External HDD formatted in error Boot Camp install gone wrong
michaelvsprague
Partitions gone missing due to user error in Boot Camp
I have a problem, stemming from a bad decision I made based on my own ignorance.
I need help recovering the File Headers, which I hope will allow me to recover the two partitions and all the files in those partitions. One was a large (990 GB) Macintosh Journaled partition (Crime Scene), not case sensitive, and the other was formatted for Windows by Disk Utility under Mac OS X Mavericks 10.9.1 The Windows partition (La Cie Share) is a 10 GB volume.
In preparing to partition my internal SSD for boot camp, I selected what I thought was the volume on my external disk set aside for Windows. (You may be aware, Boot Camp requires a Windows disk image to install Windows from, and the new acs have no optical drive, disallowing my use of a physical CD/DVD.) So, functioning properly, Boot Camp formatted the drive, not the volume.
Now I have a 1 TB drive that is ready for files, but is unaware of the many files it currently has on it, as the pointers to the two partitions, and the folder structures in those partitions, are not easily found any more.
So, BACKUP, unfortunately, was the NEXT item on my to do list, and so - I learn the BACKUP NOW, EARLY AND OFTEN rule one more time. In theory, next time I am about to be a moron I will remember that. However,
In searching for help, and asking in several fora where I thought I might find help to allow me to avoid spending thousands of dollars I do not have to recover the header files for this drive, I was given a link to a page (http://perrohunter.com/repair-a-mac-os- ... ion-table/) that seemed to offer some hope of a DIY solution.
In following this pages' directions, I found that I was able to find the information referenced, but when I got to the step, following Quit out of testisk and enter data about start addresses and size info, I received a “BAD SIZE” error message, and a lack of cooperation from the pdisk app he references.
This was all a while ago, when this first happened. Life gets in the way, and I have had this disk sitting in a box for several months now. I did, at that time make a trip to an old friends place where I recovered ~675 GB in files from the formatted disk to another 1 TB disk I had, all aggregated into folders named for file type and numbered... presumably by order of recovery. I was amazed by the number of files I had never seen before that were found on this disk by that app (might have been Data Rescue 3, but I am not certain atm, and it is of secondary importance).
Let me emphasize – I have NOT written any files to the disk I need help with. I interrupted the Boot Camp process as soon as I saw that Mac disk disappear from the desktop, disconnected it and cursed a variety of gods and demons. No daemons. But I digress -
Apparently, since Perrohunter's page was created, there have been advances in testdisk, as he says you cannot write the disk from within testdisk, browsing here I have seen several “Choose the write out”(ish) “option” as a direction, so I guess that is now functional. So, cool beans.
Also, although the App Store did not seem to be aware of it's existence, I updated my X11 from a page I found on the Apple site, so am hoping that might help with this. I am now spending a little more time looking at the cgsecurity site forums as my copy of testdisk works away, doing a deeper analysis of the disk in question. In looking, it occurs to me that, though I registered, I never posted about this.
If you have actually read to this point, thank you for dealing with this wall of text. I hope this makes sense, and am hopeful that my situation, other than the stupidity that got me here, of course, is not hopeless.
Any ideas?
System in question:
Macbook Pro now on OS X 10.9.2
core I5, 16 GB RAM
LA Cie 1 TB, 5400 RPM
2 partitions,
990 GB named "Crime Scene" (Mac OS Extended (journaled) NOT case sensitive)
10 GB named La Cie Share (MS-DOS (FAT))
If I can provide any other information, please ask. Thank you for your time. I promise to be better about backups in future.
Any ideas?
System in question:
core I5, 16 GB RAM
2 partitions,
Re: External HDD formatted in error Boot Camp install gone w
Can you post the results from TestDisk, Analyse, Quick Search and if a partition is still missing, "Deeper Search" too ?
michaelvsprague
Yes. This will take a little while. I am running a Deeper analysis atm. It is at ~57% after about 36 hours.
When it finishes, I shall follow up. It will be at least, I estimate, 24 hours from now before I am able to comply.
Thank you very much for your time and interest.
michaelvsprague
So, it is not yet finished with it's deep analysis, but I thought you might be able to make a suggestion based on this info. It is nor about 87% of the way through this process, ans I expect it will likely finish tonight while I am in my GIS class. I am looking forward to hearing what input you may have, and I'll post the full log once the scan is fully complete - or not, since my initial partial post attempt exceeded the post character number limit by 330k+ char, and I expect once the analysis finishes it will be even larger. I will pick tidbits from the final log to send, I imagine, unless you can advise on what to provide.
Thanks.
In the mean time, here is the log up to a moment ago edited down to under 60k char:
Sun Apr 20 11:35:14 2014
OS: Darwin, kernel 13.1.0 (Darwin Kernel Version 13.1.0: Thu Jan 16 19:40:37 PST 2014; root:xnu-2422.9
Compiler: GCC 4.0
Compilation date: 2013-07-30T14:08:37
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
Disk /dev/disk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/disk1 - 1032 MB / 985 MiB - 2017280 sectors (RO), sector size=512
Disk /dev/disk2 - 1000 GB / 931 GiB - 1953525168 sectors (RO), sector size=512
Disk /dev/disk3 - 523 MB / 498 MiB - 1021696 sectors (RO), sector size=512
Disk /dev/rdisk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/rdisk1 - 1032 MB / 985 MiB - 2017280 sectors (RO), sector size=512
Disk /dev/rdisk2 - 1000 GB / 931 GiB - 1953525168 sectors (RO), sector size=512
Disk /dev/rdisk3 - 523 MB / 498 MiB - 1021696 sectors (RO), sector size=512
Media is opened in read-only.
Disk /dev/rdisk2 - 1000 GB / 931 GiB (RO)
Analyse Disk /dev/rdisk2 - 1000 GB / 931 GiB - 1953525168 sectors (RO)
BAD_RS LBA=2 1339
FAT32 at 2/0/1
Info: size boot_sector 1953525166, partition 1953525166
FAT1 : 32-238441
FAT2 : 238442-476851
start_rootdir : 476852 root cluster : 2
Data : 476852-1953525107
sectors : 1953525166
cluster_size : 64
no_of_cluster : 30516379 (2 - 30516380)
fat_length 238410 calculated 238410
heads/cylinder 255 (FAT) != 1 (HD)
sect/track 32 (FAT) != 1 (HD)
get_geometry_from_list_part_aux head=1 nbr=2
Warning: number of heads/cylinder mismatches 255 (FAT) != 1 (HD)
Warning: number of sectors per track mismatches 32 (FAT) != 1 (HD)
1 * FAT32 2 1953525167 1953525166 [WININSTALL]
FAT32 at 2/0/1
FAT1 : 32-238441
cluster_size : 64
FAT32 at 2/0/1
FAT32 LBA 2 1953525167 1953525166 [WININSTALL]
FAT32, blocksize=32768, 1000 GB / 931 GiB
* FAT32 LBA 2 1953525167 1953525166 [WININSTALL]
dir_partition inode=0
FAT: cluster=2(0x2), pos=476854
4 -rwxr-xr-x 0 0 4096 12-Jan-2014 08:41 ._.Trashes
X 3 drwxr-xr-x 0 0 0 12-Jan-2014 08:41 _RASHE~1.BXJ
3 drwxr-xr-x 0 0 0 12-Jan-2014 08:41 .Trashes
5 drwxr-xr-x 0 0 0 12-Jan-2014 08:41 .Spotlight-V100
265 drwxr-xr-x 0 0 0 20-Apr-2014 08:45 .fseventsd
X 204 -rwxr-xr-x 0 0 4096 16-Jan-2014 07:47 _DAT6E~1.000
0 -rwxr-xr-x 0 0 0 16-Jan-2014 07:47 .com.apple.timemachine.donotpresent
204 -rwxr-xr-x 0 0 4096 16-Jan-2014 07:47 ._.com.apple.timemachine.donotpresent
1 * FAT32 LBA 2 1953525167 1953525166 [WININSTALL]
FAT32 at 2/0/1
FAT1 : 32-238441
cluster_size : 64
FAT32 at 2/0/1
FAT32 at 8/0/1
FAT1 : 32-238441
cluster_size : 64
FAT32 at 8/0/1
FAT32 LBA 8 1953525173 1953525166 [WININSTALL]
This partition ends after the disk limits. (start=8, size=1953525166, end=1953525173, disk end=1953525168)
BAD_RS LBA=1711969843 863
FAT16 >32M 1711969843 5625475325 3913505483
This partition ends after the disk limits. (start=1711969843, size=3913505483, end=1330508029, disk end=1953525168)
HFS+ magic value at 19535355/0/1
part_size 1933989808
HFS 19535355 1953525162 1933989808
HFS+ blocksize=4096, 990 GB / 922 GiB
HFS+ magic value at 19535357/0/1
HFS+ magic value at 19594492/0/1
HFS 19594492 1953584299 1933989808
This partition ends after the disk limits. (start=19594492, size=1933989808, end=1953584299, disk end=1953525168)
HFS+ magic value at 19594494/0/1
HFS+ magic value at 19594653/0/1
HFS 19594653 1953584460 1933989808
This partition ends after the disk limits. (start=19594653, size=1933989808, end=1953584460, disk end=1953525168)
HFS+ magic value at 19594655/0/1
HFS+ magic value at 19594742/0/1
HFS 19594742 1953584549 1933989808
This partition ends after the disk limits. (start=19594742, size=1933989808, end=1953584549, disk end=1953525168)
HFS+ magic value at 19594744/0/1
HFS+ magic value at 19594959/0/1
HFS 19594959 1953584766 1933989808
This partition ends after the disk limits. (start=19594959, size=1933989808, end=1953584766, disk end=1953525168)
HFS+ magic value at 19594961/0/1
HFS+ magic value at 19595496/0/1
HFS 19595496 1953585303 1933989808
This partition ends after the disk limits. (start=19595496, size=1933989808, end=1953585303, disk end=1953525168)
HFS+ magic value at 19595498/0/1
HFS+ magic value at 19595657/0/1
HFS 19595657 1953585464 1933989808
This partition ends after the disk limits. (start=19595657, size=1933989808, end=1953585464, disk end=1953525168)
HFS+ magic value at 19595659/0/1
HFS+ magic value at 19595786/0/1
HFS 19595786 1953585593 1933989808
This partition ends after the disk limits. (start=19595786, size=1933989808, end=1953585593, disk end=1953525168)
HFS+ magic value at 19595788/0/1
HFS+ magic value at 19595995/0/1
HFS 19595995 1953585802 1933989808
This partition ends after the disk limits. (start=19595995, size=1933989808, end=1953585802, disk end=1953525168)
HFS+ magic value at 19595997/0/1
HFS+ magic value at 19596236/0/1
HFS 19596236 1953586043 1933989808
This partition ends after the disk limits. (start=19596236, size=1933989808, end=1953586043, disk end=1953525168)
HFS+ magic value at 19596238/0/1
HFS+ magic value at 19596461/0/1
HFS 19596461 1953586268 1933989808
This partition ends after the disk limits. (start=19596461, size=1933989808, end=1953586268, disk end=1953525168)
HFS+ magic value at 19596463/0/1
HFS+ magic value at 19596566/0/1
HFS 19596566 1953586373 1933989808
This partition ends after the disk limits. (start=19596566, size=1933989808, end=1953586373, disk end=1953525168)
HFS+ magic value at 19596568/0/1
HFS+ magic value at 19596631/0/1
HFS 19596631 1953586438 1933989808
This partition ends after the disk limits. (start=19596631, size=1933989808, end=1953586438, disk end=1953525168)
HFS+ magic value at 19596633/0/1
HFS+ magic value at 19597032/0/1
HFS 19597032 1953586839 1933989808
This partition ends after the disk limits. (start=19597032, size=1933989808, end=1953586839, disk end=1953525168)
HFS+ magic value at 19597034/0/1
HFS+ magic value at 19597833/0/1
HFS 19597833 1953587640 1933989808
This partition ends after the disk limits. (start=19597833, size=1933989808, end=1953587640, disk end=1953525168)
HFS+ magic value at 19597835/0/1
HFS+ magic value at 19597994/0/1
HFS 19597994 1953587801 1933989808
This partition ends after the disk limits. (start=19597994, size=1933989808, end=1953587801, disk end=1953525168)
