HD prompts to Format Drive
Eddy
#1 Post by Eddy »
My laptop no longer turns on (motherboard). I extracted the 500GB WD hard drive from the laptop and connected it to another computer via SATA to USB but it comes up with a message to Format the disk. All I really need to do it extract all the data, ideally keeping the folder structure.
I tried running a chkdsk on it and I get an error message that the file system is RAW and chkdsk is unavailable.
Did some research and Found TestDisk but I'm not really sure how to use it to restore the MBR or fix the partition so that I can connect it to another computer and read the files through Windows Explorer.
I tried writing a partition to the F: and that has now created a G: when I plugin the drive...
If anyone could please point me in the right direction, I'd really appreciate it! Log file of the Analysis copied below.
32bit version running on Windows. Windows 7 originally installed on the failing hard drive.
THANKS!
Eddy
Sun Aug 3 08:55:35 2014
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
Compilation date: 2014-07-30T07:20:09
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=620700368896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500107862016
Disk /dev/sda - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - TOSHIBA MK6459GSXP, S/N:7 21PF50T0, FW:GN00
Disk /dev/sdb - 500 GB / 465 GiB - CHS 7600 255 63, sector size=4096 - WDC WD50 00BPKT-00PK4T0, S/N:152D20337A0C
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 7600 255 63, sector size=4096 - WDC WD50 00BPKT-00PK4T0, S/N:152D20337A0C
Drive F: - 500 GB / 465 GiB - CHS 7600 255 63, sector size=4096 - WDC WD50 00BPKT-00PK4T0, S/N:152D20337A0C
Disk /dev/sdb - 500 GB / 465 GiB - WDC WD50 00BPKT-00PK4T0
Analyse Disk /dev/sdb - 500 GB / 465 GiB - CHS 7600 255 63
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 0 32 33 12 223 19 204800
2 P HPFS - NTFS 12 223 20 60801 47 46 976564224
NTFS at 0/4/5
filesystem size 204800
mft_lcn 8533
mftmirr_lcn 2
HPFS - NTFS 0 4 5 1 155 26 25600
NTFS at 1/155/27
filesystem size 976564224
mftmirr_lcn 2
HPFS - NTFS 1 155 27 7600 37 53 122070528
file_pread(5,1,buffer,122096650(7600/42/5)) lseek err Invalid argument
file_pread(5,1,buffer,122096703(7600/42/58)) lseek err Invalid argument
file_pread(5,1,buffer,122096713(7600/43/5)) lseek err Invalid argument
file_pread(5,2,buffer,122096647(7600/42/2)) lseek err Invalid argument
file_pread(5,2,buffer,122096649(7600/42/4)) lseek err Invalid argument
file_pread(5,3,buffer,122096655(7600/42/10)) lseek err Invalid argument
file_pread(5,1,buffer,122096896(7600/45/62)) lseek err Invalid argument
file_pread(5,1,buffer,122096672(7600/42/27)) lseek err Invalid argument
file_pread(5,1,buffer,122096688(7600/42/43)) lseek err Invalid argument
file_pread(5,1,buffer,122096704(7600/42/59)) lseek err Invalid argument
file_pread(5,1,buffer,122096720(7600/43/12)) lseek err Invalid argument
file_pread(5,1,buffer,122096736(7600/43/28)) lseek err Invalid argument
file_pread(5,1,buffer,122096752(7600/43/44)) lseek err Invalid argument
file_pread(5,1,buffer,122096768(7600/43/60)) lseek err Invalid argument
file_pread(5,1,buffer,122096784(7600/44/13)) lseek err Invalid argument
file_pread(5,1,buffer,122096800(7600/44/29)) lseek err Invalid argument
file_pread(5,1,buffer,122096816(7600/44/45)) lseek err Invalid argument
file_pread(5,1,buffer,122096832(7600/44/61)) lseek err Invalid argument
file_pread(5,1,buffer,122096848(7600/45/14)) lseek err Invalid argument
file_pread(5,1,buffer,122096864(7600/45/30)) lseek err Invalid argument
file_pread(5,1,buffer,122096880(7600/45/46)) lseek err Invalid argument
file_pread(5,1,buffer,122096895(7600/45/61)) lseek err Invalid argument
file_pread(5,2,buffer,122096896(7600/45/62)) lseek err Invalid argument
