hello
i need help!!, my second harddisk 500gb, there are 3 partition:
sdb1  60gb  for windows  ntfs
sdb2  400gb for my-data  ext4
sdb3  7mb for (i dont know) ntfs
durant installation windows 7 , said cant to install to 60gb "Setup was unable to create a new system partition...bla bla"
so i go to link :  http://www.sevenforums.com/installation ... ition.html
i did command of windows:
DiskPart <ENTER>
list disk <ENTER>  (i select volume is 0 it's 60gb, and volume 1 it is 400gb (ext4)
select volume 0 <ENTER>
clean <ENTER>
create partition primary align=1024 <ENTER>
format fs=ntfs <ENTER> (Will Take a While)   this is started to formated until 2% and i stop because i was understand it's formated all partition of my second harddisk!!! so i close terminal of ms dos windows and exit the installation windows 7 and i check my linux form my first harddisk and said that second harddisk is not found...so i open this topic to ask you to help me for recovery my second harddisk 500gb HOW.....
testfdisk can recovery???? please respond me,..,... sigh sigh sigh
I HATEEEE WINDOWSS 7 because it is not clear  DAMNNN..
then i hope to recovery.....sigh sigh
						windows7 formated ntfs to ext4!!
Re: windows7 formated ntfs to ext4!!
well its possible,please read the manual first,
a lot of people are busy to explain to everyone the processes.
What do you see after fdsik -l command?