HFS+ magic value at 19597996/0/1
HFS+ magic value at 19598107/0/1
HFS 19598107 1953587914 1933989808
This partition ends after the disk limits. (start=19598107, size=1933989808, end=1953587914, disk end=1953525168)
HFS+ magic value at 19598109/0/1
HFS+ magic value at 19598196/0/1
HFS 19598196 1953588003 1933989808
This partition ends after the disk limits. (start=19598196, size=1933989808, end=1953588003, disk end=1953525168)
HFS+ magic value at 19598198/0/1
HFS+ magic value at 19598317/0/1
HFS 19598317 1953588124 1933989808
This partition ends after the disk limits. (start=19598317, size=1933989808, end=1953588124, disk end=1953525168)
HFS+ magic value at 19598319/0/1
HFS+ magic value at 19598510/0/1
HFS 19598510 1953588317 1933989808
This partition ends after the disk limits. (start=19598510, size=1933989808, end=1953588317, disk end=1953525168)
HFS+ magic value at 19598512/0/1
HFS+ magic value at 19598631/0/1
HFS 19598631 1953588438 1933989808
This partition ends after the disk limits. (start=19598631, size=1933989808, end=1953588438, disk end=1953525168)
HFS+ magic value at 19598633/0/1
HFS+ magic value at 19599016/0/1
HFS 19599016 1953588823 1933989808
This partition ends after the disk limits. (start=19599016, size=1933989808, end=1953588823, disk end=1953525168)
HFS+ magic value at 19599018/0/1
HFS+ magic value at 19599305/0/1
HFS 19599305 1953589112 1933989808
This partition ends after the disk limits. (start=19599305, size=1933989808, end=1953589112, disk end=1953525168)
HFS+ magic value at 19599307/0/1
HFS+ magic value at 19599506/0/1
HFS 19599506 1953589313 1933989808
This partition ends after the disk limits. (start=19599506, size=1933989808, end=1953589313, disk end=1953525168)
HFS+ magic value at 19599508/0/1
HFS+ magic value at 19599595/0/1
HFS 19599595 1953589402 1933989808
This partition ends after the disk limits. (start=19599595, size=1933989808, end=1953589402, disk end=1953525168)
HFS+ magic value at 19599597/0/1
HFS+ magic value at 19599812/0/1
HFS 19599812 1953589619 1933989808
This partition ends after the disk limits. (start=19599812, size=1933989808, end=1953589619, disk end=1953525168)
HFS+ magic value at 19599814/0/1
HFS+ magic value at 19600021/0/1
HFS 19600021 1953589828 1933989808
This partition ends after the disk limits. (start=19600021, size=1933989808, end=1953589828, disk end=1953525168)
HFS+ magic value at 19600023/0/1
HFS+ magic value at 19600214/0/1
HFS 19600214 1953590021 1933989808
This partition ends after the disk limits. (start=19600214, size=1933989808, end=1953590021, disk end=1953525168)
HFS+ magic value at 19600216/0/1
HFS+ magic value at 19600559/0/1
HFS 19600559 1953590366 1933989808
This partition ends after the disk limits. (start=19600559, size=1933989808, end=1953590366, disk end=1953525168)
HFS+ magic value at 19600561/0/1
HFS+ magic value at 19600672/0/1
HFS 19600672 1953590479 1933989808
This partition ends after the disk limits. (start=19600672, size=1933989808, end=1953590479, disk end=1953525168)
HFS+ magic value at 19600674/0/1
HFS+ magic value at 19600873/0/1
HFS 19600873 1953590680 1933989808
This partition ends after the disk limits. (start=19600873, size=1933989808, end=1953590680, disk end=1953525168)
HFS+ magic value at 19600875/0/1
HFS+ magic value at 19601114/0/1
HFS 19601114 1953590921 1933989808
This partition ends after the disk limits. (start=19601114, size=1933989808, end=1953590921, disk end=1953525168)
HFS+ magic value at 19601116/0/1
HFS+ magic value at 19601251/0/1
HFS 19601251 1953591058 1933989808
This partition ends after the disk limits. (start=19601251, size=1933989808, end=1953591058, disk end=1953525168)
HFS+ magic value at 19601253/0/1
HFS+ magic value at 19601420/0/1
HFS 19601420 1953591227 1933989808
This partition ends after the disk limits. (start=19601420, size=1933989808, end=1953591227, disk end=1953525168)
HFS+ magic value at 19601422/0/1
HFS+ magic value at 19601645/0/1
HFS 19601645 1953591452 1933989808
This partition ends after the disk limits. (start=19601645, size=1933989808, end=1953591452, disk end=1953525168)
HFS+ magic value at 19601647/0/1
HFS+ magic value at 19601886/0/1
HFS 19601886 1953591693 1933989808
This partition ends after the disk limits. (start=19601886, size=1933989808, end=1953591693, disk end=1953525168)
HFS+ magic value at 19601888/0/1
HFS+ magic value at 19602207/0/1
HFS 19602207 1953592014 1933989808
This partition ends after the disk limits. (start=19602207, size=1933989808, end=1953592014, disk end=1953525168)
HFS+ magic value at 19602209/0/1
HFS+ magic value at 19602504/0/1
HFS 19602504 1953592311 1933989808
This partition ends after the disk limits. (start=19602504, size=1933989808, end=1953592311, disk end=1953525168)
HFS+ magic value at 19602506/0/1
HFS+ magic value at 19602753/0/1
HFS 19602753 1953592560 1933989808
This partition ends after the disk limits. (start=19602753, size=1933989808, end=1953592560, disk end=1953525168)
HFS+ magic value at 19602755/0/1
HFS+ magic value at 19602842/0/1
HFS 19602842 1953592649 1933989808
This partition ends after the disk limits. (start=19602842, size=1933989808, end=1953592649, disk end=1953525168)
HFS+ magic value at 19602844/0/1
HFS+ magic value at 19603107/0/1
HFS 19603107 1953592914 1933989808
This partition ends after the disk limits. (start=19603107, size=1933989808, end=1953592914, disk end=1953525168)
HFS+ magic value at 19603109/0/1
HFS+ magic value at 19603460/0/1
HFS 19603460 1953593267 1933989808
This partition ends after the disk limits. (start=19603460, size=1933989808, end=1953593267, disk end=1953525168)
HFS+ magic value at 19603462/0/1
HFS+ magic value at 19603621/0/1
HFS 19603621 1953593428 1933989808
This partition ends after the disk limits. (start=19603621, size=1933989808, end=1953593428, disk end=1953525168)
HFS+ magic value at 19603623/0/1
HFS+ magic value at 19603750/0/1
HFS 19603750 1953593557 1933989808
This partition ends after the disk limits. (start=19603750, size=1933989808, end=1953593557, disk end=1953525168)
HFS+ magic value at 19603752/0/1
HFS+ magic value at 19603855/0/1
HFS 19603855 1953593662 1933989808
This partition ends after the disk limits. (start=19603855, size=1933989808, end=1953593662, disk end=1953525168)
HFS+ magic value at 19603857/0/1
HFS+ magic value at 19603976/0/1
HFS 19603976 1953593783 1933989808
This partition ends after the disk limits. (start=19603976, size=1933989808, end=1953593783, disk end=1953525168)
HFS+ magic value at 19603978/0/1
HFS+ magic value at 19604065/0/1
HFS 19604065 1953593872 1933989808
This partition ends after the disk limits. (start=19604065, size=1933989808, end=1953593872, disk end=1953525168)
HFS+ magic value at 19604067/0/1
HFS+ magic value at 19604154/0/1
HFS 19604154 1953593961 1933989808
This partition ends after the disk limits. (start=19604154, size=1933989808, end=1953593961, disk end=1953525168)
HFS+ magic value at 19604156/0/1
HFS+ magic value at 19604243/0/1
HFS 19604243 1953594050 1933989808
This partition ends after the disk limits. (start=19604243, size=1933989808, end=1953594050, disk end=1953525168)
HFS+ magic value at 19604245/0/1
HFS+ magic value at 19604332/0/1
HFS 19604332 1953594139 1933989808
This partition ends after the disk limits. (start=19604332, size=1933989808, end=1953594139, disk end=1953525168)
HFS+ magic value at 19604334/0/1
HFS+ magic value at 19604437/0/1
HFS 19604437 1953594244 1933989808
This partition ends after the disk limits. (start=19604437, size=1933989808, end=1953594244, disk end=1953525168)
HFS+ magic value at 19604439/0/1
HFS+ magic value at 19604646/0/1
HFS 19604646 1953594453 1933989808
This partition ends after the disk limits. (start=19604646, size=1933989808, end=1953594453, disk end=1953525168)
HFS+ magic value at 19604648/0/1
HFS+ magic value at 19604767/0/1
HFS 19604767 1953594574 1933989808
This partition ends after the disk limits. (start=19604767, size=1933989808, end=1953594574, disk end=1953525168)
HFS+ magic value at 19604769/0/1
HFS+ magic value at 19604864/0/1
HFS 19604864 1953594671 1933989808
This partition ends after the disk limits. (start=19604864, size=1933989808, end=1953594671, disk end=1953525168)
HFS+ magic value at 19604866/0/1
HFS+ magic value at 19605169/0/1
HFS 19605169 1953594976 1933989808
This partition ends after the disk limits. (start=19605169, size=1933989808, end=1953594976, disk end=1953525168)
HFS+ magic value at 19605171/0/1
HFS+ magic value at 19605266/0/1
HFS 19605266 1953595073 1933989808
This partition ends after the disk limits. (start=19605266, size=1933989808, end=1953595073, disk end=1953525168)
HFS+ magic value at 19605268/0/1
HFS+ magic value at 19605451/0/1
HFS 19605451 1953595258 1933989808
This partition ends after the disk limits. (start=19605451, size=1933989808, end=1953595258, disk end=1953525168)
HFS+ magic value at 19605453/0/1
HFS+ magic value at 19605540/0/1
HFS 19605540 1953595347 1933989808
This partition ends after the disk limits. (start=19605540, size=1933989808, end=1953595347, disk end=1953525168)
HFS+ magic value at 19605542/0/1
HFS+ magic value at 19605629/0/1
HFS 19605629 1953595436 1933989808
This partition ends after the disk limits. (start=19605629, size=1933989808, end=1953595436, disk end=1953525168)
HFS+ magic value at 19605631/0/1
HFS+ magic value at 19605734/0/1
HFS 19605734 1953595541 1933989808
This partition ends after the disk limits. (start=19605734, size=1933989808, end=1953595541, disk end=1953525168)
HFS+ magic value at 19605736/0/1
HFS+ magic value at 19605951/0/1
HFS 19605951 1953595758 1933989808
This partition ends after the disk limits. (start=19605951, size=1933989808, end=1953595758, disk end=1953525168)
HFS+ magic value at 19605953/0/1
HFS+ magic value at 19606168/0/1
HFS 19606168 1953595975 1933989808
This partition ends after the disk limits. (start=19606168, size=1933989808, end=1953595975, disk end=1953525168)
HFS+ magic value at 19606170/0/1
HFS+ magic value at 19606257/0/1
HFS 19606257 1953596064 1933989808
This partition ends after the disk limits. (start=19606257, size=1933989808, end=1953596064, disk end=1953525168)
HFS+ magic value at 19606259/0/1
HFS+ magic value at 19606506/0/1
HFS 19606506 1953596313 1933989808
This partition ends after the disk limits. (start=19606506, size=1933989808, end=1953596313, disk end=1953525168)
HFS+ magic value at 19606508/0/1
HFS+ magic value at 19606595/0/1
HFS 19606595 1953596402 1933989808
This partition ends after the disk limits. (start=19606595, size=1933989808, end=1953596402, disk end=1953525168)
HFS+ magic value at 19606597/0/1
HFS+ magic value at 19606692/0/1
HFS 19606692 1953596499 1933989808
This partition ends after the disk limits. (start=19606692, size=1933989808, end=1953596499, disk end=1953525168)
HFS+ magic value at 19606694/0/1
HFS+ magic value at 19606781/0/1
HFS 19606781 1953596588 1933989808
This partition ends after the disk limits. (start=19606781, size=1933989808, end=1953596588, disk end=1953525168)
HFS+ magic value at 19606783/0/1
HFS+ magic value at 19606886/0/1
HFS 19606886 1953596693 1933989808
This partition ends after the disk limits. (start=19606886, size=1933989808, end=1953596693, disk end=1953525168)
HFS+ magic value at 19606888/0/1
HFS+ magic value at 19607503/0/1
HFS 19607503 1953597310 1933989808
This partition ends after the disk limits. (start=19607503, size=1933989808, end=1953597310, disk end=1953525168)
HFS+ magic value at 19607505/0/1
HFS+ magic value at 19607712/0/1
HFS 19607712 1953597519 1933989808
This partition ends after the disk limits. (start=19607712, size=1933989808, end=1953597519, disk end=1953525168)
