TestDisk damaged my Disk
Dear all here,
My Disk was fine no thing wrong with it, i needed to move it to another computer.
it appears as (invalid dynamic) .. so i tried your solution here
http://mypkb.wordpress.com/2007/03/28/h ... sic-disks/
i did exactly step by step.. i rebooted my computer after "make the dynamic to basic drive conversion happen"
but unfortuntley my Disk appears like that
http://i57.tinypic.com/2zsb1ua.jpg
SO PLEASE I WANT YOUR HELP TO RESTORE MY DISK STRUCTURE AS IT WAS.
i did that step as says (It displays the current structure. Select Backup first, then Proceed. Backing up first is a good idea if you later want to restore the drive’s partition structure)
PLEASE I WANT TO RESTORE MY DISK TO BE RIGHT AS IT WAS BEFORE.
Help !
Help !
Re: TestDisk damaged my Disk
Testdisk doesn't touch your file system and data.
TestDisk only recovers partitions and will never touch data nor underlying data.
Please don't write or change anything to your disk.
Dynamic disks don't use an intel partition table this way like a normal MBR disks do!
Restore of a backup of your partition table works if you're running Quick Search and stop it pressing enter.
Pressing L for load and confirming, you'll get back to your previous situation.
But you shouldn't do it now.
Do you still have your testdisk.log before your current situation occured?
Please run TestDisk Analyse and Quick Search!
Stop testdisk and use quit to close it.
Copy and paste the content of your testdisk.log into your next post!
Thank you very much for your kindness Help
Actually my Disk becomes 1 partition and it seems there is Unknown Data.
TestDisk.log contains many text, Here you are the log file
Thanks again.
In fact i think i chose Intel as the program tells me.Dynamic disks don't use an intel partition table this way like a normal MBR disks do
Wed May 28 15:15:13 2014
TestDisk 7.0-WIP, Data Recovery Utility, May 2014
Compilation date: 2014-05-20T10:35:40
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=290285682688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=209715200000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=740719332864
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM0 ST500DM002-1BD14, S/N:Z2AW6XSS, FW:KC45
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - WDC WD7500BPVT-80HXZ, S/N:WD-WX91A91Z0525, FW:01.0
Disk /dev/sdb - 750 GB / 698 GiB - WDC WD7500BPVT-80HXZ
Analyse Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63
FAT32 at 0/1/1
Info: size boot_sector 1446717447, partition 1446717447
FAT1 : 32-176590
FAT2 : 176591-353149
start_rootdir : 353150 root cluster : 2
Data : 353150-1446717437
sectors : 1446717447
cluster_size : 64
no_of_cluster : 22599442 (2 - 22599443)
fat_length 176559 calculated 176559
FAT differs, FAT sectors=560-576/176559
1 * FAT32 LBA 0 1 1 90053 254 63 1446717447 [FD_BETA9SR2]
FAT32 at 0/1/1
FAT1 : 32-176590
cluster_size : 64
FAT32 at 0/1/1
FAT32, blocksize=32768, 740 GB / 689 GiB
file_pread(5,2,buffer,1465149440(91201/85/21)) lseek err Invalid argument
file_pread(5,1,buffer,1465149440(91201/85/21)) lseek err Invalid argument
file_pread(5,1,buffer,1465149439(91201/85/20)) lseek err Invalid argument
file_pread(5,14,buffer,1465149441(91201/85/22)) lseek err Invalid argument
file_pread(5,3,buffer,1465149455(91201/85/36)) lseek err Invalid argument
file_pread(5,3,buffer,1465149502(91201/86/20)) lseek err Invalid argument
file_pread(5,8,buffer,1465149518(91201/86/36)) lseek err Invalid argument
file_pread(5,11,buffer,1465149565(91201/87/20)) lseek err Invalid argument
file_pread(5,2,buffer,1465151487(91201/117/52)) lseek err Invalid argument
interface_load
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63 Wed May 28 14:56:06 2014
1 P W2K Dynamic/SFS 0 1 1 0 32 32 1985
2 * W2K Dynamic/SFS 0 32 33 12 223 19 204800
3 P W2K Dynamic/SFS 12 223 20 12748 86 10 204595200
4 P W2K Dynamic/SFS 12748 86 11 91201 48 31 1260345072
check_part_i386 1 type 42: no test
check_part_i386 2 type 42: no test
check_part_i386 3 type 42: no test
check_part_i386 4 type 42: no test
Invalid partition structure.
