I'm trying to recover the file system on a single-partition NTFS drive (an old Windows XP 32-bit disk). I'm doing this under 64-bit Linux. Neither Linux nor Windows are capable of mounting the drive. However, using PhotoRec, I can recuperate numerous files (sorting them is a different matter). Nonetheless, I'm having difficulty recreating the file system of the NTFS drive.
When running testdisk on the drive, it recognizes it as an Intel/PC partition. Upon analysing it, testdisk finds a single NTFS partition:
> 1 * HPFS - NTFS 0 1 1 19455 254 63 312560577Code: Select all
Disk image.dd - 160 GB / 149 GiB - CHS 19456 255 63
> P NTFS 0 0 1 19455 253 63 312560577Code: Select all
Status: OK
Status: OK
Sectors are identical.
any data; even if the partition is not bootable.Code: Select all
>dr-xr-xr-x 0 0 0 24-Jan-2014 22:23 .
dr-xr-xr-x 0 0 0 24-Jan-2014 22:23 .Code: Select all
MFT and MFT mirror are bad. Failed to repair them.--------------------------------------------
* Aside:
Note that if I choose Intel/PC (rather than "None") for the partition type, upon analysing it, I receive the following output:
1 * Sys=72 13577 238 11 119521 238 60 1701990410
Bad relative sector.
2 * Sys=74 45381 70 3 79242 34 29 543974724
3 * NetWare 3.11+ 10498 56 41 10498 56 40 0
