Hello Everyone,
first of all take my appreciation for your great solution!
My story:two days ago a simple BSOD my windows xp was not able to boot anymore.
It was the first time for me to use linux,the knoppix.It took me a couple of while to study the system.
So with the ntfsfix i was able to get back my file(there were two partition on it.).
So i was happy to make a copy of the windows partition and keep in trust that the other
partition is in a safe place.........No,that wasn't
I made a fresh install with an old xp,i format the windows partition and then i tried to boot to the windows.
But something went wrong the win was not able to boot.
I attached the HDD with a usb external cable.Run the knoppix and than the testdisk.
My problem is that the second partition(with my documents) was lost,the test disk only sees the first(windows)
partition,when i made a restore with the photorec i getting back my old files from the windows partition.Getting mad..
The HDD is a western digital 320GB (WD3200BEVE) the test disk only see 57gb from it.
I don't know what happened with the other partition:i tried every kind of partition recovery but only sees 57gb part.
Get back files and then lost
Re: Get back files and then lost
So with after a while a found my partition.
It gone to a Host provided area,the size was exactly what the lost partition was.
With the hdat2 i restored the original size of the hdd,with the maximalized sector numbers.
I was told it will not makes data loss.
After a deep search i am still got a lot of Ext4 filesystem partitions,which is not correct
since the lost partition was ntfs.
I don't know what to do now
- sc
- sc.png (57.48 KiB) Viewed 3148 times
OS: Linux, kernel 3.13.4-pmagic (#2 SMP Sun Feb 23 12:17:46 CST 2014) i686
Compiler: GCC 4.8
Compilation date: 2013-07-30T16:08:31
ext2fs lib: 1.42.9, ntfs lib: libntfs-3g, reiserfs lib: 0.3.0.5, ewf lib: none
/dev/sda: size 625142448 sectors
/dev/sda: user_max 625142448 sectors
/dev/sda: native_max 625142448 sectors
/dev/sr0 is not an ATA disk
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200BEVE-00A0HT0, S/N:WD-WXB1A31L1001, FW:11.01A11
Disk /dev/sdb - 15 GB / 14 GiB - CHS 14793 64 32, sector size=512 - Kingston DataTraveler 2.0, FW:1.00
Disk /dev/sr0 - 652 MB / 622 MiB - 318815 sectors (RO), sector size=2048 - SD-R6252, S/N:84G4600402, FW:1A11
Disk /dev/sda - 320 GB / 298 GiB - WDC WD3200BEVE-00A0HT0
Partition table type: None
Analyse Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63
NTFS at 0/0/1
filesystem size 121320360
mftmirr_lcn 7582522
NTFS at 0/0/1
Info: size boot_sector 121320360, partition 625142448
P NTFS 0 0 1 38913 80 63 625142448
NTFS at 0/0/1
mftmirr_lcn 7582522
NTFS 0 0 1 7551 214 63 121320360
NTFS, blocksize=4096, 62 GB / 57 GiB
recover_EXT2: s_block_group_nr=0/104, s_mnt_count=24/30, s_blocks_per_group=32768, s_inodes_per_group=8144
recover_EXT2: s_blocks_count 3414016
recover_EXT2: part_size 27312128
ext4 7551 215 48 9251 241 37 27312128
ext4 blocksize=4096 Large file Sparse superblock Recover, 13 GB / 13 GiB
recover_EXT2: s_block_group_nr=0/104, s_mnt_count=5/30, s_blocks_per_group=32768, s_inodes_per_group=8144
ext4 9327 79 56 11027 105 45 27312128
P NTFS 0 0 1 7551 214 63 121320360
P ext4 7551 215 48 9251 241 37 27312128
P ext4 9327 79 56 11027 105 45 27312128
dir_partition inode=2
ext2fs_dir_iterate failed with error 1.
Write isn't available because the partition table type "None" has been selected.
NTFS at 0/0/1
mftmirr_lcn 7582522
NTFS at 0/1/1
heads/cylinder 240 (NTFS) != 255 (HD)
filesystem size 163840257
mftmirr_lcn 10240016
NTFS part_offset=32256, part_size=83886211584, sector_size=512
NTFS at 0/1/1
NTFS 0 1 1 10198 149 63 163840257
NTFS, blocksize=4096, 83 GB / 78 GiB
FAT12 at 38/9/44
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
no_of_cluster : 2586 (2 - 2587)
fat_length 8 calculated 8
FAT differs, FAT sectors=0-8/8
heads/cylinder 4 (FAT) != 255 (HD)
sect/track 17 (FAT) != 63 (HD)
FAT12 at 38/9/44
FAT12 38 9 44 39 83 55 20739 [NO NAME]
check_FAT: Unusual, only one FAT
FAT32 at 38/9/45
check_FAT: Bad number of entries in root dir
FAT16 at 38/9/48
check_FAT: Unusual number of reserved sectors 4 (FAT), should be 1.
