I posted this problem already in the German section but I didn't get any replies, so I try my luck here.
I have a external HD (WD, 1TB), which I did format under Ubuntu (probably 12.04). I then made a partition which had the same size of the HD and encrypted it with Truecrypt. Some days ago, I connected the HD to my PC and couldn't see any partition to mount with Truecrypt. I tried to mount the disk, without any success.
I analysed the HD with testdisk and these are the results:
Thu Jun 5 15:17:43 2014
OS: Linux, kernel 3.5.0-47-generic (#71-Ubuntu SMP Tue Feb 18 23:59:30 UTC 2014) i686
Compiler: GCC 4.7
Compilation date: 2012-10-01T12:56:22
ext2fs lib: 1.42.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size 976773168 sectors
/dev/sda: user_max 976773168 sectors
/dev/sda: dco 976773168 sectors
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000BEVT-22A0RT0, S/N:WD-WXK1A10N3804, FW:01.01A01
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WD 10EADS External, FW:1.75
Disk /dev/mapper/cryptswap1 - 5999 MB / 5722 MiB - CHS 11718656 1 1, sector size=512
Disk /dev/dm-0 - 5999 MB / 5722 MiB - CHS 11718656 1 1, sector size=512
Disk /dev/sdb - 1000 GB / 931 GiB - WD 10EADS External
Partition table type: None
P Unknown 0 0 1 121601 80 63 1953525168
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/7452, s_mnt_count=161/31, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 244190000
recover_EXT2: part_size 1953520000
ext4 0 0 62 121600 254 59 1953520000 [HD_1TB]
EXT4 Large file Sparse superblock Backup superblock, 1000 GB / 931 GiB
P ext4 0 0 62 121600 254 59 1953520000 [HD_1TB]
Write isn't available because the partition table type "None" has been selected.
New options :
Dump : No
Cylinder boundary : Yes
Expert mode : Yes
Change partition type:
P ext4 0 0 1 121601 80 63 1953525168
Ask the user for vista mode
search_vista_part: 0
New options :
Dump : No
Expert mode : Yes
search_superblock
block_group_nr 625
block_group_nr 625
block_group_nr 625
ext4 0 1 1 121600 254 61 1953520000 [HD_1TB]
LVM magic value at 10259/233/25
block_group_nr 2401
recover_EXT2: "e2fsck -b 78675968 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2401/7452, s_mnt_count=161/31, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2401
SYSV4 Marker at 51990/91/32
recover_sysv4
SysV 4 51990 91 32 51990 91 31 0 [|Ôæh]
SysV4, 0 B
Partition not added.
VMFS 58569 14 45 1413313883 254 49 35764004444738854
VMFS 1962429706, 18311170 TB / 16653912 TiB
This partition ends after the disk limits. (start=940911911, size=749507878, end=1690419789, disk end=1953525168)
recover_EXT2: s_block_group_nr=0/7452, s_mnt_count=487/31, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 60587 169 54 182188 168 51 1953520000 [HD_1TB]
EXT4 Large file Sparse superblock Recover, 1000 GB / 931 GiB
This partition ends after the disk limits. (start=973340855, size=1953520000, end=2926860854, disk end=1953525168)
ext4 60587 171 32 182188 170 29 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973340959, size=1953520000, end=2926860958, disk end=1953525168)
ext4 60587 173 2 182188 171 62 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973341055, size=1953520000, end=2926861054, disk end=1953525168)
ext4 60587 174 43 182188 173 40 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973341159, size=1953520000, end=2926861158, disk end=1953525168)
ext4 60587 176 37 182188 175 34 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973341279, size=1953520000, end=2926861278, disk end=1953525168)
ext4 60587 177 62 182188 176 59 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973341367, size=1953520000, end=2926861366, disk end=1953525168)
ext4 60587 179 40 182188 178 37 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973341471, size=1953520000, end=2926861470, disk end=1953525168)
