Help!! Slow deeper search. files not copying out ($mft error
deolu
#1 Post by deolu »
I've been trying to get a hang of the testdisk utility for about 10Hrs now, but seems i'm just messing it up, i'm extremely drained,s o my typing might be crap.
First, the wiki didn't help out, cause it wasn't the same result i was getting:
It didn't give the no partition is bootable error at first, i didn't know where to go from there, so i just hit enter and it took a while to load, infact, with every new menu it takes a while, i presume that is because the hard disk is bad.
And oh, the HDD, a WD blue is for my laptop, win 8.1, 2 partitions, one extended, a bad Sata/IDE-Usb connector caused it to change format. before that, i was having blue screens at all the startup options.
Back to TEstDisk..........
So, the first time i tried copying files, from the non-boot partition, it was working, then it all suddenly stopped; copying just the directories for the folder, but not the files contained.
so, i tried again, but it just kept progressing, 0 copied, 899.. failed.
and the i tried starting the utility again, but when it gets to displaying the partition table from quick search and i hit enter, it says, no partition found...... or some error of sort, then i hit enter for deeper scan, then i've been on that for about 2hrs now; progress= 2817/121600: 02%.
Quick response much appreciated. i'd have to leave the office soon, dunno if i have to leave the desktop on
Re: Help!! Slow deeper search. files not copying out ($mft e
A faulty file system and bad sectors can cause that testdisk hang during a scan and copying files.
Did you get read errors too?
Can you check your disk using crystaldiskinfo?
The portable version is recommended because the windows installer (exe) contains adware open candy.
Did you use your WD blue used as an internal disk?
Can you repeat your Diagnose and open your testdisk.log and copy and paste the content into your next post?
If testdisk hangs, you can stop your diagnose and copy and paste the content of your testdisk.log as far as it's available too.
deolu
#3 Post by deolu »
This time, it didn't hang, now it returns the error, this partition is not recoverable and shows the boot partition in green, but in windows explorer, its still not opening.
Crystal disk Results:
CrystalDiskInfo 6.1.14 (C) 2008-2014 hiyohiyo
                                Crystal Dew World : http://crystalmark.info/
    OS : Windows 8  [6.2 Build 9200] (x64)
  Date : 2014/07/09 12:09:01
-- Controller Map ----------------------------------------------------------
 - Microsoft Storage Spaces Controller [SCSI]
 + Intel(R) Mobile Express Chipset SATA RAID Controller [SCSI]
   - ST750LM022 HN-M750MBB
   - hp CDDVDW SN-208BB
-- Disk List ---------------------------------------------------------------
 (1) ST750LM022 HN-M750MBB : 750.1 GB [0/0/0, pd1] - st
 (2) WDC WD10JPVT-22A1YT0 : 1000.2 GB [1/0/0, jm1] - wd
           Model : ST750LM022 HN-M750MBB
        Firmware : 2AR10002
   Serial Number : S2SUJ9CCA03487
       Disk Size : 750.1 GB (8.4/137.4/750.1/750.1)
     Buffer Size : 8192 KB
     Queue Depth : 32
    # of Sectors : 1465149168
   Rotation Rate : 5400 RPM
       Interface : Serial ATA
   Major Version : ACS-2
   Minor Version : ATA8-ACS version 6
   Transfer Mode : ---- | SATA/300
  Power On Hours : 218 hours
  Power On Count : 429 count
     Temperature : 33 C (91 F)
   Health Status : Good
        Features : S.M.A.R.T., APM, 48bit LBA, NCQ
       APM Level : 0080h [OFF]
       AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 _51 00000000022D Read Error Rate
02 252 252 __0 000000000000 Throughput Performance
03 _89 _89 _25 000000000D90 Spin-Up Time
04 100 100 __0 0000000001D1 Start/Stop Count
05 252 252 _10 000000000000 Reallocated Sectors Count
07 252 252 _51 000000000000 Seek Error Rate
08 252 252 _15 000000000000 Seek Time Performance
09 100 100 __0 0000000000DA Power-On Hours
0A 252 252 _51 000000000000 Spin Retry Count