Should be marked as FAT16
FAT1 : 4-115
FAT2 : 116-227
start_rootdir : 228
Data : 420-223683
sectors : 223684
cluster_size : 8
no_of_cluster : 27908 (2 - 27909)
fat_length 112 calculated 110
FAT differs, FAT sectors=0-16/112
heads/cylinder 7 (FAT) != 255 (HD)
sect/track 35 (FAT) != 63 (HD)
FAT16 at 38/9/48
FAT16 38 9 48 51 245 18 223684 [NO NAME]
FAT16, blocksize=4096, 114 MB / 109 MiB
FAT32 at 38/9/49
FAT32 at 213/184/53
Bad root_cluster
FAT12 at 213/184/54
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
FAT differs, FAT sectors=0-9/9
FAT12 at 213/184/54
FAT12 213 184 54 213 230 35 2880 [NO NAME]
recover_EXT2: s_block_group_nr=0/104, s_mnt_count=3/30, s_blocks_per_group=32768, s_inodes_per_group=8144
ext4 260 115 47 1960 141 36 27312128
Linux SWAP 2 298 150 36 298 150 51 16
SWAP2 version 0, pagesize=8192, 8192 B
Linux SWAP 2 298 150 44 379 40 28 1294320
SWAP2 version 1, pagesize=4096, 662 MB / 631 MiB
ext4 299 117 50 1999 143 39 27312128
ext4 299 135 12 1999 161 1 27312128
ext4 306 118 60 2006 144 49 27312128
ext4 307 133 42 2007 159 31 27312128
recover_EXT2: s_block_group_nr=0/104, s_mnt_count=8/30, s_blocks_per_group=32768, s_inodes_per_group=8144
ext4 599 233 42 2300 4 31 27312128
ext4 599 235 12 2300 6 1 27312128
ext4 599 237 22 2300 8 11 27312128
ext4 599 238 55 2300 9 44 27312128
ext4 599 240 25 2300 11 14 27312128
ext4 599 241 58 2300 12 47 27312128
ext4 599 243 28 2300 14 17 27312128
ext4 599 244 61 2300 15 50 27312128
ext4 599 246 31 2300 17 20 27312128
ext4 599 248 1 2300 18 53 27312128
ext4 599 249 34 2300 20 23 27312128
ext4 599 251 4 2300 21 56 27312128
ext4 599 252 37 2300 23 26 27312128
Record 0 has no FILE magic (0x6d0309)
ntfs_mst_post_read_fixup_warn: magic: 0x006d0309 size: 1024 usa_ofs: 115 usa_count: 102: Invalid argument
33610 122 32 35310 148 21 27312128
P ext4 33610 133 43 35310 159 32 27312128
P ext4 33625 182 37 35325 208 26 27312128
P ext4 33625 183 54 35325 209 43 27312128
P ext4 33625 185 24 35325 211 13 27312128
P ext4 33625 194 57 35325 220 46 27312128
P ext4 33625 197 52 35325 223 41 27312128
P ext4 33625 201 56 35325 227 45 27312128
dir_partition inode=5
NTFS found using backup sector, blocksize=4096, 62 GB / 57 GiB
5 dr-xr-xr-x 0 0 0 31-Mar-2014 18:00 .
5 dr-xr-xr-x 0 0 0 31-Mar-2014 18:00 ..
3291 dr-xr-xr-x 0 0 0 30-Mar-2014 12:46 $RECYCLE.BIN
3295 dr-xr-xr-x 0 0 0 31-Mar-2014 21:14 System Volume Information
28 dr-xr-xr-x 0 0 0 6-Jan-1980 21:28 WINDOWS
3294 dr-xr-xr-x 0 0 0 31-Mar-2014 13:26 Ãj mappa
2544 -r--r--r-- 0 0 4952 25-Apr-2003 11:00 Bootfont.bin
3253 -r--r--r-- 0 0 47580 25-Apr-2003 11:00 NTDETECT.COM
27 -r--r--r-- 0 0 41943040 6-Jan-1980 21:25 PAGEFILE.SYS
3281 -r--r--r-- 0 0 202 6-Jan-1980 21:28 boot.ini
3249 -r--r--r-- 0 0 234736 25-Apr-2003 11:00 ntldr
NTFS, blocksize=4096, 320 GB / 298 GiB
P NTFS 0 1 1 10198 149 63 163840257
dir_partition inode=0
P FAT12 38 9 44 39 83 55 20739 [NO NAME]
16 dr-xr-xr-x 0 0 2213317461 25-Jan-1941 01:35 ÿuèäöÿÿ.ëãÿ
1537 dr-xr-xr-x 0 0 274208255 20-Jan-1980 19:03 ìSVWh¬.
