invalid or incomplete multibyte or wide character
sercerfe
#1 Post by sercerfe »
Hi.
i try to recover my data because i can't repair de partition table i don't know what, but with testdisk i can view all my lost partitions and all my lost data.
when i try to recover my data, some files shows: "invalid or incomplete multibyte or wide character" in the log file.
What can i do?
sercerfe
Re: invalid or incomplete multibyte or wide character
#2 Post by sercerfe »
Here some of the failures that testdisk shows:
Cannot represent filename in current locale.
Can't create file /mnt/sdc5/DATOS/DOCUMENTOS/MANUALES/SICK/Fotocélulas/W_34_e.pdf: Invalid or incomplete multibyte or wide character
ERROR: Couldn't set the file's date and time for /mnt/sdc5/DATOS/DOCUMENTOS/MANUALES/SICK/Fotocélulas
But there are a lot of failures "Invalid or incomplete multibyte or wide character"
when i search partitions i found my two partitions and i can navigate and see all the files, but when i try to recover it, then appear these failures.
Is possible recover the files or this software cant?
remy
#3 Post by remy »
wouldn't be easier to repair your partition table with testdisk and then to mount file-system to access data ?
Why weren't you able to repair your partition table ?
