Seagate Backup Plus 4TB - NEED HELP PLS!!
jmw637
Re: Seagate Backup Plus 4TB - NEED HELP PLS!!
#11 Post by jmw637 »
so when i analyze the disk you requested (Disk / dev / sdd - 4000 GB), the results are as follows:
testdisk screenshots - 4.jpg (69.49 KiB) Viewed 3157 times
a quick search yields the following results:
testdisk screenshots - 5.jpg (80.49 KiB) Viewed 3157 times
if i try and list the files i receive that same error message:
testdisk screenshots - 6.jpg (55.3 KiB) Viewed 3157 times
questions: should i make any changes to the partition characteristics? should i change the partition itself (from "HPFS - NTFS" to simply "NTFS")?
...to be continued in new reply (because i can only attach a max of three screenshots here)
jmw637
#12 Post by jmw637 »
when i run a deeper search these are the results:
testdisk screenshots - 7.jpg (76.55 KiB) Viewed 3157 times
when i hit continue, i get the same results as from the quick search:
testdisk screenshots - 8.jpg (80.55 KiB) Viewed 3157 times
and the same results when i try to view the files:
testdisk screenshots - 9.jpg (55.2 KiB) Viewed 3157 times
...thoughts?
thanks in advance for any advice and/or help you can provide...jeff
jmw637
#13 Post by jmw637 »
it's that bad, huh? ;)
jmw637
#14 Post by jmw637 »
so i was asked "To select your disk (Disk / dev / sdd - 4000 GB) is appreciated, because I'd get information about your current partition table."
which i did...and provided (what i thought) was great detail on the results.
so why no response?