FAT32 at 0/1/1
FAT1 : 32-176590
cluster_size : 64
FAT32 at 0/1/1
FAT1 : 32-176590
cluster_size : 64
FAT32 at 0/1/1
interface_load
interface_load
FAT32 at 0/1/1
FAT1 : 32-176590
cluster_size : 64
FAT32 at 0/1/1
FAT1 : 32-176590
cluster_size : 64
FAT32 at 0/1/1
interface_load
interface_load
I forgot to say that i tried in the 1st time to "load" the backup but it tells .. somthing (bad).
Please run Deeper Search.
Might be possible that Deeper Search finds more partitions, mark them and press p to list your data.
Please post your testdisk.log again.
My Partition found...
Thank you
Please how to restore my partition???
Thank you
Thu May 29 20:39:15 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=740719332864
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
FAT32 at 0/1/1
FAT1 : 32-176590
cluster_size : 64
FAT32 at 0/1/1
FAT1 : 32-176590
cluster_size : 64
FAT32 at 0/1/1
dir_partition inode=0
FAT: cluster=2(0x2), pos=353213
71761928 -rwxr-xr-x 0 0 1183409664 23-Feb-1918 10:58 ネニユ
239495680 drwxr-xr-x 0 0 877037568 29-Feb-1980 22:03 3@ᅥF.fノF
6744064 -rwxr-xr-x 0 0 4294919952 14-Feb-1983 13:51 │ᅬ`
140832907 -r-xr-xr-x 0 0 1717044330 26-Dec-1970 04:35 ナ�u.hワ
9603173 dr-xr-xr-x 0 0 37766 10-Dec-2015 00:00 ᄋF@テ�.ネニ
3091 drwxr-xr-x 0 0 0 28-May-2014 15:02 $RECYCLE.BIN
191269222 -rwxr-xr-x 0 0 2280148550 10-Mar-1980 12:50 タヤ
477111 -rwxr-xr-x 0 0 2724745318 17-Aug-1987 14:16 _
420556 dr-xr-xr-x 0 0 3906679652 24-May-1946 21:15 ᅩᅩᅩᅩヒ�Uヒ.↓SV
118458624 -rwxr-xr-x 0 0 24381509 2-Jan-1980 00:36 @fノFPjX.ᅥF
36488 -rwxr-xr-x 0 0 145 31-May-1989 16:24 ニヤ
65744 -r-xr-xr-x 0 0 1347485696 7-Nov-1915 03:39 →ネ゙モ
57036358 -rwxr-xr-x 0 0 6179304 1-Oct-1912 04:02 │oG��fᄊ.ヌ
FAT32 at 0/1/1
FAT1 : 32-176590
cluster_size : 64
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 32-176590
cluster_size : 64
FAT differs, FAT sectors=544-560/176559
FAT32 at 0/1/7
NTFS at 0/32/33
filesystem size 204800
mft_lcn 8533
mftmirr_lcn 2
HPFS - NTFS 0 32 33 12 223 19 204800
NTFS at 12/223/19
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/20
filesystem size 204595200
mftmirr_lcn 2
HPFS - NTFS 12 223 20 12748 86 10 204595200
NTFS, blocksize=4096, 104 GB / 97 GiB
NTFS at 12748/86/11
filesystem size 614400000
mftmirr_lcn 2
HPFS - NTFS 12748 86 11 50992 247 7 614400000
NTFS, blocksize=4096, 314 GB / 292 GiB
NTFS at 50992/247/8
filesystem size 307200000
mftmirr_lcn 2
HPFS - NTFS 50992 247 8 70115 72 37 307200000
NTFS, blocksize=4096, 157 GB / 146 GiB
NTFS at 70115/72/38
filesystem size 338741248
mftmirr_lcn 2
HPFS - NTFS 70115 72 38 91200 242 50 338741248
NTFS, blocksize=4096, 173 GB / 161 GiB
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 28-Apr-2014 18:35 .
5 dr-xr-xr-x 0 0 0 28-Apr-2014 18:35 ..
