Made schoolboy error
lith
#1 Post by lith »
Can anybody help me undo the partitions that I created on my disk. I realize that I created the partitions before the software had recognized the true partitions from the RAW hard drive.
I now have 3 drive letters assigned and would like to undo the partitions that I have created - many thanks for a solution or work around
Re: Made schoolboy error
Can your run TestDisk / Analyse / Quick and if your partitions are not found, Deeper Search also?
If a partition is found, please mark it and press p to have a try to list your data.
In your testdisk folder, you'll find a file called testdisk.log
Can you open it using a wordprocessor like wordpad and copy and paste the content into your next post?
lith
#3 Post by lith »
I have attached the log file (big!!)
The quick scan gives 3 separate lines - but no partition designation (I could press 'P' and see my file names). The deeper scan seems quick and only gave 1 line of information and no partition designation. :?
lith
#4 Post by lith »
update - the proposed attached log was 450Mb in size and would not send
#5 Post by Fiona »
Yes, might be too big.
Did you achieve any read errors?
lith
#6 Post by lith »
yes - many read errors
I followed up with a HDD check (HDD Tune), this revealed a healthy drive
I ran again Testdisk and used the deeper scan function - after 20 hrs i gave up (it is a 750Gb drive and the scan was only 15% complete). How long should I expect for this process ?
Is there something else that I can check?
lith
#7 Post by lith »
i have truncated the file - but the data was lines of the same
I am trying to rerun the program now
Sun Jul 13 17:41:53 2014
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
Compilation date: 2014-06-21T09:12:27
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=63962087424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=63864569856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=63962087424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=63864569856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=240055746560
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=63847792640
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=208666624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=63945310208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=723324502016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=22360883200
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - Crucial_ CT240M500SSD, S/N:310290B3EF61, FW:MU02
Disk /dev/sdb - 63 GB / 59 GiB - CHS 7776 255 63, sector size=512 - JMCR SD
Disk /dev/sdc - 63 GB / 59 GiB - CHS 7764 255 63, sector size=512 - O2Micro SD, FW:0001
Disk /dev/sdd - 750 GB / 698 GiB - CHS 11400 255 63, sector size=4096 - ST975042 0AS, S/N:152D20337A0C
Disk \\.\PhysicalDrive3 - 750 GB / 698 GiB - CHS 11400 255 63, sector size=4096 - ST975042 0AS, S/N:152D20337A0C
Drive F: - 208 MB / 199 MiB - CHS 3 255 63, sector size=4096 - ST975042 0AS, S/N:152D20337A0C
Drive H: - 723 GB / 673 GiB - CHS 10992 255 63, sector size=4096 - ST975042 0AS, S/N:152D20337A0C
Drive I: - 22 GB / 20 GiB - CHS 339 255 63, sector size=4096 - ST975042 0AS, S/N:152D20337A0C
Disk \\.\PhysicalDrive3 - 750 GB / 698 GiB - ST975042 0AS
Analyse Disk \\.\PhysicalDrive3 - 750 GB / 698 GiB - CHS 11400 255 63
Partition: Read error
file_win32_pread(268,1,buffer,6(0/0/7)) read err: read after end of file
file_win32_pread(268,2,buffer,6(0/0/7)) read err: read after end of file
file_win32_pread(268,1,buffer,8(0/0/9)) read err: read after end of file
file_win32_pread(268,2,buffer,13(0/0/14)) read err: read after end of file
file_win32_pread(268,3,buffer,21(0/0/22)) read err: read after end of file
file_win32_pread(268,1,buffer,262(0/4/11)) read err: read after end of file
file_win32_pread(268,2,buffer,32(0/0/33)) read err: read after end of file
file_win32_pread(268,1,buffer,34(0/0/35)) read err: read after end of file