HFS+ magic value at 19607714/0/1
HFS+ magic value at 19607945/0/1
HFS 19607945 1953597752 1933989808
This partition ends after the disk limits. (start=19607945, size=1933989808, end=1953597752, disk end=1953525168)
HFS+ magic value at 19607947/0/1
HFS+ magic value at 19610874/0/1
HFS 19610874 1953600681 1933989808
This partition ends after the disk limits. (start=19610874, size=1933989808, end=1953600681, disk end=1953525168)
HFS+ magic value at 19610876/0/1
HFS+ magic value at 19611587/0/1
HFS 19611587 1953601394 1933989808
This partition ends after the disk limits. (start=19611587, size=1933989808, end=1953601394, disk end=1953525168)
HFS+ magic value at 19611589/0/1
HFS+ magic value at 19611700/0/1
HFS 19611700 1953601507 1933989808
This partition ends after the disk limits. (start=19611700, size=1933989808, end=1953601507, disk end=1953525168)
HFS+ magic value at 19611702/0/1
HFS+ magic value at 19611877/0/1
HFS 19611877 1953601684 1933989808
This partition ends after the disk limits. (start=19611877, size=1933989808, end=1953601684, disk end=1953525168)
HFS+ magic value at 19611879/0/1
HFS+ magic value at 19612166/0/1
HFS 19612166 1953601973 1933989808
This partition ends after the disk limits. (start=19612166, size=1933989808, end=1953601973, disk end=1953525168)
HFS+ magic value at 19612168/0/1
HFS+ magic value at 19612391/0/1
HFS 19612391 1953602198 1933989808
This partition ends after the disk limits. (start=19612391, size=1933989808, end=1953602198, disk end=1953525168)
HFS+ magic value at 19612393/0/1
HFS+ magic value at 19612480/0/1
HFS 19612480 1953602287 1933989808
This partition ends after the disk limits. (start=19612480, size=1933989808, end=1953602287, disk end=1953525168)
HFS+ magic value at 19612482/0/1
HFS+ magic value at 19612689/0/1
HFS 19612689 1953602496 1933989808
This partition ends after the disk limits. (start=19612689, size=1933989808, end=1953602496, disk end=1953525168)
HFS+ magic value at 19612691/0/1
HFS+ magic value at 19618554/0/1
HFS 19618554 1953608361 1933989808
This partition ends after the disk limits. (start=19618554, size=1933989808, end=1953608361, disk end=1953525168)
HFS+ magic value at 19618556/0/1
HFS+ magic value at 19618731/0/1
HFS 19618731 1953608538 1933989808
This partition ends after the disk limits. (start=19618731, size=1933989808, end=1953608538, disk end=1953525168)
HFS+ magic value at 19618733/0/1
HFS+ magic value at 19618868/0/1
HFS 19618868 1953608675 1933989808
This partition ends after the disk limits. (start=19618868, size=1933989808, end=1953608675, disk end=1953525168)
HFS+ magic value at 19618870/0/1
HFS+ magic value at 19618973/0/1
HFS 19618973 1953608780 1933989808
This partition ends after the disk limits. (start=19618973, size=1933989808, end=1953608780, disk end=1953525168)
HFS+ magic value at 19618975/0/1
HFS+ magic value at 19619494/0/1
HFS 19619494 1953609301 1933989808
This partition ends after the disk limits. (start=19619494, size=1933989808, end=1953609301, disk end=1953525168)
HFS+ magic value at 19619496/0/1
HFS+ magic value at 19619615/0/1
HFS 19619615 1953609422 1933989808
This partition ends after the disk limits. (start=19619615, size=1933989808, end=1953609422, disk end=1953525168)
HFS+ magic value at 19619617/0/1
HFS+ magic value at 19619792/0/1
HFS 19619792 1953609599 1933989808
This partition ends after the disk limits. (start=19619792, size=1933989808, end=1953609599, disk end=1953525168)
HFS+ magic value at 19619794/0/1
HFS+ magic value at 19619969/0/1
HFS 19619969 1953609776 1933989808
This partition ends after the disk limits. (start=19619969, size=1933989808, end=1953609776, disk end=1953525168)
HFS+ magic value at 19619971/0/1
HFS+ magic value at 19620170/0/1
HFS 19620170 1953609977 1933989808
This partition ends after the disk limits. (start=19620170, size=1933989808, end=1953609977, disk end=1953525168)
HFS+ magic value at 19620172/0/1
HFS+ magic value at 19620443/0/1
HFS 19620443 1953610250 1933989808
This partition ends after the disk limits. (start=19620443, size=1933989808, end=1953610250, disk end=1953525168)
HFS+ magic value at 19620445/0/1
HFS+ magic value at 19620540/0/1
HFS 19620540 1953610347 1933989808
This partition ends after the disk limits. (start=19620540, size=1933989808, end=1953610347, disk end=1953525168)
HFS+ magic value at 19620542/0/1
HFS+ magic value at 19620781/0/1
HFS 19620781 1953610588 1933989808
This partition ends after the disk limits. (start=19620781, size=1933989808, end=1953610588, disk end=1953525168)
HFS+ magic value at 19620783/0/1
HFS+ magic value at 19620846/0/1
HFS 19620846 1953610653 1933989808
This partition ends after the disk limits. (start=19620846, size=1933989808, end=1953610653, disk end=1953525168)
HFS+ magic value at 19620848/0/1
HFS+ magic value at 19621919/0/1
HFS 19621919 1953611726 1933989808
This partition ends after the disk limits. (start=19621919, size=1933989808, end=1953611726, disk end=1953525168)
HFS+ magic value at 19621921/0/1
HFS+ magic value at 19622208/0/1
HFS 19622208 1953612015 1933989808
This partition ends after the disk limits. (start=19622208, size=1933989808, end=1953612015, disk end=1953525168)
HFS+ magic value at 19622210/0/1
HFS+ magic value at 19622361/0/1
HFS 19622361 1953612168 1933989808
This partition ends after the disk limits. (start=19622361, size=1933989808, end=1953612168, disk end=1953525168)
HFS+ magic value at 19622363/0/1
HFS+ magic value at 19622490/0/1
HFS 19622490 1953612297 1933989808
This partition ends after the disk limits. (start=19622490, size=1933989808, end=1953612297, disk end=1953525168)
HFS+ magic value at 19622492/0/1
HFS+ magic value at 19622579/0/1
HFS 19622579 1953612386 1933989808
This partition ends after the disk limits. (start=19622579, size=1933989808, end=1953612386, disk end=1953525168)
HFS+ magic value at 19622581/0/1
HFS+ magic value at 19622700/0/1
HFS 19622700 1953612507 1933989808
This partition ends after the disk limits. (start=19622700, size=1933989808, end=1953612507, disk end=1953525168)
HFS+ magic value at 19622702/0/1
HFS+ magic value at 19622973/0/1
HFS 19622973 1953612780 1933989808
This partition ends after the disk limits. (start=19622973, size=1933989808, end=1953612780, disk end=1953525168)
HFS+ magic value at 19622975/0/1
HFS+ magic value at 19623278/0/1
HFS 19623278 1953613085 1933989808
This partition ends after the disk limits. (start=19623278, size=1933989808, end=1953613085, disk end=1953525168)
HFS+ magic value at 19623280/0/1
HFS+ magic value at 19623575/0/1
HFS 19623575 1953613382 1933989808
This partition ends after the disk limits. (start=19623575, size=1933989808, end=1953613382, disk end=1953525168)
HFS+ magic value at 19623577/0/1
HFS+ magic value at 19623776/0/1
HFS 19623776 1953613583 1933989808
This partition ends after the disk limits. (start=19623776, size=1933989808, end=1953613583, disk end=1953525168)
HFS+ magic value at 19623778/0/1
HFS+ magic value at 19623865/0/1
HFS 19623865 1953613672 1933989808
This partition ends after the disk limits. (start=19623865, size=1933989808, end=1953613672, disk end=1953525168)
HFS+ magic value at 19623867/0/1
HFS+ magic value at 19624170/0/1
HFS 19624170 1953613977 1933989808
This partition ends after the disk limits. (start=19624170, size=1933989808, end=1953613977, disk end=1953525168)
HFS+ magic value at 19624172/0/1
HFS+ magic value at 19624291/0/1
HFS 19624291 1953614098 1933989808
This partition ends after the disk limits. (start=19624291, size=1933989808, end=1953614098, disk end=1953525168)
HFS+ magic value at 19624293/0/1
HFS+ magic value at 19624548/0/1
HFS 19624548 1953614355 1933989808
This partition ends after the disk limits. (start=19624548, size=1933989808, end=1953614355, disk end=1953525168)
HFS+ magic value at 19624550/0/1
HFS+ magic value at 19624757/0/1
HFS 19624757 1953614564 1933989808
This partition ends after the disk limits. (start=19624757, size=1933989808, end=1953614564, disk end=1953525168)
HFS+ magic value at 19624759/0/1
HFS+ magic value at 19624950/0/1
HFS 19624950 1953614757 1933989808
This partition ends after the disk limits. (start=19624950, size=1933989808, end=1953614757, disk end=1953525168)
HFS+ magic value at 19624952/0/1
HFS+ magic value at 19625055/0/1
HFS 19625055 1953614862 1933989808
This partition ends after the disk limits. (start=19625055, size=1933989808, end=1953614862, disk end=1953525168)
HFS+ magic value at 19625057/0/1
HFS+ magic value at 19625240/0/1
HFS 19625240 1953615047 1933989808
This partition ends after the disk limits. (start=19625240, size=1933989808, end=1953615047, disk end=1953525168)
HFS+ magic value at 19625242/0/1
HFS+ magic value at 19625417/0/1
HFS 19625417 1953615224 1933989808
This partition ends after the disk limits. (start=19625417, size=1933989808, end=1953615224, disk end=1953525168)
HFS+ magic value at 19625419/0/1
HFS+ magic value at 19626058/0/1
HFS 19626058 1953615865 1933989808
This partition ends after the disk limits. (start=19626058, size=1933989808, end=1953615865, disk end=1953525168)
HFS+ magic value at 19626060/0/1
HFS+ magic value at 19626203/0/1
HFS 19626203 1953616010 1933989808
This partition ends after the disk limits. (start=19626203, size=1933989808, end=1953616010, disk end=1953525168)
HFS+ magic value at 19626205/0/1
HFS+ magic value at 19626420/0/1
HFS 19626420 1953616227 1933989808
This partition ends after the disk limits. (start=19626420, size=1933989808, end=1953616227, disk end=1953525168)
HFS+ magic value at 19626422/0/1
HFS+ magic value at 19626637/0/1
HFS 19626637 1953616444 1933989808
This partition ends after the disk limits. (start=19626637, size=1933989808, end=1953616444, disk end=1953525168)
HFS+ magic value at 19626639/0/1
HFS+ magic value at 19626790/0/1
HFS 19626790 1953616597 1933989808
This partition ends after the disk limits. (start=19626790, size=1933989808, end=1953616597, disk end=1953525168)
HFS+ magic value at 19626792/0/1
HFS+ magic value at 19626967/0/1
HFS 19626967 1953616774 1933989808
This partition ends after the disk limits. (start=19626967, size=1933989808, end=1953616774, disk end=1953525168)
HFS+ magic value at 19626969/0/1
HFS+ magic value at 19627232/0/1
HFS 19627232 1953617039 1933989808
This partition ends after the disk limits. (start=19627232, size=1933989808, end=1953617039, disk end=1953525168)
HFS+ magic value at 19627234/0/1
HFS+ magic value at 19627297/0/1
HFS 19627297 1953617104 1933989808
This partition ends after the disk limits. (start=19627297, size=1933989808, end=1953617104, disk end=1953525168)
HFS+ magic value at 19627299/0/1
HFS+ magic value at 19628322/0/1
HFS 19628322 1953618129 1933989808
This partition ends after the disk limits. (start=19628322, size=1933989808, end=1953618129, disk end=1953525168)
HFS+ magic value at 19628324/0/1
HFS+ magic value at 19628451/0/1
HFS 19628451 1953618258 1933989808
This partition ends after the disk limits. (start=19628451, size=1933989808, end=1953618258, disk end=1953525168)
HFS+ magic value at 19628453/0/1
HFS+ magic value at 19628596/0/1
HFS 19628596 1953618403 1933989808
This partition ends after the disk limits. (start=19628596, size=1933989808, end=1953618403, disk end=1953525168)
HFS+ magic value at 19628598/0/1
HFS+ magic value at 19628685/0/1
HFS 19628685 1953618492 1933989808
This partition ends after the disk limits. (start=19628685, size=1933989808, end=1953618492, disk end=1953525168)
HFS+ magic value at 19628687/0/1
HFS+ magic value at 19628806/0/1
HFS 19628806 1953618613 1933989808