101 dr-xr-xr-x 0 0 0 28-Apr-2014 18:35 $RECYCLE.BIN
35 dr-xr-xr-x 0 0 0 13-Feb-2013 02:33 Boot
98 dr-xr-xr-x 0 0 0 18-Oct-2013 11:58 System Volume Information
97 -r--r--r-- 0 0 8192 12-Feb-2013 10:44 BOOTSECT.BAK
86 -r--r--r-- 0 0 383786 20-Nov-2010 05:40 bootmgr
partition_save
Results saved in backup.log.
partition_save
5 dr-xr-xr-x 0 0 0 28-Apr-2014 12:00 .
5 dr-xr-xr-x 0 0 0 28-Apr-2014 12:00 ..
37 dr-xr-xr-x 0 0 0 28-Apr-2014 18:35 $RECYCLE.BIN
90309 dr-xr-xr-x 0 0 0 30-Dec-2013 11:12 Edu CDs
601 dr-xr-xr-x 0 0 0 20-Jan-2014 02:08 FFOutput
124138 dr-xr-xr-x 0 0 0 30-Dec-2013 12:25 org_files
35 dr-xr-xr-x 0 0 0 18-Oct-2013 11:58 System Volume Information
208336 dr-xr-xr-x 0 0 0 30-Dec-2013 12:51 TXT
608 dr-xr-xr-x 0 0 0 30-Jan-2014 12:02 Temp
205600 dr-xr-xr-x 0 0 0 6-Apr-2014 20:44 Tor world
208400 dr-xr-xr-x 0 0 0 20-Jan-2014 02:12 USB
6147 dr-xr-xr-x 0 0 0 1-Apr-2014 18:10 android
6253 dr-xr-xr-x 0 0 0 30-Dec-2013 09:33 applications
226954 dr-xr-xr-x 0 0 0 30-Dec-2013 17:44 biz
6720 dr-xr-xr-x 0 0 0 30-Dec-2013 09:33 certificate
6780 dr-xr-xr-x 0 0 0 30-Dec-2013 10:47 computer
76368 dr-xr-xr-x 0 0 0 21-Feb-2014 20:24 courses
90290 dr-xr-xr-x 0 0 0 30-Dec-2013 11:11 cracks & serials
90312 dr-xr-xr-x 0 0 0 30-Dec-2013 11:20 english
97516 dr-xr-xr-x 0 0 0 30-Dec-2013 11:28 faleh
102391 dr-xr-xr-x 0 0 0 30-Dec-2013 11:32 game
104644 dr-xr-xr-x 0 0 0 30-Dec-2013 11:38 ghost
106359 dr-xr-xr-x 0 0 0 6-Feb-2014 03:18 images
121960 dr-xr-xr-x 0 0 0 30-Dec-2013 12:25 internet
124216 dr-xr-xr-x 0 0 0 30-Dec-2013 12:29 learn
134785 dr-xr-xr-x 0 0 0 30-Dec-2013 12:29 maintenance
134995 dr-xr-xr-x 0 0 0 14-Mar-2014 23:44 microsoft learning
109 dr-xr-xr-x 0 0 0 4-Mar-2014 03:09 mine
135816 dr-xr-xr-x 0 0 0 4-Mar-2014 03:08 needed
135848 dr-xr-xr-x 0 0 0 30-Dec-2013 12:38 network
136357 dr-xr-xr-x 0 0 0 30-Dec-2013 12:38 npp+nsc
136399 dr-xr-xr-x 0 0 0 30-Dec-2013 12:38 others
136903 dr-xr-xr-x 0 0 0 30-Dec-2013 12:38 product-admin_online_humax9110
136909 dr-xr-xr-x 0 0 0 23-Sep-2012 20:16 protect
136910 dr-xr-xr-x 0 0 0 30-Dec-2013 12:47 rubbish
185956 dr-xr-xr-x 0 0 0 30-Dec-2013 12:47 security
47 dr-xr-xr-x 0 0 0 24-Mar-2014 07:38 sh sh sh
186009 dr-xr-xr-x 0 0 0 30-Dec-2013 12:49 sites templates
204105 dr-xr-xr-x 0 0 0 30-Dec-2013 12:50 tech
223053 dr-xr-xr-x 0 0 0 30-Dec-2013 12:55 work in sites
227159 dr-xr-xr-x 0 0 0 30-Dec-2013 12:55 forman