file_win32_pread(268,2,buffer,39(0/0/40)) read err: read after end of file
file_win32_pread(268,2,buffer,41(0/0/42)) read err: read after end of file
file_win32_pread(268,3,buffer,47(0/0/48)) read err: read after end of file
file_win32_pread(268,1,buffer,288(0/4/37)) read err: read after end of file
file_win32_pread(268,2,buffer,63(0/1/1)) read err: read after end of file
file_win32_pread(268,1,buffer,65(0/1/3)) read err: read after end of file
file_win32_pread(268,2,buffer,70(0/1/8)) read err: read after end of file
file_win32_pread(268,2,buffer,72(0/1/10)) read err: read after end of file
file_win32_pread(268,3,buffer,78(0/1/16)) read err: read after end of file
file_win32_pread(268,1,buffer,319(0/5/5)) read err: read after end of file
file_win32_pread(268,2,buffer,256(0/4/5)) read err: read after end of file
file_win32_pread(268,1,buffer,258(0/4/7)) read err: read after end of file
file_win32_pread(268,2,buffer,263(0/4/12)) read err: read after end of file
file_win32_pread(268,2,buffer,265(0/4/14)) read err: read after end of file
file_win32_pread(268,3,buffer,271(0/4/20)) read err: read after end of file
file_win32_pread(268,1,buffer,512(0/8/9)) read err: read after end of file
file_win32_pread(268,2,buffer,512(0/8/9)) read err: read after end of file
file_win32_pread(268,1,buffer,514(0/8/11)) read err: read after end of file
file_win32_pread(268,2,buffer,519(0/8/16)) read err: read after end of file
file_win32_pread(268,2,buffer,521(0/8/18)) read err: read after end of file
file_win32_pread(268,3,buffer,527(0/8/24)) read err: read after end of file
file_win32_pread(268,1,buffer,768(0/12/13)) read err: read after end of file
file_win32_pread(268,2,buffer,768(0/12/13)) read err: read after end of file
file_win32_pread(268,1,buffer,770(0/12/15)) read err: read after end of file
file_win32_pread(268,2,buffer,775(0/12/20)) read err: read after end of file
file_win32_pread(268,2,buffer,777(0/12/22)) read err: read after end of file
file_win32_pread(268,3,buffer,783(0/12/28)) read err: read after end of file
file_win32_pread(268,1,buffer,1024(0/16/17)) read err: read after end of file
file_win32_pread(268,2,buffer,1008(0/16/1)) read err: read after end of file
file_win32_pread(268,1,buffer,1010(0/16/3)) read err: read after end of file
file_win32_pread(268,2,buffer,1015(0/16/8)) read err: read after end of file
file_win32_pread(268,2,buffer,1017(0/16/10)) read err: read after end of file
file_win32_pread(268,3,buffer,1023(0/16/16)) read err: read after end of file
file_win32_pread(268,1,buffer,1264(0/20/5)) read err: read after end of file
file_win32_pread(268,1,buffer,1025(0/16/18)) read err: read after end of file
file_win32_pread(268,1,buffer,1026(0/16/19)) read err: read after end of file
file_win32_pread(268,2,buffer,1031(0/16/24)) read err: read after end of file
file_win32_pread(268,2,buffer,1033(0/16/26)) read err: read after end of file
file_win32_pread(268,3,buffer,1039(0/16/32)) read err: read after end of file
file_win32_pread(268,1,buffer,1280(0/20/21)) read err: read after end of file
file_win32_pread(268,2,buffer,1071(0/17/1)) read err: read after end of file
file_win32_pread(268,1,buffer,1073(0/17/3)) read err: read after end of file
file_win32_pread(268,2,buffer,1078(0/17/8)) read err: read after end of file
file_win32_pread(268,2,buffer,1080(0/17/10)) read err: read after end of file
file_win32_pread(268,3,buffer,1086(0/17/16)) read err: read after end of file
file_win32_pread(268,1,buffer,1327(0/21/5)) read err: read after end of file
file_win32_pread(268,2,buffer,1280(0/20/21)) read err: read after end of file
file_win32_pread(268,1,buffer,1282(0/20/23)) read err: read after end of file
file_win32_pread(268,2,buffer,1287(0/20/28)) read err: read after end of file
file_win32_pread(268,2,buffer,1289(0/20/30)) read err: read after end of file
file_win32_pread(268,3,buffer,1295(0/20/36)) read err: read after end of file
