Partition found but cannot write
antonyunus
#1 Post by antonyunus »
Hi, I have a problem with my external drive, WD Mybook Essential, which is suddenly requesting to be initialized on the disk management, and I made a mistake here, I initialized the drive
After I run TestDisk 7.0 April 2014, the TestDisk found my partition and I was able to confirm that all my files are there, but when I choose write, it give me the error message :
Partition: Write error
attached is the log file generated
Sat May 03 17:56:26 2014
TestDisk 7.0-WIP, Data Recovery Utility, April 2014
Compiler: GCC 4.8, MinGW 3.11
Compilation date: Apr 28 2014 11:23:03
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=256066453504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=239186477056
Disk \\.\PhysicalDrive0 - 256 GB / 238 GiB - CHS 31131 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive C: - 239 GB / 222 GiB - CHS 29079 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive1 - 2000 GB / 1862 GiB - CHS 243197 255 63
NTFS at 0/32/33
filesystem size           3906961408
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS              0  32 33 243197  57 60 3906961408
     NTFS, blocksize=4096, 2000 GB / 1862 GiB
   * HPFS - NTFS              0  32 33 243197  57 60 3906961408
 1 P HPFS - NTFS              0  32 33 243197  57 60 3906961408
write!
Store new MBR code
file_win32_pwrite(92,1,buffer,0(0/0/1)) write err
How do I get the TestDisk to be able to write the partition table ? I am doing the deeper scan now
Thank you
Re: Partition found but cannot write
You don't need to use Deeper Search as your partition has been found.
An antivirus may block the write operation. Restart Windows in safe mode and/or disable your antivirus
antonyunus
#3 Post by antonyunus »
Thanks for the reply,
I managed to bring back the partition with :
1. hdd needs to be connected with the original circuit board (I don't know, but I read on other forums that WD Mybooks are hardware encrypted)
2. with the hdd connected by the circuit board, I found two partition (1 data partition and 1 wd smartware partition)
turns out that when I connected the hdd with docking station, the partition found is the wd smartware partition and cannot be recovered
3. hdd needs to be initialized on disk manager, but when I tried to initialized, it said that hdd is write protected, so I used diskpart command in cmd to clear the write protect attribut
4. I run the TestDisk again and this time the TestDisk can write to the hdd and my data can be accessed again.
Thank you
