I'm broke before I get started.
The arrow keys don't work in TestDisk under Mac OS X 10.6.1.
Are there any Terminal gurus out there that can help me???
can't use TestDisk (Mac)
Re: can't use TestDisk (Mac)
more info needed to catch Christophe Grenier attention on your problem :
-what version of testdisk you tried ?
-do you have other return on the command line, like errors ?
-did you launch testdisk as root ?
Note that it seems there's a problem with testdisk/mac since some days but I can't be sure your problem is related to.
CG won't have access to a mac in the next ten days but we are doing some testings.
macevanscb
The current download for Mac: v7.0
I can't even quit normally... I have to ctl-X out to get back to the command prompt, so nothing is returned.
I'm doing sudo ./testdisk and entering the root password.
No rush on this... been dinking around with this drive for over a month.
