Hey
My WD External HD was working great. Yesterday when i plugged it in pc after a month, it gives error of making it format. Tried using testwin, initially it was showing bad sector - bad, tried build IS then it showed bad sector - ok. but still partition not accessible. Also it can't list the files. Pls help me out.
Now m again using build IS, its showing something else, (screenshot attached). What to do??
Found Partitions But Can't Recover Them - BADSECTORS
- Picture1.jpg (62.75 KiB) Viewed 2407 times
Re: Found Partitions But Can't Recover Them - BADECTORS
Most of recent WD external disks are encrypted by interface. You can't use it inside a PC (direct sata attached) to recover the data.