227193 dr-xr-xr-x 0 0 0 2-Mar-2014 19:14 shokrat
227593 dr-xr-xr-x 0 0 0 30-Dec-2013 12:56 hi sens
227884 dr-xr-xr-x 0 0 0 30-Dec-2013 12:56 learned
228858 dr-xr-xr-x 0 0 0 30-Dec-2013 12:56 hewar
229619 dr-xr-xr-x 0 0 0 30-Dec-2013 12:56 deros
229623 dr-xr-xr-x 0 0 0 30-Dec-2013 12:56 styled
229928 dr-xr-xr-x 0 0 0 30-Dec-2013 12:57 ehsa
229946 dr-xr-xr-x 0 0 0 30-Dec-2013 12:57 nett
89 -r--r--r-- 0 0 51414 6-Apr-2013 16:26 2013-02-22-310.jpg
92 -r--r--r-- 0 0 51646 6-Apr-2013 16:26 2013-02-22-315.jpg
93 -r--r--r-- 0 0 53058 6-Apr-2013 16:26 2013-02-22-316.jpg
96 -r--r--r-- 0 0 81654 6-Apr-2013 16:27 2013-02-22-343.jpg
97 -r--r--r-- 0 0 97757 6-Apr-2013 16:34 2013-02-22-358.jpg
98 -r--r--r-- 0 0 178615 7-Nov-2012 22:56 2222222222222222.jpg
99 -r--r--r-- 0 0 93 1-Apr-2014 17:57 4u.txt
100 -r--r--r-- 0 0 0 4-Aug-2013 09:12 66732_436586289789329_1437818599_n.jpg
106356 -r--r--r-- 0 0 377840583 20-Dec-2010 19:38 Hirens.BootCD.12.0.zip
124137 -r--r--r-- 0 0 188910 7-Apr-2010 04:21 org.htm
208398 -r--r--r-- 0 0 156728 11-Feb-2013 05:59 Untitled page.one
208399 -r--r--r-- 0 0 22585189 27-Sep-2012 21:20 Untitled.wma
6714 -r--r--r-- 0 0 654 26-Feb-2012 07:58 asus utility.txt
104913 -r--r--r-- 0 0 3258956 23-Jan-2013 02:49 h.mp3
106357 -r--r--r-- 0 0 243804 14-Aug-2012 21:08 how-hd.docx
106358 -r--r--r-- 0 0 132978928 1-Apr-2013 06:24 hp basic driver xp printers and scanners.exe
134 -r--r--r-- 0 0 4931 11-Jan-2014 02:38 maghagha1.txt
137 -r--r--r-- 0 0 4392 11-Jan-2014 02:38 maghagha2.txt
136902 -r--r--r-- 0 0 1241201 16-Sep-2007 09:58 prmjyat.zip
136908 -r--r--r-- 0 0 12179 9-Apr-2010 22:34 product-admin_online_humax9110.zip
204104 -r--r--r-- 0 0 2317086 4-Oct-2007 20:35 teaqny_magazine1.zip
223052 -r--r--r-- 0 0 52 1-Dec-2009 09:22 viewer.txt
226953 -r--r--r-- 0 0 1994398 11-Jul-2011 02:05 info_838.mht
227158 -r--r--r-- 0 0 5719842 11-Sep-2008 12:59 traveller.pdf
229927 -r--r--r-- 0 0 17706 15-Aug-2012 04:52 moderya.docx
229944 -r--r--r-- 0 0 88 14-May-2012 02:41 mm.txt
229945 -r--r--r-- 0 0 89 3-Apr-2011 21:22 mnshed.txt
227157 -r--r--r-- 0 0 1988 30-Mar-2012 18:36 basala.txt
223 dr-xr-xr-x 0 0 0 28-Apr-2014 18:35 $RECYCLE.BIN
227 dr-xr-xr-x 0 0 0 17-Dec-2012 09:04 ATTEQANY-PC
45083 dr-xr-xr-x 0 0 0 6-Apr-2014 18:43 New folder
44653 dr-xr-xr-x 0 0 0 2-Feb-2014 23:29 bha
44640 dr-xr-xr-x 0 0 0 19-Nov-2013 04:08 bha2
