I googled a lot and searched this forum, but I couldn't find a solution to restore my home partition folder structures.
Before trouble started my hard disk had the following partitions:
P windows, ntfs, with label windoof
Extended partition consisting of
L lubuntu root, ext4, no label
L home, ext4, label home
L swap
L fat32, label fat
I created an usb multiboot system with the help of the multisystem software. Two of the installed images were Dr. Web Antivirus and Parted Magic. When booting the Dr. Web Antivirus Image I encountered some error messages. After that the laptop didn't boot anymore from hd, because all the data of the lubuntu root partition were gone and grub could not be found. After reinstalling Lubuntu, everything was fine again, the home data was still ok and the story could have ended here.
But I added a new logical partition behind the fat32 partition with ext4, label grub2 and installed grub additionally on that partition. Later I booted the Dr. Web image again - with similar results. Finally I could not find any data on the root, home and grub2 partitions. The windows partition is still ok.
Now I started using the parted magic image from the usb stick, and used the testdisk and photorec tools. Photorec worked like a charm on the home partition. Now I try too recover the data of the home partition with testdisk to get back the folder structure too.
The results of the quick search look promising. But when I look at the existing files on e.g. the home partition I only find deleted folders (guest, tom, lost+found) and these are empty:
P Linux 4569 1 1 60016 254 62 890772056 [home]
Directory /tom
No file found, filesystem may be damaged.
The harddisk (500 GB / 465 GiB) seems too small! (< 1023 GB / 953 GiB)
> Linux 7205 171 7 62653 170 5 890772056 [home]
Linux 7207 213 47 62655 212 45 890772056 [home]
Linux 7211 71 29 62659 70 27 890772056 [home]
FAT16 <32M 20783 87 39 124469 203 58 1665722918Code: Select all
Disk /dev/sda - 500 GB / 465 GiB - CHS 60802 255 63
D HPFS - NTFS 0 1 1 2609 254 53 41929577 [windoof]
D HPFS - NTFS 0 1 11 2609 254 63 41929577
D Linux 2611 0 1 4568 254 57 31455264 [root]
D Linux 2611 1 1 4437 253 58 29350624
>* Linux 4569 1 1 60016 254 62 890772056 [home]
P Linux Swap 60017 1 1 60669 254 41 10490360
P FAT32 LBA 60670 1 1 60788 79 27 1900611 [fat]
D Linux 60788 111 58 60800 237 43 200704 [grub2]
D Linux 60788 111 60 60800 237 45 200704 [grub2]
Enter: to continue
EXT4 Large file Sparse superblock, 456 GB / 424 GiBAny help, comments and tips are highly appreciated.
Greets, Tom
Here is my log:
Mon Apr 23 16:37:40 2012
OS: Linux, kernel 3.2.13-pmagic (#1 SMP Sat Mar 24 08:16:47 CDT 2012) i686
Compiler: GCC 4.5
Compilation date: 2012-01-28T16:01:13
ext2fs lib: 1.42.1, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size 976773168 sectors
/dev/sda: user_max 976773168 sectors
/dev/sda: dco 976773168 sectors
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000BEVT-00A0RT0, S/N:WD-WXB1C10T5424, FW:01.01A01
Disk /dev/sda - 500 GB / 465 GiB - WDC WD5000BEVT-00A0RT0
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/1/1
Info: size boot_sector 41929577, partition 41929587
FAT32 at 60670/1/1
Info: size boot_sector 1900611, partition 1900611
FAT1 : 42-1896
FAT2 : 1897-3751
start_rootdir : 3752 root cluster : 2
Data : 3752-1900607
sectors : 1900611
cluster_size : 8
no_of_cluster : 237107 (2 - 237108)
fat_length 1855 calculated 1853
get_geometry_from_list_part_aux head=255 nbr=14
get_geometry_from_list_part_aux head=8 nbr=3