P FAT16 38 9 48 51 245 18 223684 [NO NAME]
32 -rwxr-xr-x 0 0 6619219 18-Mar-1980 00:03 S
116 -rwxr-xr-x 0 0 6226031 2-Mar-1980 00:03 t
50 -rwxr-xr-x 0 0 2883628 19-Feb-1980 00:02 S
92 -rwxr-xr-x 0 0 3145851 4-Feb-1980 00:02 0
52 -rwxr-xr-x 0 0 3670068 13-Jan-1980 00:01 F
69 -rwxr-xr-x 0 0 4325431 16-Jan-1980 00:02 1
77 -rwxr-xr-x 0 0 7602287 31-Dec-1979 00:03 B
101 -rwxr-xr-x 0 0 7667827 18-Feb-1980 00:01 o
104 -rwxr-xr-x 0 0 7077999 19-Mar-1980 00:03 m
76 -rwxr-xr-x 0 0 4784211 3-Feb-1980 00:01 d
57 -rwxr-xr-x 0 0 3276849 4-Feb-1980 00:01 D
49 -rwxr-xr-x 0 0 4259891 16-Jan-1980 00:01 -
112 -rwxr-xr-x 0 0 7471205 16-Mar-1980 00:03 0
103 -rwxr-xr-x 0 0 2883699 14-Mar-1980 00:03 .o
114 -rwxr-xr-x 0 0 6619251 5-Mar-1980 00:03 S
83 -rwxr-xr-x 0 0 4456521 12-Feb-1980 00:02 ,
49 -rwxr-xr-x 0 0 2949170 25-Jan-1980 00:02 \
51 -rwxr-xr-x 0 0 3145793 17-Jan-1980 00:01 4
101 -rwxr-xr-x 0 0 2097266 16-Mar-1980 00:03 E
115 -rwxr-xr-x 0 0 5439532 7-Mar-1980 00:03 M
44 -rwxr-xr-x 0 0 852017 12-Jan-1980 00:03 t
48 -rwxr-xr-x 0 0 4325446 27-Mar-1980 00:02
56 -rwxr-xr-x 0 0 2949169 20-Jan-1980 00:01 9
66 -rwxr-xr-x 0 0 3670082 23-Jan-1980 00:02 8
116 -rwxr-xr-x 0 0 7471215 15-Mar-1980 00:02 1
112 -rwxr-xr-x 0 0 6226035 5-Mar-1980 00:03 .t
76 -rwxr-xr-x 0 0 4784211 3-Feb-1980 00:01 2
72 -rwxr-xr-x 0 0 4390987 11-Jan-1980 00:00 S
48 -rwxr-xr-x 0 0 4522040 25-Jan-1980 00:02 R
56 -rwxr-xr-x 0 0 4522054 24-Jan-1980 00:01 4
125 -rwxr-xr-x 0 0 5439580 17-Jan-1980 00:01 -
83 -rwxr-xr-x 0 0 7602277 31-Dec-1979 00:03 t
101 -rwxr-xr-x 0 0 7536754 22-Mar-1980 00:03 t
101 -rwxr-xr-x 0 0 2883699 14-Mar-1980 00:03 i
68 -rwxr-xr-x 0 0 8061020 9-Feb-1980 00:02 ,
45 -rwxr-xr-x 0 0 3407924 18-Jan-1980 00:01 0
48 -rwxr-xr-x 0 0 3604549 1-Feb-1980 00:01 8
32 -rwxr-xr-x 0 0 7274573 18-Mar-1980 00:03 B
75 -rwxr-xr-x 0 0 6488169 12-Jan-1980 00:03 t
44 -rwxr-xr-x 0 0 852019 12-Jan-1980 00:03 k
100 -rwxr-xr-x 0 0 4391007 12-Mar-1980 00:03 .t
116 -rwxr-xr-x 0 0 2883628 21-Mar-1980 00:03 u
68 -rwxr-xr-x 0 0 8061020 9-Feb-1980 00:02 2
83 -rwxr-xr-x 0 0 6619252 12-Jan-1980 00:03 t
117 -rwxr-xr-x 0 0 7209061 17-Mar-1980 00:03 p
76 -rwxr-xr-x 0 0 4784211 3-Feb-1980 00:01 c
117 -rwxr-xr-x 0 0 7929972 4-Feb-1980 00:03 S
80 -rwxr-xr-x 0 0 7340129 27-Jan-1980 00:01 _
67 -rwxr-xr-x 0 0 2883666 11-Feb-1980 00:02 e
69 -rwxr-xr-x 0 0 2949172 24-Jan-1980 00:01 C
69 -rwxr-xr-x 0 0 3538989 6-Feb-1980 00:01 D
80 -rwxr-xr-x 0 0 7340129 28-Feb-1980 00:03 0
101 -rwxr-xr-x 0 0 5439583 13-Mar-1980 00:03 e