file_win32_pread(268,1,buffer,1536(0/24/25)) read err: read after end of file
file_win32_pread(268,2,buffer,1536(0/24/25)) read err: read after end of file
file_win32_pread(268,1,buffer,1538(0/24/27)) read err: read after end of file
file_win32_pread(268,2,buffer,1543(0/24/32)) read err: read after end of file
file_win32_pread(268,2,buffer,1545(0/24/34)) read err: read after end of file
file_win32_pread(268,3,buffer,1551(0/24/40)) read err: read after end of file
file_win32_pread(268,1,buffer,1792(0/28/29)) read err: read after end of file
file_win32_pread(268,2,buffer,1792(0/28/29)) read err: read after end of file
file_win32_pread(268,1,buffer,1794(0/28/31)) read err: read after end of file
file_win32_pread(268,2,buffer,1799(0/28/36)) read err: read after end of file
file_win32_pread(268,2,buffer,1801(0/28/38)) read err: read after end of file
file_win32_pread(268,3,buffer,1807(0/28/44)) read err: read after end of file
file_win32_pread(268,1,buffer,2048(0/32/33)) read err: read after end of file
file_win32_pread(268,2,buffer,2048(0/32/33)) read err: read after end of file
file_win32_pread(268,1,buffer,2050(0/32/35)) read err: read after end of file
file_win32_pread(268,2,buffer,2055(0/32/40)) read err: read after end of file
file_win32_pread(268,2,buffer,2057(0/32/42)) read err: read after end of file
file_win32_pread(268,3,buffer,2063(0/32/48)) read err: read after end of file
file_win32_pread(268,1,buffer,2304(0/36/37)) read err: read after end of file
file_win32_pread(268,2,buffer,2304(0/36/37)) read err: read after end of file
file_win32_pread(268,1,buffer,2306(0/36/39)) read err: read after end of file
file_win32_pread(268,2,buffer,2311(0/36/44)) read err: read after end of file
file_win32_pread(268,2,buffer,2313(0/36/46)) read err: read after end of file
file_win32_pread(268,3,buffer,2319(0/36/52)) read err: read after end of file
file_win32_pread(268,1,buffer,2560(0/40/41)) read err: read after end of file
file_win32_pread(268,2,buffer,2560(0/40/41)) read err: read after end of file
file_win32_pread(268,1,buffer,2562(0/40/43)) read err: read after end of file
file_win32_pread(268,2,buffer,2567(0/40/48)) read err: read after end of file
file_win32_pread(268,2,buffer,2569(0/40/50)) read err: read after end of file
file_win32_pread(268,3,buffer,2575(0/40/56)) read err: read after end of file
file_win32_pread(268,1,buffer,2816(0/44/45)) read err: read after end of file
file_win32_pread(268,2,buffer,2816(0/44/45)) read err: read after end of file
file_win32_pread(268,1,buffer,2818(0/44/47)) read err: read after end of file
file_win32_pread(268,2,buffer,2823(0/44/52)) read err: read after end of file
file_win32_pread(268,2,buffer,2825(0/44/54)) read err: read after end of file
file_win32_pread(268,3,buffer,2831(0/44/60)) read err: read after end of file
file_win32_pread(268,1,buffer,3072(0/48/49)) read err: read after end of file
file_win32_pread(268,2,buffer,3072(0/48/49)) read err: read after end of file
file_win32_pread(268,1,buffer,3074(0/48/51)) read err: read after end of file
file_win32_pread(268,2,buffer,3079(0/48/56)) read err: read after end of file
file_win32_pread(268,2,buffer,3081(0/48/58)) read err: read after end of file
file_win32_pread(268,3,buffer,3087(0/49/1)) read err: read after end of file
file_win32_pread(268,1,buffer,3328(0/52/53)) read err: read after end of file
file_win32_pread(268,2,buffer,3328(0/52/53)) read err: read after end of file
file_win32_pread(268,1,buffer,3330(0/52/55)) read err: read after end of file
file_win32_pread(268,2,buffer,3335(0/52/60)) read err: read after end of file
file_win32_pread(268,2,buffer,3337(0/52/62)) read err: read after end of file
file_win32_pread(268,3,buffer,3343(0/53/5)) read err: read after end of file
file_win32_pread(268,1,buffer,3584(0/56/57)) read err: read after end of file
file_win32_pread(268,2,buffer,3584(0/56/57)) read err: read after end of file