This partition ends after the disk limits. (start=19628806, size=1933989808, end=1953618613, disk end=1953525168)
HFS+ magic value at 19628808/0/1
HFS+ magic value at 19628999/0/1
HFS 19628999 1953618806 1933989808
This partition ends after the disk limits. (start=19628999, size=1933989808, end=1953618806, disk end=1953525168)
HFS+ magic value at 19629001/0/1
HFS+ magic value at 19629184/0/1
HFS 19629184 1953618991 1933989808
This partition ends after the disk limits. (start=19629184, size=1933989808, end=1953618991, disk end=1953525168)
HFS+ magic value at 19629186/0/1
HFS+ magic value at 19629601/0/1
HFS 19629601 1953619408 1933989808
This partition ends after the disk limits. (start=19629601, size=1933989808, end=1953619408, disk end=1953525168)
HFS+ magic value at 19629603/0/1
HFS+ magic value at 19629890/0/1
HFS 19629890 1953619697 1933989808
This partition ends after the disk limits. (start=19629890, size=1933989808, end=1953619697, disk end=1953525168)
HFS+ magic value at 19629892/0/1
HFS+ magic value at 19630147/0/1
HFS 19630147 1953619954 1933989808
This partition ends after the disk limits. (start=19630147, size=1933989808, end=1953619954, disk end=1953525168)
HFS+ magic value at 19630149/0/1
HFS+ magic value at 19630428/0/1
HFS 19630428 1953620235 1933989808
This partition ends after the disk limits. (start=19630428, size=1933989808, end=1953620235, disk end=1953525168)
HFS+ magic value at 19630430/0/1
HFS+ magic value at 19630637/0/1
HFS 19630637 1953620444 1933989808
This partition ends after the disk limits. (start=19630637, size=1933989808, end=1953620444, disk end=1953525168)
HFS+ magic value at 19630639/0/1
HFS+ magic value at 19630806/0/1
HFS 19630806 1953620613 1933989808
This partition ends after the disk limits. (start=19630806, size=1933989808, end=1953620613, disk end=1953525168)
HFS+ magic value at 19630808/0/1
HFS+ magic value at 19630943/0/1
HFS 19630943 1953620750 1933989808
This partition ends after the disk limits. (start=19630943, size=1933989808, end=1953620750, disk end=1953525168)
HFS+ magic value at 19630945/0/1
HFS+ magic value at 19631048/0/1
HFS 19631048 1953620855 1933989808
This partition ends after the disk limits. (start=19631048, size=1933989808, end=1953620855, disk end=1953525168)
HFS+ magic value at 19631050/0/1
HFS+ magic value at 19631393/0/1
HFS 19631393 1953621200 1933989808
This partition ends after the disk limits. (start=19631393, size=1933989808, end=1953621200, disk end=1953525168)
HFS+ magic value at 19631395/0/1
HFS+ magic value at 19631634/0/1
HFS 19631634 1953621441 1933989808
This partition ends after the disk limits. (start=19631634, size=1933989808, end=1953621441, disk end=1953525168)
HFS+ magic value at 19631636/0/1
HFS+ magic value at 19632923/0/1
HFS 19632923 1953622730 1933989808
This partition ends after the disk limits. (start=19632923, size=1933989808, end=1953622730, disk end=1953525168)
HFS+ magic value at 19632925/0/1
HFS+ magic value at 19633060/0/1
HFS 19633060 1953622867 1933989808
This partition ends after the disk limits. (start=19633060, size=1933989808, end=1953622867, disk end=1953525168)
HFS+ magic value at 19633062/0/1
HFS+ magic value at 19633309/0/1
HFS 19633309 1953623116 1933989808
This partition ends after the disk limits. (start=19633309, size=1933989808, end=1953623116, disk end=1953525168)
HFS+ magic value at 19633311/0/1
HFS+ magic value at 19633526/0/1
HFS 19633526 1953623333 1933989808
This partition ends after the disk limits. (start=19633526, size=1933989808, end=1953623333, disk end=1953525168)
HFS+ magic value at 19633528/0/1
HFS+ magic value at 19633591/0/1
HFS 19633591 1953623398 1933989808
This partition ends after the disk limits. (start=19633591, size=1933989808, end=1953623398, disk end=1953525168)
HFS+ magic value at 19633593/0/1
HFS+ magic value at 19634704/0/1
HFS 19634704 1953624511 1933989808
This partition ends after the disk limits. (start=19634704, size=1933989808, end=1953624511, disk end=1953525168)
HFS+ magic value at 19634706/0/1
HFS+ magic value at 19634841/0/1
HFS 19634841 1953624648 1933989808
This partition ends after the disk limits. (start=19634841, size=1933989808, end=1953624648, disk end=1953525168)
HFS+ magic value at 19634843/0/1
HFS+ magic value at 19635402/0/1
HFS 19635402 1953625209 1933989808
This partition ends after the disk limits. (start=19635402, size=1933989808, end=1953625209, disk end=1953525168)
HFS+ magic value at 19635404/0/1
HFS+ magic value at 19635659/0/1
HFS 19635659 1953625466 1933989808
This partition ends after the disk limits. (start=19635659, size=1933989808, end=1953625466, disk end=1953525168)
HFS+ magic value at 19635661/0/1
HFS+ magic value at 19635748/0/1
HFS 19635748 1953625555 1933989808
This partition ends after the disk limits. (start=19635748, size=1933989808, end=1953625555, disk end=1953525168)
HFS+ magic value at 19635750/0/1
HFS+ magic value at 19635877/0/1
HFS 19635877 1953625684 1933989808
This partition ends after the disk limits. (start=19635877, size=1933989808, end=1953625684, disk end=1953525168)
HFS+ magic value at 19635879/0/1
HFS+ magic value at 19636062/0/1
HFS 19636062 1953625869 1933989808
This partition ends after the disk limits. (start=19636062, size=1933989808, end=1953625869, disk end=1953525168)
HFS+ magic value at 19636064/0/1
HFS+ magic value at 19636151/0/1
HFS 19636151 1953625958 1933989808
This partition ends after the disk limits. (start=19636151, size=1933989808, end=1953625958, disk end=1953525168)
HFS+ magic value at 19636153/0/1
HFS+ magic value at 19636296/0/1
HFS 19636296 1953626103 1933989808
This partition ends after the disk limits. (start=19636296, size=1933989808, end=1953626103, disk end=1953525168)
HFS+ magic value at 19636298/0/1
HFS+ magic value at 19636393/0/1
HFS 19636393 1953626200 1933989808
This partition ends after the disk limits. (start=19636393, size=1933989808, end=1953626200, disk end=1953525168)
HFS+ magic value at 19636395/0/1
HFS+ magic value at 19636698/0/1
HFS 19636698 1953626505 1933989808
This partition ends after the disk limits. (start=19636698, size=1933989808, end=1953626505, disk end=1953525168)
HFS+ magic value at 19636700/0/1
HFS+ magic value at 19636891/0/1
HFS 19636891 1953626698 1933989808
This partition ends after the disk limits. (start=19636891, size=1933989808, end=1953626698, disk end=1953525168)
HFS+ magic value at 19636893/0/1
HFS+ magic value at 19636996/0/1
HFS 19636996 1953626803 1933989808
This partition ends after the disk limits. (start=19636996, size=1933989808, end=1953626803, disk end=1953525168)
HFS+ magic value at 19636998/0/1
HFS+ magic value at 19637189/0/1
HFS 19637189 1953626996 1933989808
This partition ends after the disk limits. (start=19637189, size=1933989808, end=1953626996, disk end=1953525168)
HFS+ magic value at 19637191/0/1
HFS+ magic value at 19637478/0/1
HFS 19637478 1953627285 1933989808
This partition ends after the disk limits. (start=19637478, size=1933989808, end=1953627285, disk end=1953525168)
HFS+ magic value at 19637480/0/1
HFS+ magic value at 19637679/0/1
HFS 19637679 1953627486 1933989808
This partition ends after the disk limits. (start=19637679, size=1933989808, end=1953627486, disk end=1953525168)
HFS+ magic value at 19637681/0/1
HFS+ magic value at 19637768/0/1
HFS 19637768 1953627575 1933989808
This partition ends after the disk limits. (start=19637768, size=1933989808, end=1953627575, disk end=1953525168)
HFS+ magic value at 19637770/0/1
HFS+ magic value at 19637985/0/1
HFS 19637985 1953627792 1933989808
This partition ends after the disk limits. (start=19637985, size=1933989808, end=1953627792, disk end=1953525168)
HFS+ magic value at 19637987/0/1
HFS+ magic value at 19638114/0/1
HFS 19638114 1953627921 1933989808
This partition ends after the disk limits. (start=19638114, size=1933989808, end=1953627921, disk end=1953525168)
HFS+ magic value at 19638116/0/1
HFS+ magic value at 19638227/0/1
HFS 19638227 1953628034 1933989808
This partition ends after the disk limits. (start=19638227, size=1933989808, end=1953628034, disk end=1953525168)
HFS+ magic value at 19638229/0/1
HFS+ magic value at 19638332/0/1
HFS 19638332 1953628139 1933989808
This partition ends after the disk limits. (start=19638332, size=1933989808, end=1953628139, disk end=1953525168)
HFS+ magic value at 19638334/0/1
HFS+ magic value at 19638453/0/1
HFS 19638453 1953628260 1933989808
This partition ends after the disk limits. (start=19638453, size=1933989808, end=1953628260, disk end=1953525168)
HFS+ magic value at 19638455/0/1
HFS+ magic value at 19638590/0/1
HFS 19638590 1953628397 1933989808
This partition ends after the disk limits. (start=19638590, size=1933989808, end=1953628397, disk end=1953525168)
HFS+ magic value at 19638592/0/1
HFS+ magic value at 19638775/0/1
HFS 19638775 1953628582 1933989808
This partition ends after the disk limits. (start=19638775, size=1933989808, end=1953628582, disk end=1953525168)
HFS+ magic value at 19638777/0/1
HFS+ magic value at 19639008/0/1
HFS 19639008 1953628815 1933989808
This partition ends after the disk limits. (start=19639008, size=1933989808, end=1953628815, disk end=1953525168)
HFS+ magic value at 19639010/0/1
HFS+ magic value at 19639153/0/1
HFS 19639153 1953628960 1933989808
This partition ends after the disk limits. (start=19639153, size=1933989808, end=1953628960, disk end=1953525168)
HFS+ magic value at 19639155/0/1
HFS+ magic value at 19639466/0/1
HFS 19639466 1953629273 1933989808
This partition ends after the disk limits. (start=19639466, size=1933989808, end=1953629273, disk end=1953525168)
HFS+ magic value at 19639468/0/1
HFS+ magic value at 19639531/0/1
HFS 19639531 1953629338 1933989808
This partition ends after the disk limits. (start=19639531, size=1933989808, end=1953629338, disk end=1953525168)
HFS+ magic value at 19639533/0/1
HFS+ magic value at 19639900/0/1
HFS 19639900 1953629707 1933989808
This partition ends after the disk limits. (start=19639900, size=1933989808, end=1953629707, disk end=1953525168)
HFS+ magic value at 19639902/0/1
HFS+ magic value at 19639989/0/1
HFS 19639989 1953629796 1933989808
This partition ends after the disk limits. (start=19639989, size=1933989808, end=1953629796, disk end=1953525168)
HFS+ magic value at 19639991/0/1
HFS+ magic value at 19640166/0/1
HFS 19640166 1953629973 1933989808
This partition ends after the disk limits. (start=19640166, size=1933989808, end=1953629973, disk end=1953525168)
HFS+ magic value at 19640168/0/1
HFS+ magic value at 19640295/0/1
HFS 19640295 1953630102 1933989808
This partition ends after the disk limits. (start=19640295, size=1933989808, end=1953630102, disk end=1953525168)
HFS+ magic value at 19640297/0/1
HFS+ magic value at 19640424/0/1
HFS 19640424 1953630231 1933989808
This partition ends after the disk limits. (start=19640424, size=1933989808, end=1953630231, disk end=1953525168)
HFS+ magic value at 19640426/0/1
HFS+ magic value at 19640569/0/1
HFS 19640569 1953630376 1933989808
This partition ends after the disk limits. (start=19640569, size=1933989808, end=1953630376, disk end=1953525168)
HFS+ magic value at 19640571/0/1
Thanks.
Compiler: GCC 4.0
BAD_RS LBA=2 1339
FAT32 at 2/0/1
FAT1 : 32-238441
cluster_size : 64
FAT32 at 2/0/1
FAT1 : 32-238441
cluster_size : 64
FAT32 at 2/0/1
FAT32 at 2/0/1
FAT1 : 32-238441
cluster_size : 64
FAT32 at 2/0/1
FAT32 at 8/0/1
FAT1 : 32-238441
cluster_size : 64
FAT32 at 8/0/1
When the 10GB partition at the end of the disk will be found, it should be possible to recreate the partition table.
Please send the end of the log file.
michaelvsprague
Ok, so here is the bottom portion of the log.
