Can you please check my test.log file?  It is saying that it cannot find the partition. For background, I was attempting to expand the non-boot data drive formatted NTFS with Partition Magic and upon reboot the data drive now displays as RAW.
I have searched and deep searched the partition but no luck.
Any help will be appreciated.
Fri May 30 12:53:16 2014
TestDisk 7.0-WIP, Data Recovery Utility, May 2014
OS: Windows Server 2008 R2 (7601) SP1
Compiler: GCC 4.8, MinGW 3.11
Compilation date: May 29 2014 15:18:18
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3999688294400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=524183142400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3166732288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=8434493440
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=3000590401536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=1276375990272
Disk \\.\PhysicalDrive0 - 3999 GB / 3725 GiB - CHS 486267 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Drive C: - 524 GB / 488 GiB - CHS 63728 255 63, sector size=512
Drive E: - 3166 MB / 3020 MiB - CHS 755 64 32, sector size=2048
Drive F: - 8434 MB / 8043 MiB - CHS 2010 64 32, sector size=2048
Drive J: - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Drive M: - 1276 GB / 1188 GiB - CHS 155177 255 63, sector size=512
Analyse Drive M: - 1276 GB / 1188 GiB - CHS 155177 255 63
Geometry from i386 MBR: head=115 sector=52
BAD_RS LBA=1936269394 5382406
check_part_i386 1 type 4F: no test
BAD_RS LBA=1917848077 5967333
check_part_i386 2 type 73: no test
BAD_RS LBA=1818575915 5855017
check_part_i386 3 type 2B: no test
BAD_RS LBA=2844524554 5982593
check_part_i386 4 type 61: no test
 1 * Sys=4F               120527  49 53 234813 237 34 1836016416
Bad relative sector.
 2 * Sys=73               119380 132 62 153270  41 37  544437093
 3 * Sys=2B               113201  29 24 147074 114 59  544175136
 4 * SpeedStor            177063 118 26 177066 225 63      54974
						RAW disk for NTFS drive inability to find parititon
Re: RAW disk for NTFS drive inability to find parititon
Did you use testdisk 64bit?
Please note:
If your OS is Vista, Win7, Win8/8.1 and Windows Server 2008 R2. you can run testdisk 32bit.
Would it be possible to repeat your diagnose using the 32bit version?
Select your physically disk and not a drive.
Copy and paste the content of your testdisk.log again!
						Please note:
WOW64 (Windows On Windows) means, it provides a 32bit emulation running 32bit programs.Windows 64-bit Use only on systems lacking WoW64 as some features are missing.
