Special Case?, Will this work?
spUME6hu
#1 Post by spUME6hu »
I have a USB flash Device that isn't recognized correctly and reads empty.
May be in the wrong forum.
Very new at this and hope for a gifted helpers.
DETAILS:
I have a
Lexar USB 3.0 Flash Device running as Innostor NAND Flash USB Device
It contains a lot of photo's and some files. It used to read and then just started to flash and can't be accessed.
Lexar USB 3.0
Flash Drive
Flash Device
Thumb Drive
LJDS73-32G-133-1444 E
33609-32GGB
0813S
N12610
Reading as Innostor NAND Flash USB Device
Removable (E:)
Partition style Master Boot Record (MBR)
Driver Provider: Microsoft
Driver Date: 6/21/2006
Driver Version: 6.3.9600.16384
Digital Signer: Microsoft
Using a Toshiba Satellite C855-S5367
Portable PC
64 bits
Running Windows 8.1
Events
Timestamp Description
3/14/2014 1:55:55 PM
Device USBSTOR\Disk&Ven_Innostor&Prod_NAND_Flash&Rev_1.00\7&1b82b8c2&0 was configured.
Driver Name: disk.inf
Class Guid: {4D36E967-E325-11CE-BFC1-08002BE10318}
Driver Date: 06/21/2006
Driver Section: disk_install.NT
Driver Rank: 0xFF0006
Matching Device Id: GenDisk
Outranked Drivers: disk.inf:GenDisk:00FF2002
Device Updated: false
Device USBSTOR\Disk&Ven_Innostor&Prod_NAND_Flash&Rev_1.00\7&1b82b8c2&0 was started.
Service: disk
Lower Filters:
Upper Filters:
4/21/2014 1:59:53 AM
Device USBSTOR\DISK&VEN_INNOSTOR&PROD_NAND_FLASH&REV_1.00\7&1B82B8C2&0 was deleted.
4/21/2014 2:02:18 AM
Service: disk
Lower Filters:
Upper Filters:
Re: Special Case?, Will this work?
Try PhotoRec on the PhysicalDrive corresponding to your device. Does it work ?
spUME6hu
#3 Post by spUME6hu »
Neither Photo or Test recognize the USB. Started both under ADMIN. does this product work on 8.1?