HFS 19753087 1953742894 1933989808
HFS 19753352 1953743159 1933989808
HFS 19753473 1953743280 1933989808
HFS 19753562 1953743369 1933989808
HFS 19753779 1953743586 1933989808
HFS 19754036 1953743843 1933989808
HFS 19754349 1953744156 1933989808
HFS 19754470 1953744277 1933989808
HFS 19754583 1953744390 1933989808
HFS 19754696 1953744503 1933989808
HFS 19754881 1953744688 1933989808
HFS 19755090 1953744897 1933989808
HFS 19755379 1953745186 1933989808
HFS 19755588 1953745395 1933989808
HFS 19755677 1953745484 1933989808
HFS 19755926 1953745733 1933989808
HFS 19756039 1953745846 1933989808
HFS 19756176 1953745983 1933989808
HFS 19756281 1953746088 1933989808
HFS 19756602 1953746409 1933989808
HFS 19756915 1953746722 1933989808
HFS 19757052 1953746859 1933989808
HFS 19757141 1953746948 1933989808
HFS 19757302 1953747109 1933989808
HFS 19757503 1953747310 1933989808
HFS 19757680 1953747487 1933989808
HFS 19757769 1953747576 1933989808
HFS 19758034 1953747841 1933989808
FAT12 111457851 3480518994 3369061144
FAT16 <32M 279584445 2427354812 2147770368
FAT16 >32M 364187544 4005202985 3641015442
FAT16 LBA 376517313 1998037886 1621520574
FAT32 420543349 3173591124 2753047776
VMFS 427541358 32610715137783481 32610714710242123
VMFS 1373745152, 16696685 TB / 15185547 TiB
FAT12 558078918 4091401387 3533322470
FAT32 LBA 570394637 4856942434 4286547798
FAT16 <32M 601013043 4849468186 4248455144
FAT16 LBA 642997390 2258211753 1615214364
FAT16 <32M 674510955 2025355981 1350845027
FAT32 LBA 676637386 3923581490 3246944105
FAT16 LBA 703230527 2540470207 1837239681
FAT16 >32M 718786961 4207917560 3489130600
FAT32 LBA 719052782 3131349517 2412296736
FAT16 >32M 749763480 4390778921 3641015442
FAT16 >32M 753565910 3548636849 2795070940
FAT16 >32M 755133574 2841439133 2086305560
FAT32 LBA 795572294 3207869029 2412296736
FAT12 803723356 3651115775 2847392420
FAT32 804066799 3105685571 2301618773
FAT32 807539629 3560587404 2753047776
FAT16 >32M 813967783 3399270889 2585303107
FAT32 LBA 874262978 4121207082 3246944105
FAT16 LBA 877133839 2714373519 1837239681
FAT16 >32M 892532854 2978838413 2086305560
FAT16 <32M 898191926 2474793908 1576601983
FAT12 908465783 3886471288 2978005506
FAT16 >32M 922734586 2064109817 1141375232
FAT12 938274299 5181743968 4243469670
FAT16 LBA 943473604 3645451006 2701977403
FAT12 957108886 3883777316 2926668431
FAT32 LBA 968399501 2263130452 1294730952
FAT12 969796342 4503118811 3533322470
FAT16 <32M 1000921981 4130487406 3129565426
HPFS - NTFS 1010984207 2895133735 1884149529
FAT12 1017028097 2978338242 1961310146
FAT32 LBA 1050262703 3755674034 2705411332
FAT16 >32M 1073834803 2227680100 1153845298
FAT12 1114432498 2842658895 1728226398
FAT12 1131112437 4392856566 3261744130
FAT32 1134812677 5247916187 4113103511
VMFS 1136820164 8475224530726 8474087710562
VMFS 108, 4338 TB / 3946 TiB
FAT32 LBA 1140347326 3552644061 2412296736
HPFS - NTFS 1142725669 3640120736 2497395068
FAT16 >32M 1146763176 4787778617 3641015442
FAT16 >32M 1163629230 3958700169 2795070940
FAT32 LBA 1169058654 5445342408 4276283755
FAT16 LBA 1179177296 3940867551 2761690256
FAT16 <32M 1183198482 2332915031 1149716550
FAT16 <32M 1190385425 2322931664 1132546240
FAT16 >32M 1204018834 5019620366 3815601533
HPFS - NTFS 1224434943 3108584471 1884149529
FAT16 <32M 1238999637 2183374628 944374992
FAT16 LBA 1245745112 4726283025 3480537914
FAT12 1246431703 3553637141 2307205439
FAT12 1251567921 3212878066 1961310146
FAT16 LBA 1253342872 4015033127 2761690256
FAT32 1258433890 4632510520 3374076631
FAT32 LBA 1263336996 4255339384 2992002389
FAT12 1267386146 2139801417 872415272
HPFS - NTFS 1268050053 2675577700 1407527648
FAT16 LBA 1273037609 2638215307 1365177699
FAT16 LBA 1276424718 5357443193 4081018476
FAT16 <32M 1279673728 4031300743 2751627016
HPFS - NTFS 1305183468 2000603808 695420341
HPFS - NTFS 1322063665 4626968365 3304904701
FAT16 >32M 1329179081 4818309680 3489130600
FAT16 LBA 1330958231 2604583129 1273624899
FAT16 <32M 1347944349 4477509774 3129565426
FAT32 LBA 1348859804 2965875055 1617015252
FAT32 LBA 1350109396 4492013292 3141903897
FAT16 <32M 1353280115 3701185694 2347905580
FAT32 LBA 1366745945 4386652603 3019906659
FAT16 LBA 1370534535 2567669438 1197134904
FAT32 LBA 1373976389 3551947098 2177970710
FAT32 LBA 1388510943 4441124993 3052614051
FAT12 1408192332 4255584751 2847392420
VMFS 1409709814 32610716119951937 32610714710242123
FAT32 LBA 1427892391 4480506441 3052614051
FAT16 >32M 1428257390 2933017621 1504760232
HPFS - NTFS 1441503129 3696410100 2254906972
FAT32 LBA 1444428872 3660446107 2216017236
HPFS - NTFS 1454254354 2170342322 716087969
FAT16 >32M 1457877155 5637563933 4179686779
FAT32 LBA 1460745501 5747293298 4286547798
FAT16 LBA 1465980969 2831158667 1365177699
FAT32 1476932915 3631389218 2154456304
HPFS - NTFS 1488885763 4362001399 2873115637
FAT32 LBA 1491834077 4650281239 3158447163
FAT16 LBA 1493234573 5408786919 3915552347
FAT32 1496394886 2797215037 1300820152
FAT32 1507940158 5231591328 3723651171
FAT16 LBA 1509276849 5519232633 4009955785
FAT32 1515679958 4174071582 2658391625
FAT16 LBA 1537713114 2251776710 714063597
FAT32 LBA 1547118860 4539121248 2992002389
FAT16 >32M 1549126553 3383098306 1833971754
FAT12 1566530667 4827801734 3261271068
FAT16 LBA 1566604582 4080567151 2513962570
FAT32 1569012930 2380734078 811721149
FAT16 >32M 1590825864 5144753245 3553927382
FAT32 LBA 1601576171 2508333773 906757603
FAT32 LBA 1610840432 4671571627 3060731196
FAT16 <32M 1633436070 4159849011 2526412942
FAT12 1648096970 3706115281 2058018312
HPFS - NTFS 1655175577 3330601416 1675425840
HPFS - NTFS 1656576748 5023281077 3366704330
FAT12 1663214171 4924485238 3261271068
FAT32 LBA 1671661653 3069148480 1397486828
FAT16 LBA 1673828704 2796573759 1122745056
HPFS - NTFS 1674620419 3686361526 2011741108
FAT16 LBA 1676749704 3553249899 1876500196
FAT16 <32M 1688110889 4113073783 2424962895
FAT16 LBA 1703643540 5549550397 3845906858
FAT16 <32M 1714592186 4206033757 2491441572
FAT32 LBA 1729829737 5242905424 3513075688
HPFS - NTFS 1733249841 4827164347 3093914507
FAT16 <32M 1736820523 2604690410 867869888
FAT16 >32M 1749199981 5046401959 3297201979
FAT32 LBA 1750527977 4770434635 3019906659
FAT32 1755861935 5156600642 3400738708
FAT16 >32M 1759408541 5056610519 3297201979
FAT12 1776917220 4241242020 2464324801
HPFS - NTFS 1780433077 4131070159 2350637083
HPFS - NTFS 1784476490 4415801181 2631324692
FAT16 LBA 1785665264 5688542638 3902877375
FAT32 LBA 1794891575 4766014865 2971123291
FAT32 LBA 1797595527 4503006858 2705411332
FAT32 1802974388 4454153375 2651178988
FAT16 <32M 1807983762 2957700311 1149716550
FAT16 >32M 1813891090 5629492622 3815601533
FAT32 LBA 1816380185 2438347064 621966880
FAT16 >32M 1817136436 2393190877 576054442
FAT16 <32M 1825962325 5833179829 4007217505
FAT16 <32M 1834602682 4140666496 2306063815
FAT16 <32M 1835205258 4141269072 2306063815
HPFS - NTFS 1835859554 2106953248 271093695
FAT32 LBA 1838256936 5753525814 3915268879
FAT16 LBA 1845958828 2702828480 856869653
FAT16 LBA 1846372257 4201260413 2354888157
FAT16 <32M 1847051399 4580709828 2733658430
FAT12 1847101581 2186180128 339078548
FAT12 1852962452 5444978381 3592015930
FAT32 LBA 1862595839 5754698743 3892102905
HPFS - NTFS 1866825354 2574821925 707996572
HPFS - NTFS 1873079899 3696057008 1822977110
FAT16 >32M 1873578058 3955172681 2081594624
FAT12 1878878458 4890379834 3011501377
FAT16 >32M 1881028062 2688974324 807946263
FAT32 LBA 1887030755 5328257633 3441226879
FAT16 <32M 1898081708 2621232756 723151049
FAT32 LBA 1901605032 2393269574 491664543
FAT16 LBA 1903839494 2937314952 1033475459
FAT16 LBA 1905686702 5380479063 3474792362
FAT12 1906505590 2778921053 872415464
HPFS - NTFS 1911476124 5703761853 3792285730
FAT16 LBA 1913598834 2646969233 733370400
FAT16 LBA 1915322780 4188059684 2272736905
FAT32 1919446272 4334266286 2414820015
FAT16 LBA 1922404795 5204510188 3282105394
FAT12 1922488208 3261192990 1338704783
FAT12 1923315168 3781394542 1858079375
FAT32 LBA 1926551281 4399334826 2472783546
FAT16 <32M 1927398231 4794491838 2867093608
FAT16 <32M 1927664843 3387979178 1460314336
FAT12 1927970788 4878960757 2950989970
FAT16 <32M 1936450674 2828665280 892214607
FAT16 LBA 1936817199 5739496267 3802679069
FAT16 <32M 1937990316 2878697216 940706901
FAT32 1939746283 4670422099 2730675817
FAT12 1944108724 3529978191 1585869468
FAT16 >32M 1944347296 2902310361 957963066
FAT16 >32M 1947795088 5678821651 3731026564
FAT12 1954581928 5362219015 3407637088
FAT12 1961806182 5461337841 3499531660
FAT32 1966379759 5913539317 3947159559
HPFS - NTFS 1966433025 5271337725 3304904701
FAT32 1966914799 5914074357 3947159559
FAT32 1971914222 2652266529 680352308
FAT16 <32M 1982044283 4329949862 2347905580
FAT16 <32M 1987707884 3323456182 1335748299
FAT12 1999154983 2833833798 834678816
FAT32 LBA 2006789250 5825540897 3818751648
FAT16 >32M 2025201284 3599305659 1574104376
FAT32 LBA 2025551204 4312333689 2286782486
FAT16 LBA 2025696860 3777434374 1751737515
FAT12 2028501924 2330644806 302142883
FAT16 <32M 2029293164 3365041462 1335748299
FAT32 LBA 2035497317 2133587303 98089987
FAT16 <32M 2039243690 3146343568 1107099879
FAT16 <32M 2041876747 5547565816 3505689070
FAT16 LBA 2051179943 5205932818 3154752876
HPFS - NTFS 2053513529 3728939368 1675425840
FAT12 2056511547 6040111549 3983600003
FAT12 2061216523 6044816525 3983600003
FAT32 2067290222 3105971150 1038680929
FAT32 LBA 2077734995 5758773653 3681038659
FAT16 <32M 2078660899 3538975234 1460314336
FAT32 LBA 2079059721 6351753292 4272693572
FAT32 LBA 2085530341 3633671902 1548141562
HPFS - NTFS 2087646672 2096332274 8685603
FAT32 2090864257 3563704271 1472840015
FAT12 2106155194 3235983368 1129828175
FAT16 >32M 2118983857 6054313449 3935329593
HPFS - NTFS 2131637442 4071389780 1939752339
FAT32 LBA 2135885925 5549386413 3413500489
FAT32 2150101975 4469353341 2319251367
FAT32 2150634662 6128631037 3977996376
FAT16 LBA 2150680507 2403133768 252453262
FAT32 2150803044 2481049933 330246890
FAT32 LBA 2157635045 4613395304 2455760260
