SAGEM DTR67250
daystrom
Re: SAGEM DTR67250
#11 Post by daystrom »
Do you have a link to the documentation on how to do a dump?
I'm not sure how its done. Thanks
daystrom
Re: SAGEM DTR67250
#12 Post by daystrom »
Hex Dump of SAGEM sector 0
Hope this helps.
remy
Re: SAGEM DTR67250
#13 Post by remy »
It's very curious. Your first sector does have a signature, but it's 0xAA55 instead of 0x55AA.
It may be because your enclosure use inversion in byte order.
At 0x1Bh, there's a partition begin :
80 (bootable)
0EFFFF : begin of partition (old MBR before 32GB limit)
0B : FAT32
0EFFFF : end (like above)
E0A3261B : number of sector before partition (usaly read last-to-first : 0x1B26A3E0) but that make no sense there
8675D101 : size of the partition (usaly read last-to-first : 0x01D17586) but... no sense too.
It looks like your MBR was written with ytorder inversion (big-endian) instead of the way it should be (little-endian).
How to deal with that ? I don't know... Please provide the same hexadecimal dump inside the enclosure, to see if there's a difference...
I'll ask Christophe if he has an idea how to solve this.
daystrom
Re: SAGEM DTR67250
#14 Post by daystrom »
not sure what is meant by "inside the enclosure", so I'll give you sectors 1 to 256
SAGEM sector 1
SAGEM sector 1
SAGEM sector 2
SAGEM sector 2
Sector 3 is filled with 0x01
So has sector 4, all the way to sector 255. Sector 256 has data.
SAGEM sector 256
SAGEM sector 256
remy
Re: SAGEM DTR67250
#15 Post by remy »
sector 256 also has a signature AA55 instead of 55AA.
I've asked to Christophe, who told me that you'll have to duplicate your disk with dd tool (under gnu/linux) using option conv=swab.
Do you have a linux working and/or some knowledge about it ? If you try alone, be really carrefull with dd to copy source on destination, and not destination over the source... :cry:
I'll help you, but that's just to know what kind of help you'll need.
daystrom
Re: SAGEM DTR67250
#16 Post by daystrom »
I dont have linux. I did make an image of the HD -- not too confident about the software, though, because half way through the copy, drive 0 disappeared from the list of HDs. But the operation did complete, and I've used the software before on other drives successfully.
I did a search for HDD1_AV1 and found a few links, notably
http://www.generationcable.net/gcmag_faq_tv.php, and http://wiki.lagamel.fr/doku.php?id=sage ... :disquedur
Phil78 on http://www.tvnt.net/forum/sagem-pvr-624 ... 3-135.html, suggests that sagem is using an Amiga file system.
I used iRecover, and although it found no files it did show that it had a 15Gb partition. Which seems to tally with what they say.
I've been assured that http://www.ezvan.fr/public/logiciels/papa/DVBT2MPG.ZIP will read sagem drives, but with my drive a message pops up stating that it cant find the DVBT stream on any devices.
I considered emailing him but his website is in French, I noticed, Remy, that your signature is in French. So, perhaps if you were to email him this may yield quick results.
remy
Re: SAGEM DTR67250
#17 Post by remy »
I can try to contact him, but that won't be easy to explain a problem without having the disk and made a diagnose of it by myself. And the post you linked is 5 years old :/
In my opinion it may be esaier to drive you with some basic linux commands, so that you will be able to duplicate you disk using conversion to put bytes in a readable order and recover your data then with testdisk.
daystrom
Re: SAGEM DTR67250
#18 Post by daystrom »
is ubuntu ok, or does it have red hat?
I have a spare HD I can install the OS on.
Is there any other software I'll need to install?
remy
Re: SAGEM DTR67250
#19 Post by remy »
Ubuntu, perfect.
Installation on spare HD : perfect (you'll have persistance of data, and will work quicker than a liveCD)
Other tools to install :
download testdisk 6.14 for linux after install, uncompress, and copy testdisk_static in your personal folder.
Then, connect your sagem, your disk for duplication, and give feedback for :
sudo sfdisk -luS
daystrom
Re: SAGEM DTR67250
#20 Post by daystrom »
The sfdisk shows
Disk /dev/sda: 30401 cylinders, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 0 does not have an MSDOS signature
/dev/sda: unrecognised partition table type
No partitions found