82 -rwxr-xr-x 0 0 4390956 3-Feb-1980 00:02 e
52 -rwxr-xr-x 0 0 4456493 5-Feb-1980 00:01 L
45 -rwxr-xr-x 0 0 3145782 5-Feb-1980 00:02 9
97 -rwxr-xr-x 0 0 6619248 16-Feb-1980 00:02 1
114 -rwxr-xr-x 0 0 5439583 5-Mar-1980 00:03 r
105 -rwxr-xr-x 0 0 7929972 18-Mar-1980 00:03 e
67 -rwxr-xr-x 0 0 5439564 12-Jan-1980 00:02 ,
68 -rwxr-xr-x 0 0 3211321 13-Jan-1980 00:01 I
48 -rwxr-xr-x 0 0 3342385 22-Jan-1980 00:01 2
101 -rwxr-xr-x 0 0 2097266 16-Mar-1980 00:03 A
83 -rwxr-xr-x 0 0 7209061 2-Mar-1980 00:03 S
44 -rwxr-xr-x 0 0 4980780 18-Mar-1980 00:03 s
83 -rwxr-xr-x 0 0 4456521 12-Feb-1980 00:02 e
32 -rwxr-xr-x 0 0 6619219 18-Mar-1980 00:03 E
110 -rwxr-xr-x 0 0 7274611 5-Mar-1980 00:02 n
44 -rwxr-xr-x 0 0 5832748 14-Mar-1980 00:03 r
68 -rwxr-xr-x 0 0 8061020 9-Feb-1980 00:02 e
101 -rwxr-xr-x 0 0 7536750 19-Feb-1980 00:01 B
111 -rwxr-xr-x 0 0 6226034 19-Mar-1980 00:03 o
105 -rwxr-xr-x 0 0 6815847 8-Feb-1980 00:01 2
123 -rwxr-xr-x 0 0 4587568 28-Feb-1980 00:02
52 -rwxr-xr-x 0 0 3211320 20-Jan-1980 00:01 B
55 -rwxr-xr-x 0 0 4325442 5-Feb-1980 00:01 -
115 -rwxr-xr-x 0 0 7471215 14-Mar-1980 00:03 8
95 -rwxr-xr-x 0 0 6225970 18-Mar-1980 00:03 ,
108 -rwxr-xr-x 0 0 655373 5-Mar-1980 00:03 T
70 -rwxr-xr-x 0 0 3735618 16-Jan-1980 00:03 H
49 -rwxr-xr-x 0 0 3670061 24-Jan-1980 00:01 0
66 -rwxr-xr-x 0 0 3211320 2-Feb-1980 00:01 8
114 -rwxr-xr-x 0 0 5242924 15-Mar-1980 00:03 }
95 -rwxr-xr-x 0 0 7602259 18-Jan-1980 00:03 a
59 -rwxr-xr-x 0 0 5046331 11-Jan-1980 00:00 o
44 -rwxr-xr-x 0 0 4980803 18-Feb-1980 00:02 i
45 -rwxr-xr-x 0 0 3735620 20-Jan-1980 00:02 S
54 -rwxr-xr-x 0 0 3211312 13-Jan-1980 00:02 1
115 -rwxr-xr-x 0 0 2097251 9-Mar-1980 00:02 3
84 -rwxr-xr-x 0 0 7340153 2-Mar-1980 00:01 I
105 -rwxr-xr-x 0 0 6488179 13-Feb-1980 00:02 1
95 -rwxr-xr-x 0 0 7274576 17-Jan-1980 00:03 .,
72 -rwxr-xr-x 0 0 4390987 11-Jan-1980 00:00 l
125 -rwxr-xr-x 0 0 5046364 17-Jan-1980 00:01 -
79 -rwxr-xr-x 0 0 3211359 9-Feb-1980 00:03 i
101 -rwxr-xr-x 0 0 655373 7-Mar-1980 00:03 _
115 -rwxr-xr-x 0 0 4784227 9-Mar-1980 00:02 }
97 -rwxr-xr-x 0 0 6619252 20-Mar-1980 00:02 O
76 -rwxr-xr-x 0 0 4784211 3-Feb-1980 00:01 ,
32 -rwxr-xr-x 0 0 3080265 3-Mar-1980 00:03 0
112 -rwxr-xr-x 0 0 2883685 25-Mar-1980 00:02 O
99 -rwxr-xr-x 0 0 4784160 19-Mar-1980 00:03 A
111 -rwxr-xr-x 0 0 6357100 16-Feb-1980 00:03 /
67 -rwxr-xr-x 0 0 2883666 11-Feb-1980 00:02 r
77 -rwxr-xr-x 0 0 7536745 28-Feb-1980 00:03 0
50 -rwxr-xr-x 0 0 5505119 2-Mar-1980 00:02 c
10 -rwxr-xr-x 0 0 4915272 14-Jan-1980 00:03 r
57 -rwxr-xr-x 0 0 3670064 2-Feb-1980 00:02 C