file_win32_pread(268,1,buffer,3586(0/56/59)) read err: read after end of file
file_win32_pread(268,2,buffer,3591(0/57/1)) read err: read after end of file
file_win32_pread(268,2,buffer,3593(0/57/3)) read err: read after end of file
file_win32_pread(268,3,buffer,3599(0/57/9)) read err: read after end of file
file_win32_pread(268,1,buffer,3840(0/60/61)) read err: read after end of file
file_win32_pread(268,2,buffer,3840(0/60/61)) read err: read after end of file
file_win32_pread(268,1,buffer,3842(0/60/63)) read err: read after end of file
file_win32_pread(268,2,buffer,3847(0/61/5)) read err: read after end of file
file_win32_pread(268,2,buffer,3849(0/61/7)) read err: read after end of file
file_win32_pread(268,3,buffer,3855(0/61/13)) read err: read after end of file
file_win32_pread(268,1,buffer,4096(0/65/2)) read err: read after end of file
file_win32_pread(268,2,buffer,4096(0/65/2)) read err: read after end of file
file_win32_pread(268,1,buffer,4098(0/65/4)) read err: read after end of file
file_win32_pread(268,2,buffer,4103(0/65/9)) read err: read after end of file
file_win32_pread(268,2,buffer,4105(0/65/11)) read err: read after end of file
file_win32_pread(268,3,buffer,4111(0/65/17)) read err: read after end of file
file_win32_pread(268,1,buffer,4352(0/69/6)) read err: read after end of file
file_win32_pread(268,2,buffer,4352(0/69/6)) read err: read after end of file
file_win32_pread(268,1,buffer,4354(0/69/8)) read err: read after end of file
file_win32_pread(268,2,buffer,4359(0/69/13)) read err: read after end of file
file_win32_pread(268,2,buffer,4361(0/69/15)) read err: read after end of file
file_win32_pread(268,3,buffer,4367(0/69/21)) read err: read after end of file
file_win32_pread(268,1,buffer,4608(0/73/10)) read err: read after end of file
file_win32_pread(268,2,buffer,4608(0/73/10)) read err: read after end of file
file_win32_pread(268,1,buffer,4610(0/73/12)) read err: read after end of file
file_win32_pread(268,2,buffer,4615(0/73/17)) read err: read after end of file
file_win32_pread(268,2,buffer,4617(0/73/19)) read err: read after end of file
file_win32_pread(268,3,buffer,4623(0/73/25)) read err: read after end of file
file_win32_pread(268,1,buffer,4864(0/77/14)) read err: read after end of file
file_win32_pread(268,2,buffer,4864(0/77/14)) read err: read after end of file
file_win32_pread(268,1,buffer,4866(0/77/16)) read err: read after end of file
file_win32_pread(268,2,buffer,4871(0/77/21)) read err: read after end of file
file_win32_pread(268,2,buffer,4873(0/77/23)) read err: read after end of file
file_win32_pread(268,3,buffer,4879(0/77/29)) read err: read after end of file
file_win32_pread(268,1,buffer,5120(0/81/18)) read err: read after end of file
file_win32_pread(268,2,buffer,5120(0/81/18)) read err: read after end of file
file_win32_pread(268,1,buffer,5122(0/81/20)) read err: read after end of file
file_win32_pread(268,2,buffer,5127(0/81/25)) read err: read after end of file
file_win32_pread(268,2,buffer,5129(0/81/27)) read err: read after end of file
file_win32_pread(268,3,buffer,5135(0/81/33)) read err: read after end of file
file_win32_pread(268,1,buffer,5376(0/85/22)) read err: read after end of file
file_win32_pread(268,2,buffer,5376(0/85/22)) read err: read after end of file
file_win32_pread(268,1,buffer,5378(0/85/24)) read err: read after end of file
file_win32_pread(268,2,buffer,5383(0/85/29)) read err: read after end of file
file_win32_pread(268,2,buffer,5385(0/85/31)) read err: read after end of file
file_win32_pread(268,3,buffer,5391(0/85/37)) read err: read after end of file
file_win32_pread(268,1,buffer,5632(0/89/26)) read err: read after end of file
file_win32_pread(268,2,buffer,5632(0/89/26)) read err: read after end of file
file_win32_pread(268,1,buffer,5634(0/89/28)) read err: read after end of file
file_win32_pread(268,2,buffer,5639(0/89/33)) read err: read after end of file
file_win32_pread(268,2,buffer,5641(0/89/35)) read err: read after end of file
