Novice seeking help with MicroSD
glks
#1 Post by glks »
Hi there,
This is my 2nd attempt to post this, so my apologies if it's already posted - I don't see it in my post.
I have a MicroSD card which has become damaged as a result of my phone shutting off - the battery ran out of power.
I have followed the instructions on the wiki as far as I can, but now I'm stuck!
I'm not sure what to do from here.
Can you please advise - screenshots attached.
screenshots
screenshots
I'm just starting to realise what I would lose if I can't retrieve this data from my SD card - which was full - photos, documents - oh!no! - videos from holidays.
I'd really appreciate your help - thanks for taking the time to read this & thank you to the developer for the providing the software. I'll definitely donate if I it helps me get my stuff back!
Thanks again!
Graham
Deity666
Re: Novice seeking help with MicroSD
#2 Post by Deity666 »
I'm sorry, this is new to me and I'm dealing with large drives, but my mom does have a small memory card for her mp3 player.
It looks like the only difference between the two photos is that the second one lists the same info twice - just once in the first picture. The only differences are the choice to write in the first.
Can you access the contents of the card via computer? I know it can be a bear, but when it comes to pictures and irreplaceble things, I have a hard time giving up.
IF...the problem is you can't access the info and no one else comes and helps (Although, I've only signed up for a couple of days and don't want to slander anyone, I would try hitting WRITE in the first screen and see what happens. If I'm wrong, I would love to learn why, so I shall fallow this topic.
Do you have a card reader? Are things corrupt or what is the problem?