924 dr-xr-xr-x 0 0 0 28-Feb-2012 01:38 games
60356 dr-xr-xr-x 0 0 0 4-Apr-2014 17:31 kasr
33991 dr-xr-xr-x 0 0 0 6-Apr-2014 18:41 last downloads
6882 dr-xr-xr-x 0 0 0 15-Apr-2013 23:16 mhsn
1072 dr-xr-xr-x 0 0 0 5-Apr-2014 00:49 mine
953 dr-xr-xr-x 0 0 0 16-Dec-2013 19:12 mobile
1137 dr-xr-xr-x 0 0 0 21-May-2012 14:40 non
43352 dr-xr-xr-x 0 0 0 15-Feb-2014 01:13 rubbish
6822 dr-xr-xr-x 0 0 0 10-Mar-2012 07:26 sites index
244 dr-xr-xr-x 0 0 0 14-Mar-2014 01:40 child
43389 dr-xr-xr-x 0 0 0 9-Nov-2013 02:45 hamla
43393 dr-xr-xr-x 0 0 0 9-Nov-2013 02:52 sheaa
40652 dr-xr-xr-x 0 0 0 25-Sep-2013 07:16 ala
40661 dr-xr-xr-x 0 0 0 25-Sep-2013 07:22 zkryat
36546 dr-xr-xr-x 0 0 0 10-Jan-2014 02:10 swara
43381 dr-xr-xr-x 0 0 0 9-Nov-2013 03:26 dehka
1171 dr-xr-xr-x 0 0 0 9-Mar-2012 18:52 farhy
40678 dr-xr-xr-x 0 0 0 25-Sep-2013 07:24 flashes
40774 dr-xr-xr-x 0 0 0 25-Sep-2013 07:25 nocels
40816 dr-xr-xr-x 0 0 0 6-Apr-2014 20:11 kartoon
27090 dr-xr-xr-x 0 0 0 28-Feb-2012 17:13 neqab
724 dr-xr-xr-x 0 0 0 30-Nov-2010 13:29 masjed
34454 dr-xr-xr-x 0 0 0 20-Feb-2014 04:46 political
1050 dr-xr-xr-x 0 0 0 10-Mar-2012 16:29 vidoos
50648 dr-xr-xr-x 0 0 0 6-Apr-2014 18:46 montage
27392 -r--r--r-- 0 0 528 8-Apr-2012 21:23 MediaID.bin
59020 -r--r--r-- 0 0 112750609 7-Sep-2013 07:13 Winning Eleven 3.rar
47 -r--r--r-- 0 0 4535372 23-Mar-2014 10:24 alraad.rm
16560 dr-xr-xr-x 0 0 0 28-Apr-2014 18:35 $RECYCLE.BIN
35 dr-xr-xr-x 0 0 0 8-Apr-2014 01:05 System Volume Information
16613 dr-xr-xr-x 0 0 0 24-Jan-2014 05:31 Temp
179 dr-xr-xr-x 0 0 0 30-Dec-2013 16:03 qdem
258 dr-xr-xr-x 0 0 0 30-Dec-2013 16:03 webo
375 dr-xr-xr-x 0 0 0 6-Feb-2014 22:47 ebthal
385 dr-xr-xr-x 0 0 0 30-Dec-2013 16:03 ادعية
16519 dr-xr-xr-x 0 0 0 30-Dec-2013 17:41 warsha
16550 -r--r--r-- 0 0 11825908 12-Apr-2013 21:40 ar.zip
16551 -r--r--r-- 0 0 6795278 12-Apr-2011 21:02 YouTube - fgfd.flv
16552 -r--r--r-- 0 0 11057043 12-Mar-2011 05:21 YouTube - dfgARABS GOT TALENT.flv
16549 -r--r--r-- 0 0 108 6-Apr-2014 20:16 ffds.txt
16554 -r--r--r-- 0 0 52968 19-Apr-2009 03:35 dfgfd.doc
16555 -r--r--r-- 0 0 8002666 24-Jun-2011 04:19 sdfgh.rm
57 -r--r--r-- 0 0 3418263 1-Mar-2014 19:47 sdgss.mp4
16556 -r--r--r-- 0 0 12191645 9-Mar-2011 03:58 ufg.flv
16557 -r--r--r-- 0 0 3516804 19-Feb-2011 04:38 yut.mp4
Thanks for your info.
As far as I've seen your disk was created as a dynamic disk.