1 * HPFS - NTFS 0 1 1 2609 254 63 41929587 [windoof]
2 E extended 2610 254 62 60800 254 63 934822352
5 L Linux 2611 0 1 4568 254 63 31455270 [root]
X extended 4569 0 1 60016 254 63 890772120
6 L Linux 4569 1 1 60016 254 63 890772057 [home]
X extended 60017 0 1 60669 254 63 10490445
7 L Linux Swap 60017 1 1 60669 254 63 10490382
X extended 60670 0 1 60788 79 27 1900674
8 L FAT32 60670 1 1 60788 79 27 1900611 [fat]
X extended 60788 79 28 60800 237 45 202752
9 L Linux 60788 111 60 60800 237 45 200704 [grub2]
Computes LBA from CHS for Disk /dev/sda - 500 GB / 465 GiB - CHS 60802 255 63
search_vista_part: 1
NTFS at 0/1/1
filesystem size 41929577
mftmirr_lcn 1835425
NTFS, 21 GB / 19 GiB
recover_EXT2: s_block_group_nr=0/119, s_mnt_count=5/36, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 3931908
recover_EXT2: part_size 31455264
EXT4 Large file Sparse superblock, 16 GB / 14 GiB
recover_EXT2: s_block_group_nr=0/3398, s_mnt_count=5/26, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 111346507
recover_EXT2: part_size 890772056
SWAP2 version 1, 5371 MB / 5122 MiB
FAT32 at 60670/1/1
FAT1 : 42-1896
FAT2 : 1897-3751
Data : 3752-1900607
sectors : 1900611
cluster_size : 8
FAT32 at 60670/1/1
FAT32, 973 MB / 928 MiB
recover_EXT2: s_block_group_nr=0/12, s_mnt_count=5/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1936
recover_EXT2: s_blocks_count 100352
recover_EXT2: part_size 200704
EXT4 Sparse superblock, 102 MB / 98 MiB
get_geometry_from_list_part_aux head=255 nbr=9
* HPFS - NTFS 0 1 1 2609 254 53 41929577 [windoof]
P Linux 2611 0 1 4568 254 57 31455264 [root]
L Linux Swap 60017 1 1 60669 254 41 10490360
L FAT32 LBA 60670 1 1 60788 79 27 1900611 [fat]
dir_partition inode=2
2 drwxr-xr-x 0 0 4096 22-Apr-2012 13:58 .
2 drwxr-xr-x 0 0 4096 22-Apr-2012 13:58 ..
X 524289 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 home
X 786433 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 etc
X 131073 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 bin
X 655370 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 boot
X 64 drwx------ 0 0 0 22-Apr-2012 13:58 lost+found
X 655374 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 var
X 32770 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 media
X 14 lrwxrwxrwx 0 0 11 2-Nov-2009 21:47 cdrom
X 262145 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 dev
X 131074 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 lib
X 786435 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 mnt
X 524290 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 proc
X 262146 drwx------ 0 0 0 22-Apr-2012 13:58 root
X 65537 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 opt
X 524291 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 run
X 786436 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 sbin
X 131075 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 selinux
X 262147 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 srv
X 262148 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 sys
X 786437 drwxrwxrwt 0 0 0 22-Apr-2012 13:58 tmp
X 90114 drwxrwxrwt 0 0 0 21-Apr-2012 20:39 tmp
X 98305 drwxr-xr-x 0 0 0 22-Apr-2012 13:58 usr
X 11 lrwxrwxrwx 0 0 32 22-Apr-2012 11:10 initrd.img
X 12 lrwxrwxrwx 0 0 29 22-Apr-2012 11:10 vmlinuz
X 394596 -rw-r--r-- 0 0 0 22-Apr-2012 13:58 share
X 77 -rwxr-xr-x 0 0 0 22-Apr-2012 13:58 vmlinuz.2429
X 56665 lrwxrwxrwx 0 0 33 16-Feb-2012 21:26 initrd.img.old
X 77 -rwxr-xr-x 0 0 0 22-Apr-2012 13:58 vmlinuz.old
2 drwxr-xr-x 0 0 4096 22-Apr-2012 13:59 .
2 drwxr-xr-x 0 0 4096 22-Apr-2012 13:59 ..
