GUID partition table recovery - HFS+ and FAT32
nckdc
#1 Post by nckdc »
Hi. I'm new to the board and english is not my native language so accept my apologies in advance for any writing issues.
I have an external 2000 GB/ 1862 GiB HDD that I use primarily on my Mac. I can't remember exactly, but I'm sure that it had a GUID partition table. I had 2 HFS+ partitions: MiniPro (its size was something like 1460 or 1480 GB) and MiniPro Virtual Instruments (500 GB). It also had a FAT32 partition in case I should use it to take some files to a Windows machine (7 or 8 GB I think, can't remember very well now).
I had never connected the HDD to Windows, I did so a few weeks ago and it was fatal... Windows asked me to initialize the drive, I declined (obviously) but when i reconnected the drive to my Mac it was "not readable". I found testdisk when looking for a solution and it looks brilliant.
I'm running testdisk on Linux right now, I connected the HDD through a USB 3.0 port to accelerate the process (normally it is connected via FW800 on my MBP).
I have the quick search results but I don't dare to go any further (rewrite the partition table) without a little bit of expert advice. I had also the deep search results (took 24 hs to complete) but yesterday a power shortage made me loose the results and I accidentally overwrote the log file when I ran testdisk again this morning.
Now I'm running again the deep search, but I will paste here what I got so far, maybe you can tell me if I got enough information to attempt a partition recovery or I must wait till the deep search completion again.
>Disk /dev/sda - 500 GB / 465 GiB - ST500DM002-1BD142
 Disk /dev/sdb - 2000 GB / 1863 GiB - ASMT 2105
>[Proceed ]  [  Quit  ]
                                        nicolas@nicolas-lenovo:~$
If a disk listed above has incorrect size, check HD jumper settings, BIOS
I selected EFI GPT as suggested.
 [Intel  ] Intel/PC partition
>[EFI GPT] EFI GPT partition map (Mac i386, some x86_64...)
 [Humax  ] Humax partition table
 [Mac    ] Apple partition map
 [None   ] Non partitioned media
 [Sun    ] Sun Solaris partition
 [XBox   ] XBox partition
Hint: EFI GPT partition table type has been detected.
Note: Do NOT select 'None' for media with only a single partition. It's very
rare for a drive to be 'Non-partitioned'.
     CHS 1907729 64 32 - sector size=512
>[ Analyse  ] Analyse current partition structure and search for lost partitions
 [ Advanced ] Filesystem Utils
 [ Options  ] Modify options
 [ Quit     ] Return to disk selection
Note: Correct disk geometry is required for a successful recovery. 'Analyse'
process may give some warnings if it thinks the logical geometry is mismatched.
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 1907729 64 32
Trying alternate GPT
 1 P EFI System                    40     409639     409600 [EFI System Partitio
 2 P Mac HFS                   409640 2914710007 2914300368 [MiniPro]
 3 P Mac HFS               2914972152 3891534655  976562504 [Untitled]
Warning: number of heads/cylinder mismatches 255 (FAT) != 64 (HD)
 4 P MS Data               3891798016 3907028991   15230976 [Untitled] [MINIPRO
FAT]
                P=Primary  D=Deleted
>[Quick Search]  [ Backup ]
                            Try to locate partition
Here are the Quick Search results:
>P EFI System                    40     409639     409600 [EFI]
 P MS Data               3891798016 3907028991   15230976 [MINIPRO FAT]
                P=Primary  D=Deleted
     Enter: to continue
So that's what I have to this moment. Can you please tell me if I can attempt to recover my partitions with this information or a Deep search must be performed?
Thanks in advance,
Nicolas.