FAT12 2169566830 3312645775 1143078946
FAT16 LBA 2170650035 5459141795 3288491761
FAT12 2172206536 2181180578 8974043
HPFS - NTFS 2173449769 2696186021 522736253
FAT16 >32M 2173849475 3310484257 1136634783
FAT16 <32M 2177767972 3574247225 1396479254
FAT16 <32M 2179382786 3286482664 1107099879
FAT16 LBA 2180270042 4411554145 2231284104
FAT16 >32M 2183303947 5485900132 3302596186
FAT32 LBA 2184620581 3274352967 1089732387
FAT12 2196079582 3827631869 1631552288
HPFS - NTFS 2197810048 6478047855 4280237808
FAT16 <32M 2206268580 2260894398 54625819
FAT12 2207646684 3484855652 1277208969
FAT16 <32M 2211289937 5167758226 2956468290
FAT16 >32M 2211812187 2362733349 150921163
HPFS - NTFS 2215951533 5974696590 3758745058
FAT16 >32M 2220262540 2709790914 489528375
FAT16 <32M 2237164325 3181539316 944374992
FAT16 >32M 2238944478 6272144966 4033200489
FAT16 <32M 2254288559 2879545909 625257351
FAT12 2256718894 5282928750 3026209857
FAT32 2257570737 5433996658 3176425922
HPFS - NTFS 2258707900 2954128240 695420341
FAT32 LBA 2263536655 5316150705 3052614051
FAT12 2264988581 4598761495 2333772915
FAT32 2265064004 3892891342 1627827339
FAT16 LBA 2266454709 3574600107 1308145399
FAT16 <32M 2273758323 3866775302 1593016980
FAT32 2278559887 4390460397 2111900511
FAT16 LBA 2279295444 2772906163 493610720
FAT16 <32M 2286299347 3879316326 1593016980
FAT16 >32M 2303308721 4623538973 2320230253
FAT12 2308454900 5259444869 2950989970
FAT16 <32M 2312568207 6016109894 3703541688
FAT16 >32M 2316216528 2436314123 120097596
FAT16 >32M 2316947187 2951018033 634070847
HPFS - NTFS 2343786860 4809921858 2466134999
FAT32 2354207831 2681909775 327701945
HPFS - NTFS 2354267304 6556390130 4202122827
FAT32 LBA 2362486642 4650213639 2287726998
FAT12 2373940797 3689442346 1315501550
FAT32 2375166901 3834871692 1459704792
FAT12 2382994491 3378922784 995928294
FAT32 LBA 2386835249 2620973986 234138738
FAT12 2387882656 5068162057 2680279402
FAT16 LBA 2390140375 4044306907 1654166533
FAT32 2390923219 2554408694 163485476
HPFS - NTFS 2392717165 3580279040 1187561876
HPFS - NTFS 2392846530 3108934498 716087969
FAT12 2396151664 2809584747 413433084
FAT32 LBA 2396828554 2552640444 155811891
FAT16 <32M 2403002240 2791784689 388782450
FAT32 LBA 2416624863 4028173025 1611548163
FAT16 <32M 2431435189 2497178950 65743762
FAT12 2433716712 2442690754 8974043
FAT16 <32M 2434761934 4961174875 2526412942
HPFS - NTFS 2437369457 2607751458 170382002
FAT12 2440104408 3666036750 1225932343
FAT32 2444088538 5452771235 3008682698
FAT16 >32M 2452662022 2937111098 484449077
FAT12 2456506464 3682438806 1225932343
FAT16 >32M 2459103327 6575614643 4116511317
FAT16 LBA 2464221899 5752713659 3288491761
FAT12 2468514717 4038869489 1570354773
FAT32 2468747358 3507428286 1038680929
HPFS - NTFS 2486178688 4588059072 2101880385
FAT16 <32M 2486771655 5220430084 2733658430
FAT12 2487006826 3616835000 1129828175
FAT12 2492299021 5252948289 2760649269
FAT16 LBA 2493355284 2822387264 329031981
FAT12 2496979424 4142537376 1645557953
HPFS - NTFS 2501389512 6528314567 4026925056
FAT12 2506098962 5132651142 2626552181
FAT32 LBA 2506270030 2664087424 157817395
FAT12 2523691042 2655987326 132296285
HPFS - NTFS 2524892444 3616290300 1091397857
HPFS - NTFS 2530433993 3159904078 629470086
FAT16 LBA 2532629510 4535137174 2002507665
FAT16 LBA 2533019134 4535526798 2002507665
FAT32 LBA 2538483864 5136801600 2598317737
FAT16 LBA 2543180291 5987307080 3444126790
FAT16 <32M 2550426624 5513958676 2963532053
FAT32 LBA 2551965896 2614743998 62778103
FAT16 LBA 2557622305 2829269840 271647536
HPFS - NTFS 2560156680 4439200618 1879043939
FAT16 >32M 2567627380 3112300544 544673165
FAT32 LBA 2577733185 4723135569 2145402385
FAT32 LBA 2590086274 4877813271 2287726998
FAT32 2598360317 3277407725 679047409
FAT16 >32M 2603256146 2615970645 12714500
FAT32 LBA 2604531228 3871284635 1266753408
HPFS - NTFS 2620485955 5439007898 2818521944
FAT32 2624462973 4111496657 1487033685
FAT32 2633237247 3000089262 366852016
FAT12 2637112726 3420943871 783831146
FAT32 2648273045 2661431612 13158568
FAT16 <32M 2648460469 6782035296 4133574828
FAT12 2674892001 3471987644 797095644
HPFS - NTFS 2675442959 6867370092 4191927134
HPFS - NTFS 2676291895 2955860630 279568736
FAT16 <32M 2702633442 4404241911 1701608470
FAT32 LBA 2703508545 6976202116 4272693572
FAT16 <32M 2708609900 5423981833 2715371934
FAT32 LBA 2710632878 6315109254 3604476377
HPFS - NTFS 2716302200 6366927776 3650625577
FAT32 2716360136 5131180150 2414820015
FAT16 LBA 2718944684 6528378753 3809434070
FAT12 2722498728 3482772174 760273447
FAT32 LBA 2725541343 5696664633 2971123291
FAT32 LBA 2726788403 5445906255 2719117853
FAT16 >32M 2732233301 6029435279 3297201979
FAT16 >32M 2733422053 6030624031 3297201979
FAT16 LBA 2733609291 5495184699 2761575409
FAT32 LBA 2740530402 3397034051 656503650
FAT16 LBA 2742491747 5504067155 2761575409
FAT32 2745367213 6155291172 3409923960
HPFS - NTFS 2745653970 3296470419 550816450
HPFS - NTFS 2756987748 5223122746 2466134999
FAT32 LBA 2758611786 5040149193 2281537408
FAT16 LBA 2760798823 5915551698 3154752876
HPFS - NTFS 2762568583 5399805553 2637236971
FAT16 <32M 2769545428 4885661329 2116115902
FAT16 LBA 2772997933 4801781506 2028783574
FAT32 LBA 2781578055 4476722399 1695144345
FAT16 LBA 2786377554 4839525152 2053147599
FAT32 LBA 2788442140 3542761290 754319151
FAT32 LBA 2799998448 6044180907 3244182460
FAT12 2803485962 4267893897 1464407936
FAT16 >32M 2805879099 3572798568 766919470
FAT32 LBA 2806190385 3389268885 583078501
FAT16 <32M 2807390463 2923531702 116141240
FAT16 LBA 2807394891 3818562228 1011167338
FAT16 LBA 2808905994 3964044375 1155138382
FAT16 LBA 2810412106 5333329060 2522916955
HPFS - NTFS 2814007525 5914276591 3100269067
FAT12 2832798779 6280426673 3447627895
FAT32 2836692957 5859329890 3022636934
FAT16 >32M 2841267345 4720282542 1879015198
FAT16 >32M 2846609929 4725625126 1879015198
FAT32 2853233663 6800393221 3947159559
FAT16 LBA 2854001665 4937654887 2083653223
FAT16 <32M 2855542905 5812011194 2956468290
FAT16 >32M 2856353178 3545159638 688806461
FAT16 >32M 2856918998 4059861903 1202942906
FAT16 LBA 2858358905 6263091561 3404732657
FAT12 2859616899 6217424971 3357808073
FAT16 >32M 2866635210 3263436208 396800999
FAT16 >32M 2869919568 3469095445 599175878
FAT16 <32M 2870876892 4206625190 1335748299
FAT16 <32M 2872472456 4296165558 1423693103
FAT16 <32M 2881899924 3822606824 940706901
HPFS - NTFS 2891887122 3745438166 853551045
FAT16 LBA 2902496855 5566625348 2664128494
HPFS - NTFS 2913857719 4312888192 1399030474
FAT12 2914717911 6216059775 3301341865
FAT32 LBA 2915900762 5313819142 2397918381
FAT16 LBA 2924753994 4670959878 1746205885
HPFS - NTFS 2926047039 7117974172 4191927134
FAT16 <32M 2928954651 5225012691 2296058041
FAT16 LBA 2933339021 4414919265 1481580245
FAT16 <32M 2933949966 6087490815 3153540850
FAT16 LBA 2935860284 3264892264 329031981
FAT32 LBA 2936059280 3501307409 565248130
FAT12 2940591719 2942233574 1641856
FAT32 2941213978 5812143559 2870929582
FAT32 LBA 2952867167 4274867666 1322000500
FAT16 LBA 2960038105 3231685640 271647536
FAT32 LBA 2960484202 3774844526 814360325
HPFS - NTFS 2966936784 5135641021 2168704238
FAT16 <32M 2968310248 3089947573 121637326
FAT32 2972676737 4894632200 1921955464
HPFS - NTFS 2976464260 4931717611 1955253352
FAT32 LBA 2981563463 4676707807 1695144345
FAT32 LBA 2983625308 5179767275 2196141968
FAT16 <32M 2988208663 3104349902 116141240
FAT32 2989250680 4286906564 1297655885
FAT12 3003598617 5609491418 2605892802
FAT32 LBA 3012338059 6361422521 3349084463
FAT32 3019142684 3448956476 429813793
HPFS - NTFS 3021355956 3749199196 727843241
FAT12 3026811536 4486781890 1459970355
FAT16 LBA 3031621044 4783358558 1751737515
FAT16 <32M 3033315156 6821874951 3788559796
FAT16 LBA 3036825304 3042373676 5548373
FAT16 <32M 3044204151 3833777131 789572981
HPFS - NTFS 3046874956 3615197375 568322420
FAT12 3048636391 7000035699 3951399309
HPFS - NTFS 3054141240 6008431709 2954290470
FAT16 >32M 3055820792 6335830563 3280009772
FAT12 3057688227 3596656386 538968160
FAT16 >32M 3059354623 4565965374 1506610752
FAT12 3071559521 3201334336 129774816
FAT16 <32M 3072484137 3233387684 160903548
FAT32 LBA 3076041337 6984944104 3908902768
FAT16 LBA 3087444028 4484003692 1396559665
FAT16 >32M 3096530686 3791969806 695439121
FAT16 LBA 3103527962 3121161160 17633199
FAT32 3104036904 5491934806 2387897903
FAT32 LBA 3111875428 6737984877 3626109450
FAT32 LBA 3112081931 6793120589 3681038659
FAT16 LBA 3116047169 3841883057 725835889
FAT32 3123073857 5151735334 2028661478
FAT12 3129932546 5352488279 2222555734
FAT12 3131394281 5063209437 1931815157
FAT32 LBA 3138141662 3295959056 157817395
HPFS - NTFS 3142909912 4313055856 1170145945
FAT32 3143249328 4507481297 1364231970
FAT12 3151297119 5916690590 2765393472
FAT16 <32M 3151765254 4589220775 1437455522
HPFS - NTFS 3151884816 5577744245 2425859430
FAT32 3164920314 5390587762 2225667449
FAT16 LBA 3179414945 3824437187 645022243
FAT32 LBA 3185656307 3191969041 6312735
FAT32 3187603088 4551835057 1364231970
FAT12 3191421053 7401668990 4210247938
FAT12 3194074827 3598043086 403968260
FAT32 LBA 3195865155 6874513278 3678648124
HPFS - NTFS 3197737881 5994748422 2797010542
FAT16 <32M 3199957403 3586508595 386551193
HPFS - NTFS 3205661420 4557114088 1351452669
FAT16 >32M 3205792223 4712402974 1506610752
HPFS - NTFS 3218293612 3786616031 568322420
FAT16 <32M 3224429016 5471814073 2247385058
FAT16 >32M 3230319383 7143824865 3913505483
FAT32 3234003148 5406885994 2172882847
FAT16 LBA 3237402010 4489908724 1252506715
HPFS - NTFS 3239212756 4526865475 1287652720
FAT32 3243573671 6456936834 3213363164
FAT12 3266738423 4319579535 1052841113
FAT32 LBA 3270031211 6948679334 3678648124
FAT16 <32M 3276004180 4534179914 1258175735
HPFS - NTFS 3278020586 6504054895 3226034310
FAT12 3279713169 4076808812 797095644
FAT32 LBA 3280887593 3348226844 67339252
FAT32 3283579310 3967167740 683588431
FAT16 >32M 3290580356 6285968935 2995388580
FAT12 NTFS signature is missing.