0B 100 100 __0 000000000006 Recalibration Retries
0C 100 100 __0 0000000001AD Power Cycle Count
B5 100 100 __0 0000000DC1C7 Vendor Specific
B7 252 252 _10 000000000000 Vendor Specific
B8 252 252 _48 000000000000 End-to-End Error
BA 252 252 __0 000000000000 Vendor Specific
BB 100 100 __0 000000000229 Reported Uncorrectable Errors
BC 252 252 __0 000000000000 Command Timeout
BE _67 _49 _40 003300170021 Airflow Temperature
BF 100 100 __0 00000000001F G-Sense Error Rate
C0 252 252 __0 000000000000 Power-off Retract Count
C1 100 100 __0 0000000018CB Load/Unload Cycle Count
C2 _64 _49 __0 003300170021 Temperature
C3 100 100 __0 000000000000 Hardware ECC recovered
C4 252 252 __0 000000000000 Reallocation Event Count
C5 252 100 __0 000000000000 Current Pending Sector Count
C6 252 252 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
C8 100 100 __0 00000000018F Write Error Rate
-- IDENTIFY_DEVICE ---------------------------------------------------------
        0    1    2    3    4    5    6    7    8    9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 5332 5355 4A39 4343 4130 3334 3837 2020 2020 2020
020: 0000 4000 0004 3241 5231 3030 3032 5354 3735 304C
030: 4D30 3232 2048 4E2D 4D37 3530 4D42 4220 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0000
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 0D06 0000 004C 0048
080: 03FF 0028 706B 7C09 6123 7069 BC01 6123 407F 0057
090: 0057 0080 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 66F0 5754 0000 0000 0000 0000 6003 0000 5000 4CF2
110: 0884 0846 0000 0000 0000 0000 0000 0100 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1518 0000 0000
220: 0000 0000 101F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 0400 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 B6A5
-- SMART_READ_DATA ---------------------------------------------------------
     +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 2F 00 64 64 2D 02 00 00 00 00 00 02 27
010: 00 FC FC 00 00 00 00 00 00 00 03 23 00 59 59 90
020: 0D 00 00 00 00 00 04 32 00 64 64 D1 01 00 00 00
030: 00 00 05 33 00 FC FC 00 00 00 00 00 00 00 07 2F
040: 00 FC FC 00 00 00 00 00 00 00 08 25 00 FC FC 00
050: 00 00 00 00 00 00 09 32 00 64 64 DA 00 00 00 00
060: 00 00 0A 33 00 FC FC 00 00 00 00 00 00 00 0B 32
070: 00 64 64 06 00 00 00 00 00 00 0C 32 00 64 64 AD
080: 01 00 00 00 00 00 B5 22 00 64 64 C7 C1 0D 00 00
090: 00 00 B7 32 00 FC FC 00 00 00 00 00 00 00 B8 33
0A0: 00 FC FC 00 00 00 00 00 00 00 BA 32 00 FC FC 00
0B0: 00 00 00 00 00 00 BB 32 00 64 64 29 02 00 00 00
0C0: 00 00 BC 32 00 FC FC 00 00 00 00 00 00 00 BE 02
0D0: 00 43 31 21 00 17 00 33 00 00 BF 22 00 64 64 1F
0E0: 00 00 00 00 00 00 C0 22 00 FC FC 00 00 00 00 00
0F0: 00 00 C1 32 00 64 64 CB 18 00 00 00 00 00 C2 02
100: 00 40 31 21 00 17 00 33 00 00 C3 3A 00 64 64 00
110: 00 00 00 00 00 00 C4 32 00 FC FC 00 00 00 00 00
120: 00 00 C5 32 00 FC 64 00 00 00 00 00 00 00 C6 30
130: 00 FC FC 00 00 00 00 00 00 00 C7 36 00 C8 C8 00
140: 00 00 00 00 00 00 C8 2A 00 64 64 8F 01 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 30 2A 00 51
170: 03 00 01 00 02 B4 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BA
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 33 00 00 00 00 00 00 00 00 00 00 02 00
010: 00 00 00 00 00 00 00 00 00 00 03 19 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 0A 00 00 00 00 00 00 00 00 00 00 07 33
040: 00 00 00 00 00 00 00 00 00 00 08 0F 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 33 00 00 00 00 00 00 00 00 00 00 0B 00
070: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
080: 00 00 00 00 00 00 B5 00 00 00 00 00 00 00 00 00
090: 00 00 B7 0A 00 00 00 00 00 00 00 00 00 00 B8 30
0A0: 00 00 00 00 00 00 00 00 00 00 BA 00 00 00 00 00
0B0: 00 00 00 00 00 00 BB 00 00 00 00 00 00 00 00 00
0C0: 00 00 BC 00 00 00 00 00 00 00 00 00 00 00 BE 28
0D0: 00 00 00 00 00 00 00 00 00 00 BF 00 00 00 00 00
0E0: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00
0F0: 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 C2 00