Dynamic disks, created from the scratch, differ to accidentally converted disks.
The difference mentionned above is, an Intel MBR disk can only contain up to 4 primary partitions or 3 primary and 1 extended partition for logical partitions/volumes.
An extended partition needs a little bit space to be created.
If a dynamic disk is created from the scratch, there is no space left to create an extended partition.
That's why in your case you can recover up to 4 partitions.
But your disk contain 5 partition.
I'd like to show you an example:
Your results:
Your FAT32-Partition will be ignored because is not necessary.
Red marked values on the left side are displaying the start sector of a partition.
Red marked values at the right side displaying the end sector of a partition.
For example, the first partition ends at sector 19 and your second partition starts at sector 20.
That's why, there is no space for an extended partition.
It easily means, you're only able to recover up to 4 primary partitions.
If you'd only recover 3 partitions, you'll get unallocated space to create an extended partition.
But it's not a big problem, because testdisk offers you a solution to copy files from partitions as a backup.
My suggestion is not to recover 5 partitions but 3.
After partition recovery of 3 partitions, you can create an extended partition and create 2 logical partitions (if you'd like you can also create 1 logical partition) and copy your data back!
Recovery procedure may look like:
Copy your data of the last two partitions to another healthy disk/partition/ folder.
Standard folder to copy data to, is your testdisk folder.
If you list your data of your fourth/fifth partition and pressing a will mark all data for copying. marking that two dots in the upper area of your testdisk display and pressing enter, you'll get one directory up until you'll get to your disk selection.
You can select another disk, partition to copy your data to.
If you'd like to copy data into a specific folder as a destination you can mark any appropriate folder and enter it, using the right arrow on you keyboard.
After backing up your data of the last two partitions, you can recover three partitions.
Procedur will look like:
* HPFS - NTFS 0 32 33 12 223 19 204800
P HPFS - NTFS 12 223 20 12748 86 10 204595200
P HPFS - NTFS 12748 86 11 50992 247 7 614400000
If you mark a partition, you can set the status of a partition as primary activ (it's a star *) and P for primary only not bootable using the left or right arrow key on your keyboard.
You can watch it at the right side.
Please set all 3 partitions for recovery as mentionned above!
Don't forget to copy/backup your data of the last two partitions first.
Press enter and confirm at WRITE.
If there should be a problem about any boot sector, you'll receive a message to repair it.
Confirm at BackupBS to copy the backup of your boot over your boot secor.
Your boot sector will be repaired.
Finish TestDisk using Quit and restart your PC.
Now you can create an extended partition on your unallocated space and create locical partitions to copy your data back.
This procedure changed your dynamic disk to a basic disk.
At the beginning you have a windows boot partition.
Deleting it, causes unallocated space and looks somehow strange.
But if you'd like to go another way to recover your data, please let me know.
Your results:
Your disk contain 5 partitions.Results
In fact i dont know how to thank you for your kindness & help.
i would say that: what is important -for me- in that Disk is only 3 partitions, the last 3 partitions
that one
and that
and the last
So.. could i recover that 3 partition directly? so i don't need any copy or data backup? and after that i find my Data ?
my steps is:
1- Mark the 3 partitions for recovery ..and set the partitions as primary not bootable (press p).
2- press enter @ (write)
while that
3- if there is any sector problem a messege will appear to repair .. then confirm to copy the backup over boot sector
quit & restart
so i will get a basic Disk of 3 partitions with it's Data.
i'm not using that Disk for boot Windows, just wanna to keep these Data in it.
that is what i learnt from you my dear.
tell me Ok to start doing that.
Best Regards
that one
my steps is:
while that
quit & restart
Best Regards
It could be necessary that you have to set your first and second partition to D for deleted.
Works the same way like setting partitions up as primary.
Otherwise testdisk will try to add them to your partition table too.
Set your last three partitions to P for primary (If not already automatically done)) and write them into your partition table using Write.
Only in case if you get a message that a boot sector should be repaired, confirm at Backup BS.
But only in case!
Quit testdisk and restart!
But only in case!
I can't delete 1st and 2nd partitions , when i use (array) it shows (*=bootable) and (p=primary) and L=load.. but (E=extend and D=delete) does not appears.
so i can not delete the partitions \
Who is online
Users browsing this forum: Google [Bot] and 0 guests