3291115359 3526061918 234946560
FAT16 <32M 3292740445 3298664380 5923936
FAT16 LBA 3293142227 4951417997 1658275771
FAT32 3299062845 6855849731 3556786887
HPFS - NTFS 3300621189 4268473088 967851900
FAT32 LBA 3301844348 5699902257 2398057910
FAT16 <32M 3302296327 4091869307 789572981
FAT32 3302529897 5180400093 1877870197
FAT16 LBA 3309572700 7208327028 3898754329
FAT12 3311325229 5201368293 1890043065
FAT12 3311840668 6430150020 3118309353
FAT32 3322747598 3548934772 226187175
FAT16 LBA 3322932445 5872593657 2549661213
FAT16 >32M 3323442502 6986880873 3663438372
FAT16 LBA 3325929020 5074730748 1748801729
FAT32 LBA 3332914242 5481397511 2148483270
HPFS - NTFS 3335853109 4523414984 1187561876
FAT12 3337512208 3421411172 83898965
FAT16 <32M 3340533516 5907323926 2566790411
FAT16 LBA 3345354190 5272810113 1927455924
HPFS - NTFS 3354941792 7504474454 4149532663
HPFS - NTFS 3358447432 7009073008 3650625577
FAT32 3360010392 5893431887 2533421496
FAT32 3361625352 7145326610 3783701259
HPFS - NTFS 3365010520 5533714757 2168704238
FAT32 LBA 3371683542 5552004901 2180321360
FAT32 LBA 3377205875 6658409348 3281203474
FAT32 LBA 3387088511 4998636673 1611548163
FAT12 3388520608 7139454259 3750933652
FAT12 3390923878 3458032741 67108864
FAT16 <32M 3394190378 5812589191 2418398814
FAT16 <32M 3397354661 3463098422 65743762
FAT16 >32M 3403787461 7193224776 3789437316
FAT16 <32M 3410985257 5665838014 2254852758
FAT16 >32M 3413338857 4031509729 618170873
FAT12 3413696900 5616777818 2203080919
FAT16 >32M 3418573409 4036744281 618170873
FAT32 LBA 3442846074 5909061226 2466215153
FAT32 LBA 3443692317 3705313438 261621122
FAT32 LBA 3444175933 3705797054 261621122
HPFS - NTFS 3446174503 6312217063 2866042561
FAT12 3448972765 4462367965 1013395201
HPFS - NTFS 3452181800 5554062184 2101880385
FAT16 >32M 3453047463 7739833330 4286785868
FAT12 3457984445 5868960422 2410975978
FAT12 3458000874 4495581798 1037580925
FAT32 LBA 3458042241 7366945008 3908902768
FAT12 3465360930 7626413636 4161052707
FAT12 3465617259 6695629329 3230012071
FAT32 3467513544 7251214802 3783701259
FAT16 <32M 3470551147 5115304782 1644753636
HPFS - NTFS 3474135309 7332045690 3857910382
FAT32 3475765878 4159354308 683588431
FAT16 >32M 3476968448 4076144325 599175878
FAT12 3485899866 5891144750 2405244885
FAT12 3487927273 7416487634 3928560362
FAT16 LBA 3496028589 4986035502 1490006914
HPFS - NTFS 3513572902 4903085202 1389512301
FAT32 3529147812 7251349651 3722201840
HPFS - NTFS 3529344868 4620742724 1091397857
FAT32 LBA 3543177672 4108425801 565248130
FAT16 >32M 3549114563 7075439071 3526324509
FAT12 3554970093 3873889326 318919234
FAT16 >32M 3555121838 4780951725 1225829888
FAT16 LBA 3562967329 4752583654 1189616326
FAT32 LBA 3574154262 5181166320 1607012059
FAT16 <32M 3578038820 6144829230 2566790411
FAT32 3578711243 5719780286 2141069044
FAT16 LBA 3584417435 4165545009 581127575
HPFS - NTFS 3600344334 7092862618 3492518285
FAT32 3604175763 6960797149 3356621387
FAT16 <32M 3605397757 7738972584 4133574828
FAT32 3607662701 3620821268 13158568
FAT16 <32M 3610255941 4493324193 883068253
FAT32 3617387035 5758456078 2141069044
FAT32 LBA 3624350532 5232231648 1607881117
FAT12 3650003060 5807190275 2157187216
FAT32 3655616855 4153791575 498174721
HPFS - NTFS 3659986901 7517897282 3857910382
FAT16 LBA 3669016439 6773209725 3104193287
FAT16 LBA 3674398842 4926905556 1252506715
HPFS - NTFS 3679296588 4552033564 872736977
FAT32 3682545675 5064798543 1382252869
FAT16 <32M 3686294056 5586071063 1899777008
FAT16 <32M 3701399403 6754819891 3053420489
FAT32 3704353146 6557195912 2852842767
FAT12 3707938396 6826247748 3118309353
FAT16 >32M 3710203071 6699080276 2988877206
HPFS - NTFS 3711217363 4564599381 853382019
FAT16 >32M 3714889234 4403695694 688806461
FAT16 <32M 3716170090 5457203655 1741033566
FAT32 LBA 3717790722 5999328129 2281537408
FAT16 LBA 3718403720 7655728588 3937324869
FAT32 LBA 3720030413 4762743627 1042713215
FAT32 LBA 3722393376 6995032390 3272639015
HPFS - NTFS 3722882652 6313830805 2590948154
FAT16 >32M 3743174613 4324388588 581213976
FAT32 LBA 3753593338 5580056311 1826462974
FAT12 3761215420 6517067176 2755851757
FAT32 LBA 3762466160 7035105174 3272639015
FAT16 >32M 3770424912 6779798030 3009373119
FAT16 >32M 3774257060 6679755426 2905498367
FAT16 LBA 3775293497 4498453025 723159529
FAT12 3780349940 3848573940 68224001
FAT16 <32M 3783347407 6070030827 2286683421
FAT16 <32M 3787196952 4127566281 340369330
FAT12 3792591494 4398760117 606168624
FAT16 <32M 3805751394 7759393304 3953641911
FAT16 LBA 3807185373 6933264451 3126079079
FAT32 LBA 3816907749 4501273342 684365594
FAT16 >32M 3822622295 6538191200 2715568906
FAT16 >32M 3831089556 6826478135 2995388580
FAT16 LBA 3831647779 6170332193 2338684415
FAT32 3834153257 4186584318 352431062
FAT16 >32M 3837475199 6022460404 2184985206
FAT16 >32M 3840726028 7746762307 3906036280
FAT16 <32M 3840849535 5027277992 1186428458
FAT32 LBA 3858588865 7767491632 3908902768
FAT12 3862559729 6803908475 2941348747
FAT12 3866314325 5855704111 1989389787
FAT16 <32M 3870193875 6166251915 2296058041
FAT12 3872644836 6109465245 2236820410
FAT32 LBA 3875648054 7168133202 3292485149
FAT32 3881512808 5434704907 1553192100
FAT32 LBA 3887436728 6784220364 2896783637
FAT16 LBA 3892963224 6376458221 2483494998
FAT32 3906792681 7971111694 4064319014
FAT16 <32M 3914146314 4198433007 284286694
FAT16 LBA 3915346558 7620585441 3705238884
FAT16 <32M 3921994816 5821771823 1899777008
FAT32 LBA 3926487162 4740847486 814360325
FAT32 LBA 3927926853 4901866224 973939372
FAT16 LBA 3935554431 4472253231 536698801
HPFS - NTFS 3938897144 6149541146 2210644003
FAT16 >32M 3960541894 5186371781 1225829888
FAT32 LBA 3970456399 6303154145 2332697747
FAT32 LBA 3982336307 7263539780 3281203474
FAT16 <32M 3983818026 6883399578 2899581553
FAT32 3996643764 7193245263 3196601500
HPFS - NTFS 4000322227 5948046312 1947724086
FAT12 4004752709 7457715865 3452963157
HPFS - NTFS 4009005982 7501524266 3492518285
FAT32 4009334291 6067340068 2058005778
HPFS - NTFS 4011061568 7236883789 3225822222
FAT12 4016914199 6164635561 2147721363
FAT16 >32M 4021679318 5444863484 1423184167
FAT16 LBA 4027010754 7557867835 3530857082
FAT32 4027452632 4726923417 699470786
FAT16 >32M 4047806815 4573646484 525839670
FAT12 4048285428 4471767057 423481630
FAT16 <32M 4059403762 6477802575 2418398814
FAT16 <32M 4059436290 8013078200 3953641911
FAT16 LBA 4062161777 4254612068 192450292
FAT16 LBA 4087977750 7793216633 3705238884
FAT12 4094457260 7212766612 3118309353
FAT16 LBA 4099894619 5967212196 1867317578
FAT32 4121363219 4304554206 183190988
FAT16 <32M 4128804146 5591433200 1462629055
FAT32 4129896209 6189049428 2059153220
FAT16 LBA 4137027494 7254102817 3117075324
FAT16 >32M 4148929668 6864498573 2715568906
FAT12 4157987911 8151795386 3993807476
FAT16 <32M 4159985228 4177797322 17812095
HPFS - NTFS 4159985666 4177749570 17763905
FAT16 LBA 4168042981 4736527523 568484543
FAT16 <32M 4172139186 5634768240 1462629055
FAT16 <32M 4173758699 5360187156 1186428458
FAT16 LBA 4190968870 6592917046 2401948177
FAT12 4194242886 7609952431 3415709546
FAT32 4204133393 6263286612 2059153220
HPFS - NTFS 4206516323 4778205454 571689132
FAT12 4209587153 4386841691 177254539
FAT16 >32M 4209965143 6925534048 2715568906
FAT16 <32M 4216249135 5384843743 1168594609
FAT16 >32M 4222122989 7404195665 3182072677
FAT16 <32M 4225701960 4749755436 524053477
HPFS - NTFS 4241671058 7467705367 3226034310
FAT16 >32M 4248780868 6369161992 2120381125
FAT32 4253143608 4704949372 451805765
FAT32 4253326777 7385794953 3132468177
HPFS - NTFS 4254094019 6201818104 1947724086
FAT32 4254779177 7295228203 3040449027
FAT32 4260377164 8100569971 3840192808
FAT32 LBA 4262125365 4575210367 313085003
HPFS - NTFS 4279895056 6283557676 2003662621
FAT32 4291288376 4743094140 451805765
FAT16 LBA 4297401843 5010493982 713092140
HPFS - NTFS 4302581801 4819456041 516874241
FAT32 LBA 4305210211 5959132997 1653922787
FAT32 LBA 4306883716 6704941625 2398057910
HPFS - NTFS 4312641074 7561807594 3249166521
FAT16 LBA 4312969637 5155648371 842678735
FAT16 <32M 4323198946 4565518539 242319594
FAT32 4326987307 5590764900 1263777594
FAT12 4345817080 5774753497 1428936418
FAT32 LBA 4347291487 6764780466 2417488980
HPFS - NTFS 4348557666 7821792854 3473235189
FAT32 4357455613 7023094905 2665639293
FAT16 <32M 4365658424 6779425604 2413767181
FAT16 LBA 4367980640 5543167001 1175186362
FAT16 <32M 4370033410 4633394129 263360720
FAT32 4370478335 4441773621 71295287
HPFS - NTFS 4375362086 8443276429 4067914344
FAT32 4384968509 5081430046 696461538
FAT16 LBA 4392703555 4635406125 242702571
FAT16 >32M 4407117233 6840385513 2433268281
FAT32 LBA 4414069999 6634741829 2220671831
FAT12 4419499718 7565042871 3145543154
FAT16 LBA 4420617039 6966986756 2546369718
FAT32 4427069213 7994701842 3567632630
HPFS - NTFS 4432759790 6625568040 2192808251
FAT16 >32M 4438653110 7022237941 2583584832
FAT16 >32M 4441233487 5732197942 1290964456
FAT16 <32M 4443632967 5717744306 1274111340
FAT32 4452588363 6593657406 2141069044
HPFS - NTFS 4456159955 4799091439 342931485
FAT16 >32M 4468779995 4579058141 110278147
FAT16 <32M 4479473068 5418613583 939140516
FAT16 <32M 4481929125 6718501570 2236572446
FAT16 LBA 4482896931 4838097452 355200522
FAT32 LBA 4483444826 7538667806 3055222981
FAT12 4495192086 6182879257 1687687172
FAT16 >32M 4501563077 8600105772 4098542696
FAT32 LBA 4508879259 7639800590 3130921332
FAT32 4509535140 8231736979 3722201840
FAT16 LBA 4522370018 6661272450 2138902433
FAT16 >32M 4531612580 6145179899 1613567320
FAT12 4541907894 4554933398 13025505
FAT16 >32M 4542946019 4653224165 110278147
FAT32 4545466834 5293664938 748198105
FAT16 <32M 4546808523 6480387867 1933579345
FAT16 LBA 4564916042 6703818474 2138902433
FAT16 LBA 4566576564 8083459098 3516882535
FAT12 4572011298 7118149200 2546137903
HPFS - NTFS 4585202898 8341063462 3755860565
FAT12 4586157892 5990326617 1404168726
HPFS - NTFS 4596940337 4814530541 217590205
FAT32 LBA 4598486728 7871125742 3272639015
FAT16 LBA 4621832705 7782485888 3160653184
FAT16 <32M 4623894089 6301180348 1677286260
FAT32 4629272735 6013656519 1384383785
FAT16 LBA 4632636246 5828117076 1195480831
FAT12 4633469494 7440465492 2806995999
FAT16 LBA 4636352921 7570659399 2934306479
HPFS - NTFS 4636732605 7540287205 2903554601
FAT16 LBA 4642963596 8159846130 3516882535
FAT16 <32M 4645951078 7322831979 2676880902
FAT16 <32M 4651218147 7704638635 3053420489
FAT16 LBA 4655968497 4759349380 103380884
FAT16 >32M 4663646415 6575074531 1911428117
FAT16 >32M 4676059135 6928999396 2252940262
FAT32 4684723954 8559444643 3874720690
FAT16 <32M 4686406309 4898832819 212426511
FAT32 4688207658 7541050424 2852842767
FAT32 LBA 4694590275 7521948479 2827358205
FAT16 <32M 4701661910 8355131973 3653470064