100: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00
110: 00 00 00 00 00 00 C4 00 00 00 00 00 00 00 00 00
120: 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 C6 00
130: 00 00 00 00 00 00 00 00 00 00 C7 00 00 00 00 00
140: 00 00 00 00 00 00 C8 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C5
       Enclosure : WDC WD10 JPVT-22A1YT0 USB Device (V=152D, P=2338, jm1) - wd
           Model : WDC WD10JPVT-22A1YT0
        Firmware : 01.01A01
   Serial Number : WD-WXB1A9275446
       Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
     Queue Depth : 32
    # of Sectors : 1953525168
       Interface : USB (Serial ATA)
   Major Version : ATA8-ACS
   Minor Version : ----
   Transfer Mode : SATA/150 | SATA/300
  Power On Hours : 5771 hours
  Power On Count : 2411 count
     Temperature : 34 C (93 F)
   Health Status : Caution
       APM Level : 0060h [ON]
       AAM Level : ----
01 197 197 _51 00000000EA68 Read Error Rate
03 181 177 _21 00000000077C Spin-Up Time
04 _94 _94 __0 000000001943 Start/Stop Count
05 200 200 140 000000000003 Reallocated Sectors Count
07 100 253 __0 000000000000 Seek Error Rate
09 _93 _93 __0 00000000168B Power-On Hours
0A 100 100 __0 000000000000 Spin Retry Count
0B 100 100 __0 000000000000 Recalibration Retries
0C _98 _98 __0 00000000096B Power Cycle Count
BF __1 __1 __0 0000000002F0 G-Sense Error Rate
C0 199 199 __0 00000000059D Power-off Retract Count
C1 186 186 __0 00000000A6FC Load/Unload Cycle Count
C2 113 101 __0 000000000022 Temperature
C4 197 197 __0 000000000003 Reallocation Event Count
C5 194 194 __0 0000000003F5 Current Pending Sector Count
C6 100 253 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000001 UltraDMA CRC Error Count
C8 200 200 __0 000000000000 Write Error Rate
        0    1    2    3    4    5    6    7    8    9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2057 442D 5758 4231 4139 3237 3534 3436
020: 0000 4000 0000 3031 2E30 3141 3031 5744 4320 5744
030: 3130 4A50 5654 2D32 3241 3159 5430 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0100
070: 0000 0000 0000 0000 0000 001F 1F06 0002 004C 0040
080: 01FE 0000 746B 7D09 6123 7469 BC09 6123 407F 0053
090: 0053 0060 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 6003 0000 5001 4EE6
110: 5864 C255 0000 0000 0000 0000 0000 0000 0000 4018
120: 4018 0000 0000 0000 0000 0000 0000 0000 0021 0000
130: 0000 0000 0000 16E8 0000 0000 0000 0000 0000 0000
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 70B5 0000 0000 4000
220: 0000 0000 103E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 AFA5
000: 10 00 01 2F 00 C5 C5 68 EA 00 00 00 00 00 03 27
010: 00 B5 B1 7C 07 00 00 00 00 00 04 32 00 5E 5E 43
020: 19 00 00 00 00 00 05 33 00 C8 C8 03 00 00 00 00
030: 00 00 07 2E 00 64 FD 00 00 00 00 00 00 00 09 32
040: 00 5D 5D 8B 16 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 62 62 6B 09 00 00 00 00 00 BF 32
070: 00 01 01 F0 02 00 00 00 00 00 C0 32 00 C7 C7 9D
080: 05 00 00 00 00 00 C1 32 00 BA BA FC A6 00 00 00
090: 00 00 C2 22 00 71 65 22 00 00 00 00 00 00 C4 32
0A0: 00 C5 C5 03 00 00 00 00 00 00 C5 32 00 C2 C2 F5
0B0: 03 00 00 00 00 00 C6 30 00 64 FD 00 00 00 00 00
0C0: 00 00 C7 32 00 C8 C8 01 00 00 00 00 00 00 C8 08
0D0: 00 C8 C8 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 FC 3F 01 7B
170: 03 00 01 00 02 B3 05 00 00 00 00 00 00 00 00 00
180: 00 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70
000: 10 00 01 33 C8 C8 C8 C5 00 00 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 64 64 64 64 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 BF 00
070: 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00
080: 00 00 00 00 00 00 C1 00 00 00 00 00 00 00 00 00
090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C4 00
0A0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
0B0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00
0C0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 C8 00
0D0: C8 C8 C8 C8 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 31
Testdisk Results:
Wed Jul  9 10:33:05 2014
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
Compilation date: 2014-06-21T09:12:27
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=720218619904
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=29102178304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=557804683264
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - ST750LM022 HN-M750MBB, S/N:S2SUJ9CCA03487, FW:2AR10002
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 JPVT-22A1YT0, S/N:152D20337A0C
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD10 JPVT-22A1YT0
NTFS at 0/32/33
file_pread(5,1024,buffer,6296576(391/240/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6297400(391/253/47)) ReadFile Data error (cyclic redundancy check).
NTFS: Can't read MFT
 1 E extended LBA             0  32 32 67816 254 63 1089478058
 5 L HPFS - NTFS              0  32 33 67816   4 28 1089462272
Backup partition structure
partition_save
NTFS at 0/32/33
filesystem size           1089462272
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     NTFS, blocksize=4096, 557 GB / 519 GiB
file_pread(5,16,buffer,1107308607(68926/197/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1107308623(68926/197/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1107308623(68926/197/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1107402878(68932/163/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1107402878(68932/163/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1107456919(68936/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1107456920(68936/1/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1107494912(68938/94/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1107494912(68938/94/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1107494913(68938/94/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1107494914(68938/94/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1108471808(68999/45/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1108471808(68999/45/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1108471809(68999/45/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1108471810(68999/45/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1108471824(68999/45/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1108471871(68999/46/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1108471887(68999/46/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1108471934(68999/47/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1108473874(68999/78/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1108473935(68999/79/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1108473936(68999/79/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1108498432(69000/213/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1108498432(69000/213/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1108498433(69000/213/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1108498434(69000/213/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1108498448(69000/213/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1108523071(69002/94/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1108523071(69002/94/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1108547710(69003/230/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1108547712(69003/230/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1108594814(69006/213/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1108594816(69006/213/8)) ReadFile Data error (cyclic redundancy check).
BAD_RS LBA=826932863 1765260
file_pread(5,3,buffer,826932863(318823/137/34)) lseek err Invalid argument
file_pread(5,1,buffer,826932863(318823/137/34)) lseek err Invalid argument
     FAT16 >32M           318823 137 34 520356 189 31 3237630919
This partition ends after the disk limits. (start=5121900159, size=3237630919, end=8359531077, disk end=1953525168)
file_pread(5,16,buffer,1727342718(107522/28/25)) ReadFile The system cannot find the file specified.
