Unable to recover partition Topic is solved
Re: Unable to recover partition
#21 Post by Fiona »
Might be an idea to use photorec first, to recover your photos.
Afterwards you can run fsck.
But if you have all files copied and recovered, you can create a new partition and format it.
It would fix your issue about the geometry.
anapodos
#22 Post by anapodos »
I finally managed to get all my data back.
I run fsck and it corrected too many errors. Couldn't mount the partition though. Also tried to restore the superblock but no luck there. So i ended up formatting the drive and repartitioned the disk. I now have a single ext4 filesystem partition.
But when i open testdisk it still recognises the drive with none partition. Why is happening this?
Also i mentioned that the new drive i bought to back up the data, the partition isn't recognised by testdisk. I have no problem with the other hard drives as they are recognized as intel partitions.
Will it affect if in future i will have to restore the partition? (Hope i will not!!)
#23 Post by Fiona »
Drive is only a partition.
Only a disk has a MBR and as a part of it a partition table.
In TestDisk, you should always select "Disk".
Otherwise if you still experience some problems, please let me know.
You should use testdisk 32bit.
Would it be possible that your new disk has 4k sectors and it's advanced formatted?
Is your new disk bigger than 2 TB?
anapodos
#24 Post by anapodos »
I always choose disk in TestDisk and i run the 32bit version.
You have absolutely right as the disk supports advanced formatting. Also it's 4K sectors and i can confirm this from the output of fdisk -l
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Disk identifier: 0x23342335
   Device Boot      Start         End      Blocks   Id  System
/dev/sdb1            2048  1953523711   976760832   83  Linux
kostas@kostas:~$
This is for the disk we were trying to recover. Maybe this is the reason it couldn't recognize it?
anapodos
#25 Post by anapodos »
Sorry i didn't noticed that so far i was using 64bit version.
I downloaded 32bit and the results are these:
Also here is the output of testdisk 32bit
Sun Jun 22 01:12:54 2014
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
OS: Linux, kernel 3.13.0-30-generic (#54-Ubuntu SMP Mon Jun 9 22:45:01 UTC 2014) x86_64
Compiler: GCC 4.4
Compilation date: 2014-06-21T09:16:18
User is not root!
Disk /dev/sda - 400 GB / 372 GiB - CHS 48641 255 63, sector size=512 - WDC WD4000AAKS-00TMA0, S/N:WD-WCAPW1513407, FW:12.01C01
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-00ZF5A0, S/N:WD-WMC1S2520330, FW:80.00A80
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD10EZEX-00ZF5A0
 1 P Linux                    0  32 33 121601  57 56 1953521664 [Downloads]
recover_EXT2: s_block_group_nr=0/7452, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 244190638
recover_EXT2: part_size 1953525104
     Linux                    0   1  1 121601  80 62 1953525104
     ext4 blocksize=4096 Large file Sparse superblock, 1000 GB / 931 GiB
Warning: the current number of heads per cylinder is 255 but the correct value may be 16.
   * Linux                    0   1  1 121601 254 63 1953536067
dir_partition inode=2
ext2fs_dir_iterate failed with error 2133571402.
 1 * Linux                    0   1  1 121601 254 63 1953536067
Is there anything wrong or i can continue to use the disk?
#26 Post by Fiona »
Especially to advanced format, in my tests, even windows explorer was generating sometimes messages, like repair, sometimes testdisk found a partition and sometimes not.
Windows explorer also.
Advanced format is a different alignment and was especially used under winxp because of degraded performance.
Even 4k sectors are handled different.
They emulate 512bytes sectors, otherwise the disk might be not bootable.
Info about OS support:
http://support.microsoft.com/kb/2510009/en-us
Actually testdisk supports 4k sectors.
For me it looks like that advanced format still stucks somehow in the infancys?
Especially abou disk geometry.
Since vista, microsoft aligns partitions not on cylinder- but megabyte boundary.
TestDisk supports megabyte boundary but testdisk is generally based on PC/Intel-MBR.
If a partition is not PC/Intel-MBR standard, testdisk displays a message that geometry might be not correct.
Can be ignored.
Microsoft alignment on megabyte boundary is recognized if a partition starts after 1 MB at cylinder 0 and head 32 etc..
You can watch it on your photo and current partition strucure.
Some info about PC/Intel standard:
http://www.cgsecurity.org/wiki/Partitio ... nd_logical
In this case, everything is normal and there is no further action required
anapodos
#27 Post by anapodos »
Ubuntu 14.04 also supports and proposes alignment to mib instead of cylinder.
Two of my disks are aligned now to mib. The one we were trying to recover and the new one i bought. Both western digital and on their site they prefer the advanced format and 4k sectors.
Thanks for the info. Very useful. Also i would like to thank you for all the help till now!! Maybe i didn't recovered the partition but i recovered all the data and this was the most important for me!
#28 Post by Fiona »
Your partition was not standard and used a reserved area on your disk, before a partition normally starts by a boot sector.
It was:
Cylinder 0 and the value head should be 1 but was 0.
That's why you weren't able to write your partition.
To avoid any further trouble, it was recommended to copy your data off to another healty disk/partition and create a new partition to fix your problem.
anapodos
#29 Post by anapodos »
Yes i deleted the partition and created a new one.
This is what TestDisk shows. Is it right now?
#30 Post by Fiona »
Yes, your partition starts with the right values.