file_win32_pread(268,3,buffer,5647(0/89/41)) read err: read after end of file
file_win32_pread(268,1,buffer,5888(0/93/30)) read err: read after end of file
file_win32_pread(268,2,buffer,5888(0/93/30)) read err: read after end of file
file_win32_pread(268,1,buffer,5890(0/93/32)) read err: read after end of file
file_win32_pread(268,2,buffer,5895(0/93/37)) read err: read after end of file
file_win32_pread(268,2,buffer,5897(0/93/39)) read err: read after end of file
file_win32_pread(268,3,buffer,5903(0/93/45)) read err: read after end of file
file_win32_pread(268,1,buffer,6144(0/97/34)) read err: read after end of file
file_win32_pread(268,2,buffer,6144(0/97/34)) read err: read after end of file
file_win32_pread(268,1,buffer,6146(0/97/36)) read err: read after end of file
file_win32_pread(268,2,buffer,6151(0/97/41)) read err: read after end of file
file_win32_pread(268,2,buffer,6153(0/97/43)) read err: read after end of file
file_win32_pread(268,3,buffer,6159(0/97/49)) read err: read after end of file
file_win32_pread(268,1,buffer,6400(0/101/38)) read err: read after end of file
file_win32_pread(268,2,buffer,6400(0/101/38)) read err: read after end of file
file_win32_pread(268,1,buffer,6402(0/101/40)) read err: read after end of file
file_win32_pread(268,2,buffer,6407(0/101/45)) read err: read after end of file
file_win32_pread(268,2,buffer,6409(0/101/47)) read err: read after end of file
file_win32_pread(268,3,buffer,6415(0/101/53)) read err: read after end of file
file_win32_pread(268,1,buffer,6656(0/105/42)) read err: read after end of file
file_win32_pread(268,2,buffer,6656(0/105/42)) read err: read after end of file
file_win32_pread(268,1,buffer,6658(0/105/44)) read err: read after end of file
file_win32_pread(268,2,buffer,6663(0/105/49)) read err: read after end of file
file_win32_pread(268,2,buffer,6665(0/105/51)) read err: read after end of file
file_win32_pread(268,3,buffer,6671(0/105/57)) read err: read after end of file
file_win32_pread(268,1,buffer,6912(0/109/46)) read err: read after end of file
file_win32_pread(268,2,buffer,6912(0/109/46)) read err: read after end of file
file_win32_pread(268,1,buffer,6914(0/109/48)) read err: read after end of file
file_win32_pread(268,2,buffer,6919(0/109/53)) read err: read after end of file
file_win32_pread(268,2,buffer,6921(0/109/55)) read err: read after end of file
file_win32_pread(268,3,buffer,6927(0/109/61)) read err: read after end of file
file_win32_pread(268,1,buffer,7168(0/113/50)) read err: read after end of file
file_win32_pread(268,2,buffer,7168(0/113/50)) read err: read after end of file
file_win32_pread(268,1,buffer,7170(0/113/52)) read err: read after end of file
file_win32_pread(268,2,buffer,7175(0/113/57)) read err: read after end of file
file_win32_pread(268,2,buffer,7177(0/113/59)) read err: read after end of file
file_win32_pread(268,3,buffer,7183(0/114/2)) read err: read after end of file
file_win32_pread(268,1,buffer,7424(0/117/54)) read err: read after end of file
file_win32_pread(268,2,buffer,7424(0/117/54)) read err: read after end of file
file_win32_pread(268,1,buffer,7426(0/117/56)) read err: read after end of file
file_win32_pread(268,2,buffer,7431(0/117/61)) read err: read after end of file
file_win32_pread(268,2,buffer,7433(0/117/63)) read err: read after end of file
file_win32_pread(268,3,buffer,7439(0/118/6)) read err: read after end of file
file_win32_pread(268,1,buffer,7680(0/121/58)) read err: read after end of file
file_win32_pread(268,2,buffer,7680(0/121/58)) read err: read after end of file
file_win32_pread(268,1,buffer,7682(0/121/60)) read err: read after end of file
file_win32_pread(268,2,buffer,7687(0/122/2)) read err: read after end of file
file_win32_pread(268,2,buffer,7689(0/122/4)) read err: read after end of file
file_win32_pread(268,3,buffer,7695(0/122/10)) read err: read after end of file
file_win32_pread(268,1,buffer,7936(0/125/62)) read err: read after end of file
