Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63
Analyse cylinder 17441/38912: 44%
  HFS                    754  59 22  1276 101 55    8388610 [~?~?~?M-:D^A]
  HFS                    232  16 55   754  59 25    8388610 [~?~?~?M-:D^A]
  HFS                    774 237 35 162551 196 10 2598944898
  HFS                    995 161 27   999 202 40      66857 [M-6^G]
  HFS                    991 120 17   995 161 30      66857 [M-6^G]
Warning: Incorrect number of heads/cylinder 4 (FAT) != 255 (HD)
Warning: Incorrect number of sectors per track 17 (FAT) != 63 (HD)
  FAT12                 2249  81  3  2250 155 14      20739 [NO NAME]
check_FAT: Unusual, only one FAT
check_FAT: Bad number of entries in root dir
  NTFS                  2428 210 32  2441 146 18     204800
  NTFS                  2441 146 18  2454  82  4     204800
  NTFS                  2901  90 55  2914  26 41     204800
  NTFS                  2914  26 41  2926 217 27     204800
Took a snapshot at 44% done, it''ll be about 5 more hours till its done completly. My problem, other than the obvious, is that I have an infection that survives multiple DBAN nukes and clean install from factory discs. From researching this stuff and running many, many scans i can definatly say its a spyware designed to harvest credit card info. Its causing a minimum of 4 driver conflicts and uses peripheral hardware like usb, vga and sound. I doubt its in bios though it does seem to have midified by battery driver in order to boot alonside it. IDK I'm pretty lame at this stuff. There are also fonts that are a few hundred mb large. MBR.EXE says its mebroot/sinowal/TDL4, but from what i understand that particular infection doesnt change geometry like whats been done - I guess its changed geometry it sure seems like it. I ran Autopsy 3.0.1 on a fresh barebone win7 install and it found some virus's under installed programs an registered 4 partition 2 ntsf and 2 unallocated  Anyway I need advice on how to erase the entire drive HPA DCO all of it. Please dont refer me to any forum for help because those forum, as good and usefull as they are, are no help. They rely on scanners that dont pick this up. Any comments will be helpfull whether i take it or not. Thnks.
						Need help plz
