Ubuntu/Linux Mint Installer wipe out on a SSD disk
edouardlopez
#1 Post by edouardlopez »
I'm trying to restore my data after hitting issue #1265192: Reinstallation wipes out all/other partitions, also described in Why “remove Ubuntu 12.04 and replace it with Ubuntu 13.10” means to use all of the disk and lose all data? [closed].
Partition tables
My disk is a ~100Gb Corsair disk. Previously to the events, the parition table was :
/dev/sda1    ext4          7.5Go      /
/dev/sda2    extended
/dev/sda5    ext4          2Go        /home
/dev/sda6    ext4          100Go      /mnt/data
/dev/sda7    swap          2Go
After realizing there was no confirmation pop-up I close the installer to prevent further operation. However, I got a new partition's table :
/dev/sda1    ext4          108Go      /
/dev/sda2    extended
/dev/sda5    swap          4Go
Gpart
I went to the Ubuntu Data Recovery page and tried to use gpart, which detect 4 partition but doesn't give much information :
sudo gpart /dev/sda
Begin scan...
End scan.
Checking partitions...
Ok.
Guessed primary partition table:
Primary partition(1)
   type: 000(0x00)(unused)
   size: 0mb #s(0) s(0-0)
   chs:  (0/0/0)-(0/0/0)d (0/0/0)-(0/0/0)r
Primary partition(2)
Primary partition(3)
Primary partition(4)
Using the -v flag give a little more but still not much :
sudo gpart -v /dev/sda
dev(/dev/sda) mss(512) chs(14593/255/63)(LBA) #s(234436545) size(114470mb)
* Warning: strange partition table magic 0x0000.
   type: 131(0x83)(Linux ext2 filesystem)
   size: -1061158912mb #s(-2173253452288) s(972733539046918144-972731365793465855)
   chs:  (0/32/33)-(1023/254/63)d (60549862374535/212/14)-(60549727095765/17/60)r
   hex:  00 20 21 00 83 FE FF FF 00 08 00 00 00 D8 7F 0D 00 FE FF FF 05 FE FF FF
   type: 002(0x02)(XENIX / filesystem)
   chs:  (269/231/63)-(256/96/57)d (0/0/0)-(0/0/0)r
   hex:  FE E7 7F 0D 02 60 79 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
   size: 21mb #s(43605) s(0-43604)
   chs:  (0/0/0)-(0/0/0)d (0/0/0)-(2/182/9)r
   hex:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA 00 00 00 00 00 00
   hex:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Testdik
When running testdisk Analyse tool here is what I got :
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63
 1 P Linux                    0  32 33 14097 252 43  226482176
 2 E extended             14098  30 11 14593  66  1    7954434
 5 L Linux Swap           14098  30 13 14593  66  1    7954432
Quick search
 1 * Linux                    0  32 33 14097 252 43  226482176
 2 P Linux Swap           14098  30 13 14593  66  1    7954432
Deeper Search
Running a deeper search doesn't seems to give more, here a screenshot during :
And at the end I got back to this, that look like initial Analyse screen :
   Linux                 1215 203 13 14338  75  9  210812928
Clone
I'm creating a disk image using dd as a friend suggest the disk could try to reorganize sector even if not currenlty used (something related to TRIM flag on the disk) :
outf="/media/mint/51ee8de5-b1a9-4d57-9a94-24b9b1d0d10b/sdd-disk.img";
sudo dd if=/dev/sda of="$outf" & ddpid=$!
Questions
  • At the bottom of the Analyse tool I got a A: add partition entry. Should I rebuild manually my partition table ?
  • Does the fact that my disk is an SSD could explain why I got few information
  • What can I try next ?
Re: Ubuntu/Linux Mint Installer wipe out on a SSD disk
Try to list the content of each partition: select a partition and press 'p'.
This way you may be able to recover your partition.
edouardlopez
#3 Post by edouardlopez »
cgrenier wrote:Try to list the content of each partition: select a partition and press 'p'.
Here is what I do, output below :
  1. run testdisk
  2. create a new log file
  3. select & proceed > Disk /dev/sda - 120 GB / 111 GiB - Corsair Force GT
  4. select Intel/PC partition
  5. Analyse current partition structure and search for lost partitions
  6. Run Quick Search
  7. Select biggest partition (from current partition table, not older one!)
  8. List files
Analyse
Quick Search
ext4 blocksize=4096 Large file Sparse superblock, 115 GB / 107 GiB
List file
Got only two files, not even a file system.
>drwxr-xr-x     0     0      4096 19-May-2014 16:08 .
 drwxr-xr-x     0     0      4096 19-May-2014 16:08 ..
 drwx------     0     0     16384 19-May-2014 14:43 lost+found
 -rw-r--r--     0     0     21763 19-May-2014 16:52 testdisk.log
Previous Partition table
The one I'm trying to get data from.
Current Partition table
The one created by the Ubuntu installer.
appalbarry
#4 Post by appalbarry »
By way of followup, I had the same thing happen with the Installer for Mint 17 - instead of just upgrading the OS it wiped out every partition on the drive.
Testdisk wasn't able to find the old partitions, so I now have what looks like an very long PhotoRec session pulling files off.
Anyhow - please add your name to the bug over at Mint's Bugtracker:
https://bugs.launchpad.net/linuxmint/+bug/1325786