file_win32_pread(268,2,buffer,7936(0/125/62)) read err: read after end of file
file_win32_pread(268,1,buffer,7938(0/126/1)) read err: read after end of file
file_win32_pread(268,2,buffer,7943(0/126/6)) read err: read after end of file
file_win32_pread(268,2,buffer,7945(0/126/8)) read err: read after end of file
file_win32_pread(268,3,buffer,7951(0/126/14)) read err: read after end of file
file_win32_pread(268,1,buffer,8192(0/130/3)) read err: read after end of file
file_win32_pread(268,2,buffer,8192(0/130/3)) read err: read after end of file
file_win32_pread(268,1,buffer,8194(0/130/5)) read err: read after end of file
file_win32_pread(268,2,buffer,8199(0/130/10)) read err: read after end of file
file_win32_pread(268,2,buffer,8201(0/130/12)) read err: read after end of file
file_win32_pread(268,3,buffer,8207(0/130/18)) read err: read after end of file
file_win32_pread(268,1,buffer,8448(0/134/7)) read err: read after end of file
file_win32_pread(268,2,buffer,8448(0/134/7)) read err: read after end of file
file_win32_pread(268,1,buffer,8450(0/134/9)) read err: read after end of file
file_win32_pread(268,2,buffer,8455(0/134/14)) read err: read after end of file
file_win32_pread(268,2,buffer,8457(0/134/16)) read err: read after end of file
file_win32_pread(268,3,buffer,8463(0/134/22)) read err: read after end of file
file_win32_pread(268,1,buffer,8704(0/138/11)) read err: read after end of file
file_win32_pread(268,2,buffer,8704(0/138/11)) read err: read after end of file
file_win32_pread(268,1,buffer,8706(0/138/13)) read err: read after end of file
file_win32_pread(268,2,buffer,8711(0/138/18)) read err: read after end of file
file_win32_pread(268,2,buffer,8713(0/138/20)) read err: read after end of file
file_win32_pread(268,3,buffer,8719(0/138/26)) read err: read after end of file
file_win32_pread(268,1,buffer,8960(0/142/15)) read err: read after end of file
file_win32_pread(268,2,buffer,8960(0/142/15)) read err: read after end of file
file_win32_pread(268,1,buffer,8962(0/142/17)) read err: read after end of file
file_win32_pread(268,2,buffer,8967(0/142/22)) read err: read after end of file
file_win32_pread(268,2,buffer,8969(0/142/24)) read err: read after end of file
file_win32_pread(268,3,buffer,8975(0/142/30)) read err: read after end of file
file_win32_pread(268,1,buffer,9216(0/146/19)) read err: read after end of file
file_win32_pread(268,2,buffer,9216(0/146/19)) read err: read after end of file
file_win32_pread(268,1,buffer,9218(0/146/21)) read err: read after end of file
file_win32_pread(268,2,buffer,9223(0/146/26)) read err: read after end of file
file_win32_pread(268,2,buffer,9225(0/146/28)) read err: read after end of file
file_win32_pread(268,3,buffer,9231(0/146/34)) read err: read after end of file
file_win32_pread(268,1,buffer,9472(0/150/23)) read err: read after end of file
file_win32_pread(268,2,buffer,9472(0/150/23)) read err: read after end of file
file_win32_pread(268,1,buffer,9474(0/150/25)) read err: read after end of file
file_win32_pread(268,2,buffer,9479(0/150/30)) read err: read after end of file
file_win32_pread(268,2,buffer,9481(0/150/32)) read err: read after end of file
file_win32_pread(268,3,buffer,9487(0/150/38)) read err: read after end of file
file_win32_pread(268,1,buffer,9728(0/154/27)) read err: read after end of file
file_win32_pread(268,2,buffer,9728(0/154/27)) read err: read after end of file
file_win32_pread(268,1,buffer,9730(0/154/29)) read err: read after end of file
file_win32_pread(268,2,buffer,9735(0/154/34)) read err: read after end of file
file_win32_pread(268,2,buffer,9737(0/154/36)) read err: read after end of file
file_win32_pread(268,3,buffer,9743(0/154/42)) read err: read after end of file
file_win32_pread(268,1,buffer,9984(0/158/31)) read err: read after end of file
file_win32_pread(268,2,buffer,9984(0/158/31)) read err: read after end of file
