I'm currently attempting to use Testdisk to recover some deleted files from an ext3 partition.
Is there a way to specify a completely separate device / mount point for the destination? I obviously don't want to overwrite any 'freespace' that might be used by current deleted files.
Any pointed would be much appreciated!
Linux - Copy deleted files to *another* mount point.
Re: Linux - Copy deleted files to *another* mount point.
You can choose the destination of your choice, so yes. The destination must be mounted before you try to select it.