X 11 drwx------ 0 0 0 22-Apr-2012 13:58 lost+found
X 8193 drwxr-x--- 1000 1000 0 22-Apr-2012 13:59 tom
X27262977 drwxr-xr-x 1001 1001 0 22-Apr-2012 13:58 guest
dir_partition inode=8193
Directory /tom
1 * HPFS - NTFS 0 1 1 2609 254 53 41929577 [windoof]
2 P Linux 2611 0 1 4568 254 57 31455264 [root]
3 P Linux 4569 1 1 60016 254 62 890772056 [home]
4 E extended LBA 60017 0 1 60801 254 63 12611025
5 L Linux Swap 60017 1 1 60669 254 41 10490360
6 L FAT32 LBA 60670 1 1 60788 79 27 1900611 [fat]
7 L Linux 60788 111 60 60800 237 45 200704 [grub2]
NTFS at 0/1/1
mftmirr_lcn 1835425
NTFS at 2609/254/63
mftmirr_lcn 1835425
NTFS found using backup sector!, 21 GB / 19 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/119, s_mnt_count=44/36, s_blocks_per_group=32768, s_inodes_per_group=8192
EXT4 Large file Sparse superblock Backup superblock, 16 GB / 14 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/111, s_mnt_count=0/30, s_blocks_per_group=32768, s_inodes_per_group=16384
recover_EXT2: s_blocks_count 3668828
recover_EXT2: part_size 29350624
EXT3 Sparse superblock Backup superblock, 15 GB / 13 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/3398, s_mnt_count=0/26, s_blocks_per_group=32768, s_inodes_per_group=8192
EXT4 Large file Sparse superblock Backup superblock, 456 GB / 424 GiB
recover_EXT2: s_block_group_nr=0/3398, s_mnt_count=17/26, s_blocks_per_group=32768, s_inodes_per_group=8192
EXT4 Large file Sparse superblock Recover, 456 GB / 424 GiB
This partition ends after the disk limits. (start=115759104, size=890772056, end=1006531159, disk end=976784130)
recover_EXT2: s_block_group_nr=0/3398, s_mnt_count=7/26, s_blocks_per_group=32768, s_inodes_per_group=8192
This partition ends after the disk limits. (start=115793920, size=890772056, end=1006565975, disk end=976784130)
This partition ends after the disk limits. (start=115849216, size=890772056, end=1006621271, disk end=976784130)
BAD_RS LBA=333884414 12980581
This partition ends after the disk limits. (start=333884414, size=1665722918, end=1999607331, disk end=976784130)
FAT32 at 60670/1/1
FAT1 : 42-1896
FAT2 : 1897-3751
Data : 3752-1900607
sectors : 1900611
cluster_size : 8
FAT32 at 60670/1/1
FAT32 at 60670/1/7
FAT1 : 42-1896
FAT2 : 1897-3751
Data : 3752-1900607
sectors : 1900611
cluster_size : 8
FAT32 at 60670/1/7
FAT32 LBA 60670 1 1 60788 79 27 1900611 [NO NAME]
FAT found using backup sector!, 973 MB / 928 MiB
block_group_nr 1
recover_EXT2: "e2fsck -b 8193 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=1/12, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1936
EXT4 Sparse superblock Backup superblock, 102 MB / 98 MiB
block_group_nr 3
recover_EXT2: "e2fsck -b 24577 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=3/12, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1936
block_group_nr 5
recover_EXT2: "e2fsck -b 40961 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=5/12, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1936
block_group_nr 7
recover_EXT2: "e2fsck -b 57345 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=7/12, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1936
block_group_nr 9
recover_EXT2: "e2fsck -b 73729 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=9/12, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1936
NTFS at 0/1/1
mftmirr_lcn 1835425
get_geometry_from_list_part_aux head=255 nbr=10
Directory /tom
P Linux 60788 111 60 60800 237 45 200704 [grub2]
2 drwxr-xr-x 0 0 1024 22-Apr-2012 13:59 .
2 drwxr-xr-x 0 0 1024 22-Apr-2012 13:59 ..
X 11 drwx------ 0 0 0 22-Apr-2012 13:59 lost+found
X 12 drwxr-xr-x 0 0 0 22-Apr-2012 13:59 boot
dir_partition inode=12
Directory /boot
P Linux 60788 111 58 60800 237 43 200704 [grub2]
1 * Linux 4569 1 1 60016 254 62 890772056 [home]
2 P Linux Swap 60017 1 1 60669 254 41 10490360
3 P FAT32 LBA 60670 1 1 60788 79 27 1900611 [fat]
4 P Linux 60788 111 58 60800 237 43 200704 [grub2]