56 -rwxr-xr-x 0 0 4587576 13-Jan-1980 00:01 E
49 -rwxr-xr-x 0 0 6029437 24-Jan-1980 00:02 E
73 -rwxr-xr-x 0 0 6225999 3-Mar-1980 00:03 M
101 -rwxr-xr-x 0 0 2883628 20-Mar-1980 00:03 2
73 -rwxr-xr-x 0 0 6029380 19-Feb-1980 00:02 L
50 -rwxr-xr-x 0 0 3407917 17-Jan-1980 00:01 {
65 -rwxr-xr-x 0 0 4522032 19-Jan-1980 00:01 4
47 -rwxr-xr-x 0 0 2883663 9-Feb-1980 00:01 7
44 -rwxr-xr-x 0 0 5177388 5-Mar-1980 00:03 M
76 -rwxr-xr-x 0 0 4784211 3-Feb-1980 00:01 u
108 -rwxr-xr-x 0 0 7471201 15-Mar-1980 00:02 O
82 -rwxr-xr-x 0 0 4390956 3-Feb-1980 00:02 i
95 -rwxr-xr-x 0 0 7471188 19-Jan-1980 00:03 .,
72 -rwxr-xr-x 0 0 4390987 11-Jan-1980 00:00 i
79 -rwxr-xr-x 0 0 3342431 9-Feb-1980 00:03 i
44 -rwxr-xr-x 0 0 4718636 5-Mar-1980 00:03 _
73 -rwxr-xr-x 0 0 6029380 19-Feb-1980 00:02 i
44 -rwxr-xr-x 0 0 4784172 5-Mar-1980 00:03 M
83 -rwxr-xr-x 0 0 4456521 12-Feb-1980 00:02 n
73 -rwxr-xr-x 0 0 5177391 31-Dec-1979 00:03 E
97 -rwxr-xr-x 0 0 6881394 12-Mar-1980 00:03 ,
44 -rwxr-xr-x 0 0 4980803 18-Feb-1980 00:02 t
84 -rwxr-xr-x 0 0 6881394 2-Mar-1980 00:01 I
75 -rwxr-xr-x 0 0 5374019 8-Feb-1980 00:00 g
56 -rwxr-xr-x 0 0 3407941 16-Jan-1980 00:01 ,
70 -rwxr-xr-x 0 0 2949189 24-Jan-1980 00:01 -
92 -rwxr-xr-x 0 0 6881357 29-Mar-1980 00:01 6
95 -rwxr-xr-x 0 0 6225972 15-Feb-1980 00:02 s
44 -rwxr-xr-x 0 0 7274572 12-Jan-1980 00:03 O
92 -rwxr-xr-x 0 0 3145851 4-Feb-1980 00:02 w
44 -rwxr-xr-x 0 0 6881357 15-Feb-1980 00:01 B
73 -rwxr-xr-x 0 0 7340142 12-Jan-1980 00:01 s
68 -rwxr-xr-x 0 0 8061020 9-Feb-1980 00:02 u
79 -rwxr-xr-x 0 0 5046316 15-Jan-1980 00:02 B
105 -rwxr-xr-x 0 0 7929972 18-Mar-1980 00:03 i
105 -rwxr-xr-x 0 0 6750311 18-Mar-1980 00:02 O
95 -rwxr-xr-x 0 0 7667791 21-Jan-1980 00:03 .,
105 -rwxr-xr-x 0 0 6815847 8-Feb-1980 00:01 t
77 -rwxr-xr-x 0 0 7536745 12-Jan-1980 00:02 8
117 -rwxr-xr-x 0 0 7340148 15-Feb-1980 00:01 c
114 -rwxr-xr-x 0 0 6750313 20-Feb-1980 00:03 /
67 -rwxr-xr-x 0 0 2883666 11-Feb-1980 00:02 g
54 -rwxr-xr-x 0 0 5177439 2-Mar-1980 00:02 c
76 -rwxr-xr-x 0 0 7798895 12-Jan-1980 00:01 u
101 -rwxr-xr-x 0 0 3473440 22-Mar-1980 00:03
115 -rwxr-xr-x 0 0 655373 7-Mar-1980 00:03 0
53 -rwxr-xr-x 0 0 2097200 31-Dec-1979 00:03 }
84 -rwxr-xr-x 0 0 7602287 12-Jan-1980 00:03 d
54 -rwxr-xr-x 0 0 852025 20-Jan-1980 00:01 a
32 -rwxr-xr-x 0 0 3145781 5-Mar-1980 00:03 1
P FAT12 213 184 54 213 230 35 2880 [NO NAME]
P ext4 260 115 47 1960 141 36 27312128
P Linux SWAP 2 298 150 36 298 150 51 16
Support for this filesystem hasn't been enable during compilation.