file_win32_pread(268,1,buffer,9986(0/158/33)) read err: read after end of file
file_win32_pread(268,2,buffer,9991(0/158/38)) read err: read after end of file
file_win32_pread(268,2,buffer,9993(0/158/40)) read err: read after end of file
file_win32_pread(268,3,buffer,9999(0/158/46)) read err: read after end of file
file_win32_pread(268,1,buffer,10240(0/162/35)) read err: read after end of file
file_win32_pread(268,2,buffer,10240(0/162/35)) read err: read after end of file
file_win32_pread(268,1,buffer,10242(0/162/37)) read err: read after end of file
file_win32_pread(268,2,buffer,10247(0/162/42)) read err: read after end of file
file_win32_pread(268,2,buffer,10249(0/162/44)) read err: read after end of file
file_win32_pread(268,3,buffer,10255(0/162/50)) read err: read after end of file
file_win32_pread(268,1,buffer,10496(0/166/39)) read err: read after end of file
file_win32_pread(268,2,buffer,10496(0/166/39)) read err: read after end of file
file_win32_pread(268,1,buffer,10498(0/166/41)) read err: read after end of file
file_win32_pread(268,2,buffer,10503(0/166/46)) read err: read after end of file
file_win32_pread(268,2,buffer,10505(0/166/48)) read err: read after end of file
file_win32_pread(268,3,buffer,10511(0/166/54)) read err: read after end of file
file_win32_pread(268,1,buffer,10752(0/170/43)) read err: read after end of file
file_win32_pread(268,2,buffer,10752(0/170/43)) read err: read after end of file
file_win32_pread(268,1,buffer,10754(0/170/45)) read err: read after end of file
file_win32_pread(268,2,buffer,10759(0/170/50)) read err: read after end of file
file_win32_pread(268,2,buffer,10761(0/170/52)) read err: read after end of file
file_win32_pread(268,3,buffer,10767(0/170/58)) read err: read after end of file
file_win32_pread(268,1685/47/36)) read err: read after end of file
file_win32_pread(268,3,buffer,27072527(1685/47/42)) read err: read after end of file
file_win32_pread(268,1,buffer,27072768(1685/51/31)) read err: read after end of file
file_win32_pread(268,2,buffer,27072768(1685/51/31)) read err: read after end of file
file_win32_pread(268,1,buffer,27072770(1685/51/33)) read err: read after end of file
file_win32_pread(268,2,buffer,27072775(1685/51/38)) read err: read after end of file
file_win32_pread(268,2,buffer,27072777(1685/51/40)) read err: read after end of file
file_win32_pread(268,3,buffer,27072783(1685/51/46)) read err: read after end of file
file_win32_pread(268,1,buffer,27073024(1685/55/35)) read err: read after end of file
file_win32_pread(268,2,buffer,27073024(1685/55/35)) read err: read after end of file
file_win32_pread(268,1,buffer,27073026(1685/55/37)) read err: read after end of file
file_win32_pread(268,2,buffer,27073031(1685/55/42)) read err: read after end of file
file_win32_pread(268,2,buffer,27073033(1685/55/44)) read err: read after end of file
file_win32_pread(268,3,buffer,27073039(1685/55/50)) read err: read after end of file
file_win32_pread(268,1,buffer,27073280(1685/59/39)) read err: read after end of file
file_win32_pread(268,2,buffer,27073280(1685/59/39)) read err: read after end of file
file_win32_pread(268,1,buffer,27073282(1685/59/41)) read err: read after end of file
file_win32_pread(268,2,buffer,27073287(1685/59/46)) read err: read after end of file
file_win32_pread(268,2,buffer,27073289(1685/59/48)) read err: read after end of file
file_win32_pread(268,3,buffer,27073295(1685/59/54)) read err: read after end of file
file_win32_pread(268,1,buffer,27073536(1685/63/43)) read err: read after end of file
file_win32_pread(268,2,buffer,27073536(1685/63/43)) read err: read after end of file
file_win32_pread(268,1,buffer,27073538(1685/63/45)) read err: read after end of file
file_win32_pread(268,2,buffer,27073543(1685/63/50)) read err: read after end of file
file_win32_pread(268,2,buffer,27073545(1685/63/52)) read err: read after end of file
file_win32_pread(268,3,buffer,27073551(1685/63/58)) read err: read after end of file