file_pread(5,2,buffer,122096897(7600/45/63)) lseek err Invalid argument
file_pread(5,2,buffer,122096903(7600/46/6)) lseek err Invalid argument
file_pread(5,2,buffer,122096905(7600/46/8)) lseek err Invalid argument
file_pread(5,2,buffer,122096911(7600/46/14)) lseek err Invalid argument
file_pread(5,2,buffer,122097151(7600/50/2)) lseek err Invalid argument
* HPFS - NTFS 0 4 5 1 155 26 25600
P HPFS - NTFS 1 155 27 7600 37 53 122070528
1 * HPFS - NTFS 0 4 5 1 155 26 25600
2 P HPFS - NTFS 1 155 27 7600 37 53 122070528
NTFS at 0/4/5
mft_lcn 8533
mftmirr_lcn 2
NTFS at 1/155/26
mft_lcn 8533
mftmirr_lcn 2
HPFS - NTFS 0 4 5 1 155 27 25600
NTFS at 7600/37/53
mftmirr_lcn 2
HPFS - NTFS 1 155 27 7600 37 54 122070528
NTFS found using backup sector, blocksize=4096, 500 GB / 465 GiB
file_pread(5,2,buffer,122096703(7600/42/58)) lseek err Invalid argument
file_pread(5,1,buffer,122096657(7600/42/12)) lseek err Invalid argument
file_pread(5,2,buffer,122096672(7600/42/27)) lseek err Invalid argument
file_pread(5,2,buffer,122096688(7600/42/43)) lseek err Invalid argument
file_pread(5,2,buffer,122096704(7600/42/59)) lseek err Invalid argument
file_pread(5,2,buffer,122096720(7600/43/12)) lseek err Invalid argument
file_pread(5,2,buffer,122096736(7600/43/28)) lseek err Invalid argument
file_pread(5,2,buffer,122096752(7600/43/44)) lseek err Invalid argument
file_pread(5,2,buffer,122096768(7600/43/60)) lseek err Invalid argument
file_pread(5,2,buffer,122096784(7600/44/13)) lseek err Invalid argument
file_pread(5,2,buffer,122096800(7600/44/29)) lseek err Invalid argument
file_pread(5,2,buffer,122096816(7600/44/45)) lseek err Invalid argument
file_pread(5,2,buffer,122096832(7600/44/61)) lseek err Invalid argument
file_pread(5,2,buffer,122096848(7600/45/14)) lseek err Invalid argument
file_pread(5,2,buffer,122096864(7600/45/30)) lseek err Invalid argument
file_pread(5,2,buffer,122096880(7600/45/46)) lseek err Invalid argument
NTFS at 1/155/26
mft_lcn 8533
mftmirr_lcn 2
HPFS - NTFS 1 155 26 3 51 48 25600
NTFS at 0/4/5
mft_lcn 8533
mftmirr_lcn 2
NTFS at 1/155/27
mftmirr_lcn 2
NTFS at 0/4/5
mft_lcn 8533
mftmirr_lcn 2
NTFS at 1/155/27
mftmirr_lcn 2
write!
Sun Aug 3 11:01:05 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=500000882688
Drive F: - 104 MB / 100 MiB - CHS 1 255 63, sector size=4096 - WDC WD50 00BPKT-00PK4T0, S/N:152D20337A0C
Drive G: - 500 GB / 465 GiB - CHS 7598 255 63, sector size=4096 - WDC WD50 00BPKT-00PK4T0, S/N:152D20337A0C
Drive F: - 104 MB / 100 MiB - WDC WD50 00BPKT-00PK4T0
Analyse Drive F: - 104 MB / 100 MiB - CHS 1 255 63
Geometry from i386 MBR: head=115 sector=52
BAD_RS LBA=1936269394 5382406
check_part_i386 1 type 4F: no test
BAD_RS LBA=1917848077 5967333
check_part_i386 2 type 73: no test
BAD_RS LBA=1818575915 5855017
check_part_i386 3 type 2B: no test
BAD_RS LBA=2844524554 5982593
check_part_i386 4 type 61: no test
1 * Sys=4F 120527 49 53 234813 237 34 1836016416
Warning: Bad starting cylinder (CHS and LBA don't match)
2 * Sys=73 119380 132 62 153270 41 37 544437093
3 * Sys=2B 113201 29 24 147074 114 59 544175136
4 * SpeedStor 177063 118 26 177066 225 63 54974
NTFS at 1/151/22
mft_lcn 8533
mftmirr_lcn 2
HPFS - NTFS 0 0 1 1 151 23 25600
Partition not added.
Drive G: - 500 GB / 465 GiB - WDC WD50 00BPKT-00PK4T0
Partition table has been cleared.
You have to reboot for the change to take effect.
Sun Aug 3 11:03:12 2014
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - WDC WD50 00BPKT-00PK4T0
Analyse Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 7600 255 63
NTFS at 0/4/5
Info: size boot_sector 204800, partition 25600
NTFS at 1/155/27
Info: size boot_sector 976564224, partition 122070528
NTFS at 0/4/5
mft_lcn 8533
mftmirr_lcn 2
NTFS at 1/155/27
mftmirr_lcn 2
A new copy of MBR code has been written.