P Linux SWAP 2 298 150 44 379 40 28 1294320
P ext4 7675 207 44 9375 233 33 27312128
P FAT12 7958 116 33 7958 162 14 2880 [NO NAME]
667 drwxr-xr-x 0 0 936433444 29-Jan-1981 03:32 s.¦jÁ
2410 -rwxr-xr-x 0 0 1761308591 3-Mar-1998 11:50 ;Ly¶½àl.ºÀ
2866 -rwxr-xr-x 0 0 1014306527 24-Jul-1997 17:53
2`Æ
2818 dr-xr-xr-x 0 0 3852520463 2-Jan-1995 05:19 ÃhñÏÑ.Á¨
2973 -r-xr-xr-x 0 0 3956125452 16-Jan-2006 00:58 wsÌ.w
2573 -r-xr-xr-x 0 0 3059967265 16-Jul-1952 23:52 䯼v¤`+.
3717 -r-xr-xr-x 0 0 1266315497 10-Nov-1983 01:05 ¶ù¹ç.4ÿ.dV
4077 -rwxr-xr-x 0 0 3970600049 29-Jan-1933 13:11 D)³µ. uÛ.#&
1048 -rwxr-xr-x 0 0 1062508698 30-Jan-2009 20:02 ÿilRdV.á±
2922 -rwxr-xr-x 0 0 1753167236 1-May-2036 07:36 &ëpÆéc.^Ì
3081 -rwxr-xr-x 0 0 3515945977 30-Jan-1996 04:44
Pðð.ÿ³
2803 -rwxr-xr-x 0 0 2839830854 2-Dec-1953 18:37 ö/©|sG2.Gõ
2110 -rwxr-xr-x 0 0 1314163512 11-Aug-1933 23:51 Ð>ÇÈì.Au
3247 drwxr-xr-x 0 0 3734664991 11-Dec-1911 04:23 ¹mO
Bo.¿
826 -rwxr-xr-x 0 0 1910503582 24-May-1958 03:36 Ù27;CÝ.ºÂ
2563 -r-xr-xr-x 0 0 3044236432 15-Jan-2029 00:25 pa)uGÝì.
33 -r-xr-xr-x 0 0 2605976345 16-Jun-1936 23:44 Êð½¹i# .P»Z
1640 -rwxr-xr-x 0 0 238389289 1-Apr-1989 02:15 _~÷.¨}=
2763 -rwxr-xr-x 0 0 3343053890 17-Jan-2019 03:27 ã·dè]B.à>
3457 -r-xr-xr-x 0 0 3479347698 17-Feb-2029 04:34 µ»jï;Oe.!Í
1682 -r-xr-xr-x 0 0 157007616 28-Feb-1933 02:31 F&[ ü.£¶Ç
831 -r-xr-xr-x 0 0 863170706 1-Mar-2036 03:45 Ht±b.
11 -r-xr-xr-x 0 0 2655287854 23-May-1945 04:47 PøUØïè.5Ù
2947 dr-xr-xr-x 0 0 3913112168 18-Dec-1929 22:26 Ø8>qø(=
1186 drwxr-xr-x 0 0 3557303409 8-Mar-1980 23:39 ÷@&Lö.4)i
3979 drwxr-xr-x 0 0 1301675037 25-Dec-1911 20:04 jô.¯a
459 -rwxr-xr-x 0 0 2531993523 29-Jun-1910 09:33 ¯µÓÝôp.E/
fat_copy dst=/root/Documents/;Ly¶½àl.ºÀ first_cluster=2410 (2441) size=1761308591
fat_copy dst=/root/Documents/wsÌ.w first_cluster=2973 (3004) size=3956125452
fat_copy dst=/root/Documents/Êð½¹i# .P»Z first_cluster=33 (64) size=2605976345
fat_copy dst=/root/Documents/¯µÓÝôp.E/ first_cluster=459 (490) size=2531993523
P ext4 8636 32 52 10336 58 41 27312128
P ext4 8760 199 55 10460 225 44 27312128
Buffer can't store more than 200 lines.
