raid 10 is supposed to be striped? Anyhow I don't think I can do anything with it until I build the /dev/md back together, right?
This is a small part of the log (whole log below)
testdisk_sdd.zip
/dev/sdd scan
(7.78 KiB) Downloaded 870 times
Disk /dev/sdd - 3000 GB / 2794 GiB - WDC WD30EFRX-68AX9N0
Partition table type: EFI GPT
Analyse Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=5860533167
hdr_lba_alt=1 (expected 1)
hdr_lba_start=34
hdr_lba_table=5860533135
hdr_entries=128
hdr_entsz=128
Trying alternate GPT
[skipping most of the log...]
The harddisk (3000 GB / 2794 GiB) seems too small! (< 8251 GB / 7684 GiB)
     MS Data 1464927128 13185991575 11721064448
     ext4 blocksize=4096 Large file Sparse superblock Recover, 6001 GB / 5589 GiB
     MS Data 1464927440 13185991887 11721064448
     MS Data 1464927520 13185991967 11721064448
[...more...]
ris8
#3 Post by ris8 »
Sorry to keep replying to my post... not self-bumping...
I recovered my notes from backup on how I had assembled the raid (note to self... do not keep recovery info on the drive itself)
The disks were partitioned all in the same way (I had some notes that the partitions were not necessary to create the raid, but I am pretty sure I created them anyway)
sudo gdisk /dev/xxx
>p -> make sure ok
>n
>(enter a few times)
>fd00
>w
The raid and fs should have been created as follows:
sudo mdadm --create /dev/md1 --metadata=1.2 --verbose --level=10 --raid-devices=4 /dev/sdc1 /dev/sdg1 /dev/sde1 /dev/sdh1 –layout=f2 --chunk=1024 –name=share1
mkfs.ext4 -v -b 4096 -E stride=256,stripe-width=512 /dev/md1
This is the array in the mdadm.conf
ARRAY /dev/md1 level=raid10 num-devices=4 metadata=1.2 name=SERVER02:share1 UUID=89c4b606:01327383:c367db0f:8e93606f
I have seen posts suggesting to use the UUID to recreate the array (tried, does not work). Other posts suggest re-creating the array (did not try). But I think my first issue is to get back (at least) another partition before I can try to re-assemble the raid
Questions
1. Can I backup the partition from /dev/sda1 and restore it onto the other 3 disks?
1a. Is that a good idea?
2. Should I then re-run the same mdadm --create I did to originally create the disk?
Can you try pvdisplay -v and pvck -v ?
ris8
#5 Post by ris8 »
See below
sudo pvdisplay -v /dev/sd[acde]
    Using physical volume(s) on command line
  Failed to read physical volume "/dev/sda"
  Failed to read physical volume "/dev/sdc"
  Failed to read physical volume "/dev/sdd"
  Failed to read physical volume "/dev/sde"
sudo pvck -v /dev/sd[acde]
    Scanning /dev/sda
  Device /dev/sda not found (or ignored by filtering).
    Scanning /dev/sdc
  Device /dev/sdc not found (or ignored by filtering).
    Scanning /dev/sdd
  Device /dev/sdd not found (or ignored by filtering).
    Scanning /dev/sde
  Device /dev/sde not found (or ignored by filtering).
I don't have LVM on this machine or the array
ris8
#6 Post by ris8 »
I have seen a couple of pages mentioning the use of COW files to experiment with the disks. Essentially mounting a device which is the original disk, plus a file with the changes to it. So the changes are not written to disk
Examples are given here:
http://stackoverflow.com/questions/7582 ... ock-device
https://raid.wiki.kernel.org/index.php/ ... tware_RAID
Do they work? Would testdisk be able to copy the partition from /dev/sda to one of these fake disks? I am surprised they are not more widely cited in the forums
