I Tried Quick Search and Deeper Search and got this message
wrong geometry on flash disk
Re: wrong geometry on flash disk
The last thing you can do, to use partition table type None and test a rebuild BS.
If it doesn't work, you need data recovery software.
Start TestDisk.
Confirm at Create Log with enter.
Select your flash disk and press enter.
Choose partition table type None.
If your partition is listed as Unknown, choose Type and press enter.
Select your previous file system FAT32 and press enter.
Confirm at Boot with enter also.
Infos will follow.
Start TestDisk.
Infos will follow.
Bad
Bad
First sectors (Boot code and partition information) are not identical.
I have no idea did you run Rebuild BS or not?
If you were running Rebuild BS with no result, you should test data recovery software limke PhotoRec.
I ran Rebuild BS and it finished in few seconds, then I took the screenshot.
Now, I'm running photorec.