P ext4 299 117 50 1999 143 39 27312128
P ext4 299 135 12 1999 161 1 27312128
P ext4 306 118 60 2006 144 49 27312128
P ext4 307 133 42 2007 159 31 27312128
P ext4 353 30 27 2053 56 16 27312128
P ext4 353 30 29 2053 56 18 27312128
P ext4 385 159 60 2085 185 49 27312128
P ext4 385 159 62 2085 185 51 27312128
P ext4 599 233 42 2300 4 31 27312128
P ext4 599 235 12 2300 6 1 27312128
P ext4 599 237 22 2300 8 11 27312128
P ext4 599 238 55 2300 9 44 27312128
P ext4 599 240 25 2300 11 14 27312128
P ext4 599 241 58 2300 12 47 27312128
P ext4 599 243 28 2300 14 17 27312128
P ext4 599 244 61 2300 15 50 27312128
P ext4 599 246 31 2300 17 20 27312128
P ext4 599 248 1 2300 18 53 27312128
P ext4 599 249 34 2300 20 23 27312128
P ext4 599 251 4 2300 21 56 27312128
P ext4 599 252 37 2300 23 26 27312128
P ext4 599 254 7 2300 24 59 27312128
P ext4 600 0 40 2300 26 29 27312128
P ext4 600 2 10 2300 27 62 27312128
P ext4 600 3 43 2300 29 32 27312128
P ext4 600 5 13 2300 31 2 27312128
P ext4 600 6 46 2300 32 35 27312128
P ext4 600 8 40 2300 34 29 27312128
P ext4 600 10 10 2300 35 62 27312128
P ext4 600 11 43 2300 37 32 27312128
P ext4 600 13 13 2300 39 2 27312128
P ext4 600 14 46 2300 40 35 27312128
P ext4 600 16 48 2300 42 37 27312128
P ext4 600 18 18 2300 44 7 27312128
P ext4 600 19 51 2300 45 40 27312128
P ext4 600 21 21 2300 47 10 27312128
P ext4 600 22 54 2300 48 43 27312128
P ext4 600 24 24 2300 50 13 27312128
P ext4 600 25 57 2300 51 46 27312128
P ext4 600 27 27 2300 53 16 27312128
P ext4 600 28 60 2300 54 49 27312128
P ext4 600 30 30 2300 56 19 27312128
P ext4 600 31 63 2300 57 52 27312128
P ext4 600 33 33 2300 59 22 27312128
P ext4 600 35 3 2300 60 55 27312128
P ext4 600 36 36 2300 62 25 27312128
P ext4 600 38 6 2300 63 58 27312128
P ext4 600 39 39 2300 65 28 27312128
P ext4 600 41 9 2300 66 61 27312128
P ext4 600 42 42 2300 68 31 27312128
P ext4 646 116 12 2346 142 1 27312128
P ext4 646 116 14 2346 142 3 27312128
P ext4 678 245 45 2379 16 34 27312128
P ext4 678 245 47 2379 16 36 27312128
P ext4 711 120 15 2411 146 4 27312128
P ext4 711 120 17 2411 146 6 27312128
P ext4 743 249 48 2444 20 37 27312128
P ext4 743 249 50 2444 20 39 27312128
P ext4 776 124 18 2476 150 7 27312128
P ext4 776 124 20 2476 150 9 27312128
P ext4 799 56 41 2499 82 30 27312128
P ext4 799 64 9 2499 89 61 27312128
P ext4 841 213 52 2541 239 41 27312128
P ext4 841 216 47 2541 242 36 27312128
P ext4 850 15 29 2550 41 18 27312128
P ext4 850 16 38 2550 42 27 27312128
P ext4 850 18 8 2550 43 60 27312128
P ext4 850 19 41 2550 45 30 27312128
P ext4 850 21 51 2550 47 40 27312128
P ext4 850 23 21 2550 49 10 27312128
P ext4 850 24 54 2550 50 43 27312128
P ext4 850 26 24 2550 52 13 27312128
P ext4 850 27 57 2550 53 46 27312128
P ext4 850 29 27 2550 55 16 27312128
P ext4 850 30 60 2550 56 49 27312128
P ext4 850 32 30 2550 58 19 27312128
P ext4 850 33 63 2550 59 52 27312128
P ext4 850 35 33 2550 61 22 27312128
P ext4 850 37 3 2550 62 55 27312128
P ext4 850 38 36 2550 64 25 27312128
P ext4 850 40 6 2550 65 58 27312128
P ext4 850 41 39 2550 67 28 27312128
P ext4 850 43 9 2550 68 61 27312128
P ext4 850 44 42 2550 70 31 27312128
P ext4 850 46 36 2550 72 25 27312128
P ext4 850 48 6 2550 73 58 27312128
P ext4 850 49 39 2550 75 28 27312128
P ext4 850 51 33 2550 77 22 27312128
P ext4 850 53 3 2550 78 55 27312128
P ext4 850 54 36 2550 80 25 27312128
P ext4 850 56 38 2550 82 27 27312128
P ext4 850 59 17 2550 85 6 27312128
P ext4 850 60 50 2550 86 39 27312128
P ext4 850 62 20 2550 88 9 27312128
P ext4 850 63 53 2550 89 42 27312128
P ext4 850 65 23 2550 91 12 27312128
P ext4 850 66 56 2550 92 45 27312128