ext4 60587 181 2 182188 179 62 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973341559, size=1953520000, end=2926861558, disk end=1953525168)
ext4 60587 182 43 182188 181 40 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973341663, size=1953520000, end=2926861662, disk end=1953525168)
ext4 60587 184 45 182188 183 42 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973341791, size=1953520000, end=2926861790, disk end=1953525168)
ext4 60587 186 47 182188 185 44 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973341919, size=1953520000, end=2926861918, disk end=1953525168)
ext4 60587 188 17 182188 187 14 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973342015, size=1953520000, end=2926862014, disk end=1953525168)
ext4 60587 189 50 182188 188 47 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973342111, size=1953520000, end=2926862110, disk end=1953525168)
ext4 60587 191 52 182188 190 49 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973342239, size=1953520000, end=2926862238, disk end=1953525168)
ext4 60587 193 46 182188 192 43 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973342359, size=1953520000, end=2926862358, disk end=1953525168)
ext4 60587 195 24 182188 194 21 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973342463, size=1953520000, end=2926862462, disk end=1953525168)
ext4 60587 197 2 182188 195 62 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973342567, size=1953520000, end=2926862566, disk end=1953525168)
ext4 60587 199 12 182188 198 9 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973342703, size=1953520000, end=2926862702, disk end=1953525168)
ext4 60587 200 53 182188 199 50 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973342807, size=1953520000, end=2926862806, disk end=1953525168)
ext4 60587 202 47 182188 201 44 1953520000 [HD_1TB]
This partition ends after the disk limits. (start=973342927, size=1953520000, end=2926862926, disk end=1953525168)
HFS magic value at 62786/29/15
part_size 1260520912
HFS 62786 29 15 141249 232 42 1260520912 [IE+¯rk^ñ,ÝèdºÔ,È.Í\ͪå>3¿]
HFS, 645 GB / 601 GiB
This partition ends after the disk limits. (start=1008658931, size=1260520912, end=2269179842, disk end=1953525168)
HFS magic value at 62786/29/17
SYSV4 Marker at 75739/249/58
recover_sysv4
SysV 4 75739 249 58 75739 249 57 0 [ê4]
SysV4, 0 B
HFS magic value at 82794/17/38
part_size 136314946
HFS 82794 17 38 91279 71 56 136314946
HFS, 69 GB / 65 GiB
HFS magic value at 82794/17/40
part_size 136314946
HFS 74308 218 23 82794 17 41 136314946
HFS found using backup sector!, 69 GB / 65 GiB
HFS magic value at 95930/176/31
part_size 2286586370
HFS 95930 176 31 238264 28 14 2286586370
HFS, 1170 GB / 1090 GiB
This partition ends after the disk limits. (start=1541126568, size=2286586370, end=3827712937, disk end=1953525168)
HFS magic value at 95930/176/33
block_group_nr 6561
recover_EXT2: "e2fsck -b 214990848 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=6561/7452, s_mnt_count=161/31, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 6561
HFS magic value at 108060/104/55
part_size 8407552
HFS 108060 104 55 108583 193 4 8407552 [ÐOæóôØùèP=ËøÉ÷üœÿÂï?Ô]
HFS, 4304 MB / 4105 MiB
HFS magic value at 108060/104/57
part_size 8407552
HFS 107537 16 46 108060 104 58 8407552 [ÐOæóôØùèP=ËøÉ÷üœÿÂï?Ô]
HFS found using backup sector!, 4304 MB / 4105 MiB
Sys=0C 113668 81 32 117375 208 35 59560960
FATX, 30 GB / 28 GiB
The harddisk (1000 GB / 931 GiB) seems too small! (< 18311170 TB / 16653912 TiB)
P ext4 0 1 1 121600 254 61 1953520000 [HD_1TB]
P HFS 74308 218 23 82794 17 41 136314946
P HFS 82794 17 38 91279 71 56 136314946
HFS, 69 GB / 65 GiB
P HFS 107537 16 46 108060 104 58 8407552 [ÐOæóôØùèP=ËøÉ÷üœÿÂï?Ô]
P HFS 108060 104 55 108583 193 4 8407552 [ÐOæóôØùèP=ËøÉ÷üœÿÂï?Ô]
P Sys=0C 113668 81 32 117375 208 35 59560960
TestDisk exited normally.Anyone has some ideas?
