HP Software RAID + TrueCrypt = RAW Filesystem
Srv02
#1 Post by Srv02 »
Hi!
My name is mike and I got a real big problem. Last week I rebooted my Windows 2008 R2 server and it didn't came up again!
Inside the HP Server there is a HP BL110i RAID controller with 4x500GB HDDs, which are configured as RAID 1+0. There is one big NTFS system partition on it which was encrypted with Truecrypt.
The system stucked at the TC bootloader which didn't accept my encryption password, so I restored the key file and the bootsector with the TC rescue CD, but it only said: "No bootable partitions".
I tried several linux live CDs to decrypt and readout the data, but unfortunately the HP controller is only a software RAID and linux recognizes the 4 disks standalone and not the array itself. Then I set up a USB Stick with a bootable Windows 8.1, decrypted the partition and ran TestDisk with "Rebuild BS" but it didn't work. Boot and backup boot sectors are still bad and not identical.
Then I decided to permanently decrypt the system partition which took me 5 days straight with the TC rescue CD. Then I restored the original boot loader, but this didn't work either.
After another unsuccessful Windows TestDisk run, I am more desperate than in the beginning, because Ontrack EasyRecovery and EaseUS Recovery also didn't find any useful data. The HP Array Configuration Utility says that the RAID works fine.
Great question: Is there ANYTHING I can further do? I really need some data which were not backuped recently.
Very kind regards,
mike
Log:
Sun Apr 20 07:46:32 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=1000148590592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1000148590592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255691063296
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121594 255 63, sector size=512 - HP LOGICAL VOLUME, FW:0.00
Disk /dev/sdb - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - STT_FTM5 6GX25H, S/N:604098AFBC22
Disk /dev/sda - 1000 GB / 931 GiB - HP LOGICAL VOLUME
 1 * HPFS - NTFS              0   1  1 121594  33 60 1953409686
ntfs_boot_sector
filesystem size           9842347813354187942 6221075676106038802
sectors_per_cluster       10 157
mft_lcn                   3440782593 2195104735
mftmirr_lcn               2073577202 209705981
clusters_per_mft_record   56 75
clusters_per_index_record 41 -28
Status: Bad
Status: Bad
Sectors are not identical.
Change partition type:
Not an exFAT boot sector.
ntfs_boot_sector
Status: Bad
Status: Bad
rebuild_NTFS_BS
ntfs_boot_sector
Status: Bad
Status: Bad
rebuild_NTFS_BS
ntfs_boot_sector
Status: Bad
Status: Bad
ntfs_boot_sector
Status: Bad
Status: Bad
Re: HP Software RAID + TrueCrypt = RAW Filesystem
Can you try PhotoRec ?
Running it 15 minutes, check the recovered files, do you get some of your files ?
If there is no file or only false positive/junk, there is probably a problem with the disk decryption, it's why all the disk utilities have failed.
Srv02
#3 Post by Srv02 »
Hi cgrenier! Thank you for your quick reply.
PhotoRec didn't find any files after an 1 hour run.
After the big crash, I booted into Windows and decrypted the partition with Truecrypt to inspect the volume, but it was in the same state as after the permanent decryption process. The weird thing was that the password was accepted like a flaw.
So from my point it is a decrypted piece of junk.