FAT16 LBA 4704457025 4896907316 192450292
FAT16 <32M 4711977261 5994123163 1282145903
FAT12 4714412366 6947111943 2232699578
FAT32 LBA 4716643161 6255315478 1538672318
FAT16 <32M 4723711911 5997823250 1274111340
HPFS - NTFS 4725808141 8380801705 3654993565
FAT32 4727214791 4798510077 71295287
FAT16 >32M 4736784948 7817795028 3081010081
FAT16 >32M 4747915759 6932900964 2184985206
FAT32 LBA 4769140809 5219163944 450023136
FAT12 4771084561 8931649669 4160565109
FAT32 LBA 4798492964 6866995435 2068502472
FAT12 4816722600 5129220830 312498231
HPFS - NTFS 4848261516 5853937712 1005676197
FAT16 LBA 4856528980 8005802429 3149273450
FAT16 LBA 4871317173 9043599748 4172282576
HPFS - NTFS 4874560113 6329107526 1454547414
FAT32 LBA 4888704646 7563302626 2674597981
FAT16 LBA 4910273459 5623365598 713092140
FAT32 LBA 4914471234 6185299439 1270828206
HPFS - NTFS 4914855136 9020859457 4106004322
HPFS - NTFS 4915107594 8164274114 3249166521
FAT32 4920292283 4959247848 38955566
FAT16 >32M 4923477289 8213746546 3290269258
FAT32 4926674711 5528981497 602306787
FAT16 >32M 4939387263 7006294744 2066907482
HPFS - NTFS 4956211057 6137819022 1181607966
FAT16 <32M 4957195869 7215434057 2258238189
FAT32 LBA 4961246040 5107780405 146534366
FAT32 LBA 4966274507 8631766974 3665492468
FAT12 4969465252 6045109222 1075643971
FAT16 LBA 4985609495 9021599684 4035990190
FAT16 LBA 4987836932 8504719466 3516882535
FAT16 >32M 4989349066 5397851186 408502121
FAT12 5000388871 6110376182 1109987312
FAT32 5000589967 8948630504 3948040538
FAT16 LBA 5004895449 6717006801 1712111353
HPFS - NTFS 5006031260 5010238019 4206760
FAT16 <32M 5013820074 6476449128 1462629055
FAT16 <32M 5017998771 5402855140 384856370
FAT16 <32M 5021018779 5405875148 384856370
FAT16 <32M 5025162515 8327553974 3302391460
HPFS - NTFS 5026519605 8367402016 3340882412
FAT16 <32M 5033948686 7908441469 2874492784
FAT16 >32M 5040385575 6943816775 1903431201
FAT32 5044225493 8611858122 3567632630
FAT16 <32M 5045265753 6656193065 1610927313
FAT12 5047363392 7964546269 2917182878
FAT32 5049196695 6824073012 1774876318
HPFS - NTFS 5059143003 5402074487 342931485
FAT32 5062468315 5711779743 649311429
FAT12 5094884277 6809774108 1714889832
FAT12 5099834259 6506555719 1406721461
FAT12 5109906048 9320153985 4210247938
FAT16 LBA 5122406647 6219312394 1096905748
FAT32 5123628608 5575434372 451805765
FAT12 5130320118 7687815046 2557494929
FAT32 LBA 5130744523 7958102727 2827358205
FAT16 <32M 5136012622 8789482685 3653470064
FAT12 5158547413 8771001802 3612454390
FAT16 LBA 5158584954 7844853346 2686268393
FAT12 5159474926 5251158340 91683415
FAT12 5178070859 6520412503 1342341645
FAT16 >32M 5197260402 8685573329 3488312928
FAT32 5199739591 6006829092 807089502
FAT12 5201254385 7087199945 1885945561
FAT16 >32M 5201306869 8383379545 3182072677
FAT12 5209371470 9219245140 4009873671
FAT16 <32M 5249162767 6417757375 1168594609
FAT16 >32M 5249347554 7653403141 2404055588
FAT12 5255424623 6559913486 1304488864
FAT32 5282271611 5465010782 182739172
FAT16 >32M 5304371521 6224367556 919996036
FAT16 LBA 5309024125 8891052308 3582028184
FAT16 <32M 5324299748 8666404166 3342104419
FAT12 5329028997 8423951278 3094922282
FAT16 <32M 5355901358 5659186479 303285122
FAT32 5363232236 7125833706 1762601471
FAT16 <32M 5367727447 8309992150 2942264704
FAT16 <32M 5393289176 6958016389 1564727214
FAT12 5396869407 9189607411 3792738005
FAT16 >32M 5398060173 9020182630 3622122458
FAT16 >32M 5402456231 6781139243 1378683013
FAT16 <32M 5403746686 6031111757 627365072
FAT16 LBA 5404103530 7543005962 2138902433
HPFS - NTFS 5410993130 5628519811 217526682
FAT16 LBA 5465307929 5568688812 103380884
FAT32 5473398843 6737176436 1263777594
FAT32 5489706851 5846725982 357019132
FAT12 5499121496 7803428545 2304307050
HPFS - NTFS 5507469091 5795190923 287721833
FAT32 5509077012 7225591910 1716514899
FAT16 LBA 5517656791 6716098717 1198441927
FAT32 5523172472 7903431077 2380258606
FAT12 5525361327 8192864768 2667503442
FAT32 5560959464 5701623523 140664060
HPFS - NTFS 5573107651 9191023076 3617915426
HPFS - NTFS 5614397190 9117242393 3502845204
FAT16 LBA 5629527201 6619479937 989952737
FAT12 5642893285 6162864080 519970796
FAT16 <32M 5649900733 7433908312 1784007580
FAT16 >32M 5650406125 6771055987 1120649863
FAT32 5696790476 5732082908 35292433
HPFS - NTFS 5704527246 9049737453 3345210208
FAT16 LBA 5714770903 7288281366 1573510464
FAT32 5720082630 9633365847 3913283218
FAT32 LBA 5731930715 9220926567 3488995853
HPFS - NTFS 5761557406 9708006860 3946449455
FAT12 5762615656 7626131943 1863516288
FAT12 5804893661 9529437149 3724543489
FAT32 5805921089 6052094231 246173143
FAT16 <32M 5822585997 7385513534 1562927538
FAT32 5825064843 9855198778 4030133936
FAT12 5831715618 8935203556 3103487939
FAT12 5838346514 9568897000 3730550487
FAT16 <32M 5850913482 8080208689 2229295208
FAT16 >32M 5862491166 8830835914 2968344749
FAT16 >32M 5864156145 8951815918 3087659774
HPFS - NTFS 5877368287 6588371995 711003709
FAT12 5952934509 6048328413 95393905
get_geometry_from_list_part_aux head=1 nbr=122
get_geometry_from_list_part_aux head=8 nbr=17
get_geometry_from_list_part_aux head=16 nbr=8
get_geometry_from_list_part_aux head=32 nbr=6
FAT32 LBA 2 1953525167 1953525166 [WININSTALL]
FAT32, blocksize=32768, 1000 GB / 931 GiB
HFS 19535355 1953525162 1933989808
HFS+ blocksize=4096, 990 GB / 922 GiB
HFS 42576579 43619650 1043072
HFS+ found using backup sector!, 534 MB / 509 MiB
HFS 43619647 44662718 1043072
HFS+ blocksize=2048, 534 MB / 509 MiB
HFS 83734941 83930852 195912
HFS+ found using backup sector!, 100 MB / 95 MiB
HFS 83734942 83930853 195912
HFS 83930849 84126760 195912
HFS+ blocksize=512, 100 MB / 95 MiB
HFS 83930850 84126761 195912
HFS 106695821 106891732 195912
HFS 106695822 106891733 195912
HFS 106891729 107087640 195912
HFS 106891730 107087641 195912
HFS 109996693 111039764 1043072
HFS 111039761 112082832 1043072
FAT12 139041945 1830661276 1691619332
HPFS - NTFS 191456756 1303036998 1111580243
WBFS, 569 GB / 530 GiB
FAT16 >32M 199362721 1362627745 1163265025
FAT12 368518116 368535672 17557
FAT16 >32M 518910117 1421956142 903046026
FAT12 564699834 1437115105 872415272
FAT16 >32M 685446717 1588492742 903046026
FAT12 686976536 1522156189 835179654
FAT32 735038717 739618602 4579886
FAT12 748377418 880227900 131850483
FAT12 751909898 883760380 131850483
FAT16 >32M 763698515 1233422968 469724454
FAT32 LBA 787690538 1902772032 1115081495
HPFS - NTFS 824429409 946263914 121834506
WBFS, 62 GB / 58 GiB
HPFS - NTFS 893484818 1601481389 707996572
HPFS - NTFS 951786542 1436250246 484463705
FAT16 >32M 968593110 1398631862 430038753
FAT12 997495563 1153760146 156264584
FAT16 <32M 1021250880 1025445375 4194496
FAT12 1054230696 1461627839 407397144
FAT16 LBA 1060897795 1572660807 511763013
FAT32 LBA 1169361267 1171458418 2097152 [SDCARD]
FAT32, blocksize=2048, 1073 MB / 1024 MiB
FAT32 LBA 1169361273 1171458424 2097152 [SDCARD]
FAT32 LBA 1174725635 1174856706 131072 [SDCARD]
FAT32, blocksize=512, 67 MB / 64 MiB
FAT32 LBA 1174725641 1174856712 131072 [SDCARD]
FAT16 <32M 1207301879 1832559229 625257351
HPFS - NTFS 1213231576 1718478900 505247325
Linux 1234169254 1234216869 47616 [Compressed]
cramfs, 24 MB / 23 MiB
Linux 1234169255 1234216870 47616 [Compressed]
FAT16 LBA 1246118368 1515278830 269160463
FAT32 LBA 1252349215 1706848819 454499605
FAT16 LBA 1266282712 1535443174 269160463
FAT32 LBA 1399958338 1690619214 290660877
HPFS - NTFS 1436087007 1929073925 492986919
HPFS - NTFS 1459951240 1468636842 8685603
HFS 1508341983 1520101450 11759468
HFS+ found using backup sector!, 6020 MB / 5741 MiB
HFS 1520101447 1531860914 11759468
HFS+ blocksize=2048, 6020 MB / 5741 MiB
HFS 1522083229 1533842696 11759468
FAT32 1527294461 1662645772 135351312
HFS 1533842693 1545602160 11759468
FAT32 LBA 1535557698 1582193937 46636240
FAT12 1566348839 1650366068 84017230
FAT16 <32M 1589746740 1644372558 54625819
FAT12 1590539885 1591573949 1034065
FAT12 1605606202 1737456684 131850483
FAT12 1683599012 1811394967 127795956
FAT16 LBA 1756788871 1899442680 142653810
dir_partition inode=0
FAT: cluster=2(0x2), pos=476854
4 -rwxr-xr-x 0 0 4096 12-Jan-2014 08:41 ._.Trashes
X 3 drwxr-xr-x 0 0 0 12-Jan-2014 08:41 _RASHE~1.BXJ
3 drwxr-xr-x 0 0 0 12-Jan-2014 08:41 .Trashes
5 drwxr-xr-x 0 0 0 12-Jan-2014 08:41 .Spotlight-V100
265 drwxr-xr-x 0 0 0 20-Apr-2014 08:45 .fseventsd
X 204 -rwxr-xr-x 0 0 4096 16-Jan-2014 07:47 _DAT6E~1.000
0 -rwxr-xr-x 0 0 0 16-Jan-2014 07:47 .com.apple.timemachine.donotpresent
204 -rwxr-xr-x 0 0 4096 16-Jan-2014 07:47 ._.com.apple.timemachine.donotpresent
Support for this filesystem hasn't been enable during compilation.
Not an exFAT boot sector.
If any other bits or pieces are need, please let me know.
Michael
FAT16 >32M 1711969843 5625475325 3913505483
Michael
Re: External HDD formatted in error Boot Camp install gone w
I think I have never see a list so long!
Do you see anything related to a 10GB partition near the end of your disk ?
michaelvsprague
No, and a search of the log for "10 GB" returned Not Found result.
I copied the log to a Textedit document, zipped it and attached it here.
Will that help at all? Do I need to run testdisk again, with some other settings enables/active?
Thank you for all your help with this.
Michael
Michael
- 20 April 2014 testdisk log - long.rtf.zip
- (77 KiB) Downloaded 1104 times
michaelvsprague
I ran testdisk again, and selected Apple for disk format. This time it ran in a day, morning to afternoon, and the log seems much smaller.
Log:
Wed Apr 23 22:33:37 2014
OS: Darwin, kernel 13.1.0 (Darwin Kernel Version 13.1.0: Wed Apr 2 23:52:02 PDT 2014; root:xnu-2422.9
Compiler: GCC 4.0
Compilation date: 2013-07-30T14:08:37
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
Disk /dev/disk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/disk1 - 1032 MB / 985 MiB - 2017280 sectors (RO), sector size=512
Disk /dev/disk2 - 523 MB / 498 MiB - 1021696 sectors (RO), sector size=512
Disk /dev/disk3 - 1000 GB / 931 GiB - 1953525168 sectors (RO), sector size=512
Disk /dev/rdisk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/rdisk1 - 1032 MB / 985 MiB - 2017280 sectors (RO), sector size=512
Disk /dev/rdisk2 - 523 MB / 498 MiB - 1021696 sectors (RO), sector size=512
Disk /dev/rdisk3 - 1000 GB / 931 GiB - 1953525168 sectors (RO), sector size=512
Media is opened in read-only.
Disk /dev/disk3 - 1000 GB / 931 GiB (RO)
Partition table type: Mac
Analyse Disk /dev/disk3 - 1000 GB / 931 GiB - 1953525168 sectors (RO)
Bad MAC partition, invalid block0 signature
read_part_mac: bad DPME signature
end log
I still see nothing about a 10 GB partition.
Log:
Compiler: GCC 4.0
end log
michaelvsprague
I guess that was the quick analysis.
Deeper is now running. I'll be back when it is finished to report.
