Similar to this post:
http://forum.cgsecurity.org/phpBB3/hard ... -t379.html
I have pretty much recieved the same info (though I have Mac OS X Snow Leopard 1.6) and will not boot - just white screen with spinning disk.
After loading testdisk/deep scan etc. it says that various sectors cannot be recovered, check HD jumpers, BIOS detection etc. though I have not altered anything since the machine was recieved and had been working OK before this (Once had the '3 chimes' on bootup but reset ok a while back)
When pressing 'p' to view files after 100% analysis there is nothing listed?
Just:
EFI System 40 409639 409600 [EFI]
>drwxr-xr-x 0 0 0 26-Jul-2009 14:39 EFI
Not sure where to go from here?
Any help would be much appreciated and a little out of my depth!!!
Many thanks,
GS
