I have been working on this drive for about a week in between work and having little success.  I have recovered a small portion of the files I need using GetDataBack.  Running Testdisk 6.14 in windows was taking an extraordinary amount of time (more than 48 hours).
The drive should be NTFS with GPT with a single partition.  I have the entire drive cloned using ddrescue from a LiveCD.  I also starting running Testdisk 6.13 from a LiveCD.  It works great from the LiveCDquick scan takes about 4 hours and deepscan a bit longer.  The only problem is either I am dumb and cannot track down where the testdisk.log is going or one is not being created. I have attached the log from windows the last time but it did not complete.
I have a few questions:
How do I specify a path to put the testdisk.log if using a livecd?  Ideally just in the root of my OS C:.
When running TestDisk in deeper scan it found multiple partitions.  The top partition listed seems to be the one it was specified as D MS Data and the full size of the disk.  Using list files it said disk appears to be damaged and it could not access.  Where should I be going from here?  Probably need the log to answer that I am guessing.
Is there a way to get TestDisk to run at the same rate in Windows vs using the LiveCD?
Thank you in advance for your assistance.  I really need to recover the data if at all possible.
Fri Mar 21 17:43:20 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=120031543296
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=244881408
Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00DC0B0, S/N:2020202057202d44435731433154333238383639, FW:80.00A80
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00SPEB0, S/N:2020202057202d44435734433045393931383833, FW:80.00A80
Disk /dev/sdc - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - KINGSTON SVP200S3120G, S/N:3035323042363237363230304432433920202020, FW:501ABBF0
Drive G: - 244 MB / 233 MiB - CHS 58 64 32, sector size=2048 - ATAPI iHAS324   Y, FW:BL1W
Disk /dev/sdb - 3000 GB / 2794 GiB - WDC WD30EZRX-00SPEB0
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
 2 P MS Data                   264192 5860532223 5860268032 [Basic data partition]
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
						Recovery of 3 TB WD in RAW