P ext4 850 68 26 2550 94 15 27312128
P ext4 850 69 59 2550 95 48 27312128
P ext4 850 71 29 2550 97 18 27312128
P ext4 850 72 62 2550 98 51 27312128
P ext4 850 74 32 2550 100 21 27312128
P ext4 850 76 2 2550 101 54 27312128
P ext4 850 77 35 2550 103 24 27312128
P ext4 850 79 5 2550 104 57 27312128
P ext4 850 80 38 2550 106 27 27312128
P ext4 850 82 8 2550 107 60 27312128
P ext4 850 83 41 2550 109 30 27312128
P ext4 850 85 11 2550 110 63 27312128
P ext4 850 86 44 2550 112 33 27312128
P ext4 850 88 14 2550 114 3 27312128
P ext4 850 89 47 2550 115 36 27312128
P ext4 850 91 17 2550 117 6 27312128
P ext4 850 92 50 2550 118 39 27312128
P ext4 850 94 20 2550 120 9 27312128
P ext4 850 95 53 2550 121 42 27312128
P ext4 850 97 23 2550 123 12 27312128
P ext4 850 98 56 2550 124 45 27312128
P ext4 850 100 26 2550 126 15 27312128
P ext4 850 101 59 2550 127 48 27312128
P ext4 850 103 61 2550 129 50 27312128
P ext4 850 105 31 2550 131 20 27312128
P ext4 850 107 1 2550 132 53 27312128
P ext4 850 108 34 2550 134 23 27312128
P ext4 850 110 4 2550 135 56 27312128
P ext4 850 111 37 2550 137 26 27312128
P ext4 851 254 35 2552 25 24 27312128
P ext4 852 0 60 2552 26 49 27312128
P ext4 852 2 22 2552 28 11 27312128
P ext4 852 3 47 2552 29 36 27312128
P ext4 852 5 9 2552 30 61 27312128
P ext4 852 6 34 2552 32 23 27312128
P ext4 852 7 59 2552 33 48 27312128
P ext4 852 9 21 2552 35 10 27312128
P ext4 852 10 46 2552 36 35 27312128
P ext4 852 12 8 2552 37 60 27312128
P ext4 852 13 33 2552 39 22 27312128
P ext4 852 14 58 2552 40 47 27312128
P ext4 852 16 20 2552 42 9 27312128
P ext4 852 17 45 2552 43 34 27312128
P ext4 852 19 7 2552 44 59 27312128
P ext4 852 21 1 2552 46 53 27312128
P ext4 852 22 34 2552 48 23 27312128
P ext4 852 24 4 2552 49 56 27312128
P ext4 852 25 37 2552 51 26 27312128
P ext4 852 27 7 2552 52 59 27312128
P ext4 852 28 40 2552 54 29 27312128
P ext4 852 30 10 2552 55 62 27312128
P ext4 860 169 5 2560 194 57 27312128
P ext4 860 170 62 2560 196 51 27312128
P ext4 860 172 32 2560 198 21 27312128
P ext4 860 174 26 2560 200 15 27312128
P ext4 860 175 59 2560 201 48 27312128
P ext4 860 177 45 2560 203 34 27312128
P ext4 860 179 7 2560 204 59 27312128
P ext4 860 180 56 2560 206 45 27312128
P ext4 860 182 18 2560 208 7 27312128
P ext4 860 184 12 2560 210 1 27312128
P ext4 860 185 45 2560 211 34 27312128
P ext4 860 187 31 2560 213 20 27312128
P ext4 860 188 56 2560 214 45 27312128
P ext4 860 190 58 2560 216 47 27312128
P ext4 860 192 28 2560 218 17 27312128
P ext4 860 194 14 2560 220 3 27312128
P ext4 860 195 39 2560 221 28 27312128
P ext4 860 197 33 2560 223 22 27312128
P ext4 860 198 58 2560 224 47 27312128
P ext4 1090 162 32 2790 188 21 27312128
P ext4 1090 163 49 2790 189 38 27312128
P ext4 1090 165 19 2790 191 8 27312128
P ext4 1093 110 33 2793 136 22 27312128
P ext4 1093 111 58 2793 137 47 27312128
P ext4 1093 113 20 2793 139 9 27312128
P ext4 1093 114 45 2793 140 34 27312128
P ext4 1093 116 7 2793 141 59 27312128
P ext4 1093 117 32 2793 143 21 27312128
P ext4 1093 118 57 2793 144 46 27312128
P ext4 1093 120 19 2793 146 8 27312128
P ext4 1093 122 53 2793 148 42 27312128
P ext4 1093 124 23 2793 150 12 27312128
P ext4 1093 125 48 2793 151 37 27312128
P ext4 1093 127 10 2793 152 62 27312128
P ext4 1093 128 35 2793 154 24 27312128
P ext4 1093 129 60 2793 155 49 27312128
P ext4 1093 131 54 2793 157 43 27312128
P ext4 1093 133 16 2793 159 5 27312128
P ext4 1093 134 41 2793 160 30 27312128
P ext4 1093 136 19 2793 162 8 27312128
P ext4 1093 138 21 2793 164 10 27312128
P ext4 1093 139 46 2793 165 35 27312128
P ext4 1093 141 8 2793 166 60 27312128