file_win32_pread(268,1,buffer,27073792(1685/67/47)) read err: read after end of file
file_win32_pread(268,2,buffer,27073792(1685/67/47)) read err: read after end of file
file_win32_pread(268,1,buffer,27073794(1685/67/49)) read err: read after end of file
file_win32_pread(268,2,buffer,27073799(1685/67/54)) read err: read after end of file
file_win32_pread(268,2,buffer,27073801(1685/67/56)) read err: read after end of file
file_win32_pread(268,3,buffer,27073807(1685/67/62)) read err: read after end of file
file_win32_pread(268,1,buffer,27074048(1685/71/51)) read err: read after end of file
file_win32_pread(268,2,buffer,27074048(1685/71/51)) read err: read after end of file
file_win32_pread(268,1,buffer,27074050(1685/71/53)) read err: read after end of file
file_win32_pread(268,2,buffer,27074055(1685/71/58)) read err: read after end of file
file_win32_pread(268,2,buffer,27074057(1685/71/60)) read err: read after end of file
file_win32_pread(268,3,buffer,27074063(1685/72/3)) read err: read after end of file
file_win32_pread(268,1,buffer,27074304(1685/75/55)) read err: read after end of file
file_win32_pread(268,2,buffer,27074304(1685/75/55)) read err: read after end of file
file_win32_pread(268,1,buffer,27074306(1685/75/57)) read err: read after end of file
file_win32_pread(268,2,buffer,27074311(1685/75/62)) read err: read after end of file
file_win32_pread(268,2,buffer,27074313(1685/76/1)) read err: read after end of file
file_win32_pread(268,3,buffer,27074319(1685/76/7)) read err: read after end of file
file_win32_pread(268,1,buffer,27074560(1685/79/59)) read err: read after end of file
file_win32_pread(268,2,buffer,27074560(1685/79/59)) read err: read after end of file
file_win32_pread(268,1,buffer,27074562(1685/79/61)) read err: read after end of file
file_win32_pread(268,2,buffer,27074567(1685/80/3)) read err: read after end of file
file_win32_pread(268,2,buffer,27074569(1685/80/5)) read err: read after end of file
file_win32_pread(268,3,buffer,27074575(1685/80/11)) read err: read after end of file
file_win32_pread(268,1,buffer,27074816(1685/83/63)) read err: read after end of file
file_win32_pread(268,2,buffer,27074816(1685/83/63)) read err: read after end of file
file_win32_pread(268,1,buffer,27074818(1685/84/2)) read err: read after end of file
file_win32_pread(268,2,buffer,27074823(1685/84/7)) read err: read after end of file
file_win32_pread(268,2,buffer,27074825(1685/84/9)) read err: read after end of file
file_win32_pread(268,3,buffer,27074831(1685/84/15)) read err: read after end of file
file_win32_pread(268,1,buffer,27075072(1685/88/4)) read err: read after end of file
file_win32_pread(268,2,buffer,27075072(1685/88/4)) read err: read after end of file
file_win32_pread(268,1,buffer,27075074(1685/88/6)) read err: read after end of file
file_win32_pread(268,2,buffer,27075079(1685/88/11)) read err: read after end of file
file_win32_pread(268,2,buffer,27075081(1685/88/13)) read err: read after end of file
file_win32_pread(268,3,buffer,27075087(1685/88/19)) read err: read after end of file
file_win32_pread(268,1,buffer,27075328(1685/92/8)) read err: read after end of file
file_win32_pread(268,2,buffer,27075328(1685/92/8)) read err: read after end of file
file_win32_pread(268,1,buffer,27075330(1685/92/10)) read err: read after end of file
file_win32_pread(268,2,buffer,27075335(1685/92/15)) read err: read after end of file
file_win32_pread(268,2,buffer,27075337(1685/92/17)) read err: read after end of file
file_win32_pread(268,3,buffer,27075343(1685/92/23)) read err: read after end of file
file_win32_pread(268,1,buffer,27075584(1685/96/12)) read err: read after end of file
file_win32_pread(268,2,buffer,27075584(1685/96/12)) read err: read after end of file
file_win32_pread(268,1,buffer,27075586(1685/96/14)) read err: read after
#8 Post by Fiona »
Did you run a full surface scan using HD tune?
Red marked blocks contain bad sectors.
It takes a while too!
